Rear Tail light Replacement
I did a search and did not find anything on it. I had to change the bumper rear tail light due to my girlfriends exceptional driving. I bought a cheap china replacement and not all the lights worked. Bought the Audi part and it still doesn't work quite right. Same part number. What am I missing here? Does it need to be "Learned" to the computer or something silly?
Originally Posted by pktrusty
(Post 25284047)
I had a blond moment. I had purchased lower bumper tail light replacement from China. The wiring setup was wrong and was missing the outside side marker hole all together. I purchased a Audi Direct replacement and installed. It did not work either. I did not have a chance to look at it till this morning. Apparently either I forgot to plug it in before I installed or it didn't click and came out. Situation is fixed now. It has been a long week and I everything sorted now on my gf's car.
The reason I asked about decoding is because the Chinese guy was telling me that the light needed to be "learned" to the computer. The rear tail light is literally wires and bulbs so I figured if it was wired the same it should work. That is where my confusion came from. Thank
(Post 25284388)
I replaced both of my taillights recently, I used OEM Magneti Marelli parts and even fit a couple of (can bus friendly) backup lights, it might have been the easiest DIY ever, no more than 5 minutes on each corner :)
Iggy-
They are the Audi OEM manufacturer? Where did you get them? |
Originally Posted by Redd
(Post 25287629)
Iggy-
First I purchased a chinese replacement that did not have a spot for the side marker on the bumper tail light. I did buy a OEM replacement and forgot to plug it in I was in such a hurry. But I decided to make the spot for the corner marker and use the harness from the old light on the chinese replacement. It worked so I sold the OEM one. My OEM was from Ebay. A dealer was clearing out some parts.
Were they simply the lowest cost OEM source you could find? Or were there other reasons for choosing this supplier?
(I still suspect that Audi sends around trolls to pull all the Q5's out of the pick-a-part yards, there's just no way used parts can be so impossible to find!) |
