Product improvement from Audi: IC guard
I changed the oil on the Q5 (3.0) yesterday and noticed that the intercooler is now behind a guard which protects the fins. The S4 types (pre-'13) have been protecting the IC with a screen. Audi has looked after this for us.
You know, I am very curious about all the Audi engine tech.
I've never owned an Audi, but we're close to pulling the trigger on the Q5 3.0T. With that said, where exactly is the inter-cooler? My prior experience with forced induction was with a '05 STi, and there was no missing that inter-cooler. At least on the Audi 2.0T, I was under the impression that the only cooling the intake charge received, was just the cold fuel from the direct injection. But I'm I not understanding Audi engine tech? Is there also an inter-cooler even for the 2.0? If the new 3.0 has BOTH an inter-cooler and direct injection, that must allow for some pretty decent tuning characteristics. Is the a place on this forum for just Q5 engine tech? |
Its a front mount ic in front of radiator hidden behind bumper.
is the 3.0t motor intercooled? if so it's a water to air intercooler.
the 2.0t is a conventional radiator mounted unit. |
Interesting. So the 2.0T has both the inter-cooler, and the direct injecting. Does that mean that people can really push the boost, aftermarket, with these things?
Any engine can be pushed :)
just that typically turbo or supercharged engines have a little more room to 'push'.... tuning on a naturally aspirated GAS engine usually gives 5 to 10% hp max... on a turbo GAS engine you can get 3 to 4 times that... and on turbo diesel engines an order of magnitude more is possible... all without any hardware changes, just software... of course, that assumes that the EPA won't come calling and shut down all the tuning companies like they are starting to... https://www.google.com/search?q=h%26s+tuning+epa |
1 Attachment(s)
Originally Posted by NABS4
(Post 24394954)
Tks |
As they say, you gotta pay to play
besides the emissions issues, I hope no one really thinks there is quasi "free" power here beyond direct cost of some power upgrade. As you pump up a motor significantly, all the ancillaries need to be up to it, and seldom are. Instead there is often a long trail of broken, blown and earlier wear results. Sure, I like doing it too, but it takes some thought and care, not just a quick flash and dash.
2 Attachment(s)
Originally Posted by HZ60
(Post 24446025)
I saw your mention of the IC radiator guard in another thread and found your original post. I was wondering if it's one of those "not for U.S. markets" things? I don't seem to have one. I'd like to get one if anybody has a part number. Bug screen would probably work but I'd rather have a real one.
Tks |
Yea, the intercooler is at the bottom. It may be small, but it is quite fat (around 3" if I remember correctly). The radiator and condensor are both under 1" thick for comparison.
Is that an aftermarket condenser? The stock one that came off my car was black (aftermarket one that I got is silver with power steering cooler mounts on it - couldn't justify spending $380 for an OEM when the aftermarket cost me $50 including shipping) |
