Q5e Prestige Stealth Hitch Install
Wow, I finally got up the nerve and did the Stealth Hitch install today. I took my time, and was very careful, as I have a loaded prestige so there are sensors all over the place. I did not unplug the bumper, wiring, just was very careful and made sure it was well supported to avoid any major stress on the wires while I installed the hitch. Very happy with the look! I did not do any wiring as I'm only planning to use this for accessories like my bike rack and rear cargo tray. Maybe if a official Audi wiring kit becomes available I'll take another look at the full wiring for trailer, but not holding my breath for that. For now I'm good, and now my Audi is complete.
If you want full instructions on the the process here is the link below. But I found an error in the instructions. Instead of a T40 Torx, you need a T30 Torx, this is to remove the cargo floor which they don't make clear in the instructions (I'll email them and let them know they need to update that). I would also recommend using a razor blade knife to cut through the trim instead of a dremel, the dremel just melts the plastic, while the razor knife leaves a clean cut. Otherwise smooth, but nervous ~3 hour install (it's my new toy, not easy taking it apart...). (PDF) https://cdn.shopify.com/s/files/1/21...f?v=1617305695 https://cimg3.ibsrv.net/gimg/www.aud...3e401afeba.jpg The 12V (near seats), 14.1KwH Main Battery (big silver box) and B&O Sub next to the rear sill, all under the load floor. https://cimg3.ibsrv.net/gimg/www.aud...4876ccc9f2.jpg Bumper trim off, lots of wires, and the crash bumper stock. https://cimg2.ibsrv.net/gimg/www.aud...678e3f4772.jpg Bumper trim off, Stealth Hitch bar install under original bumper (but cross bar doesn't return) https://cimg6.ibsrv.net/gimg/www.aud...3dbdd90f13.jpg Everything back together, hard to notice the cut-out for the hitch. https://cimg9.ibsrv.net/gimg/www.aud...4717dd88e0.jpg And same view, but with the receiver locked in. Still looks good. |
Very cool. Nice to have pics of the battery too. I really like the Stealth Hitch and its disappearing act without the drawbar receiver installed.
Yeah, it's not the cheapest option out there, but I do love the clean look when I don't need the receiver installed. When it is installed it's rock solid, no wiggle that I could get out of it.
@dcaf very cool and helpful description. Do you own? Or lease? Would you be worried about this sort of alteration affecting warranty at all? I'm looking into doing the same, but I lease, so it might be riskier (although probably worth it).
Nice work dcaf! really enjoy my stealth hitch
Originally Posted by joeindisguise
(Post 25480634)
Lease might be a little different since you have to cut a hole in the plastic bumper trim, assuming you don't have one of the bumper styles that already have the hole for a future hitch. |
Originally Posted by aclass
(Post 25480712)
While the OEM hitch is now possible on the 2021 Q5e, it seems to be very cost prohibitive if not installed before delivery. The hitch itself is about the same as the stealth hitch ($855 list, $650 with discounts) but the dealers quote about 6 hours to install which adds another $1000 to the project. Looking at the Q5e there seems to be no easy way to get to the holes in frame to screw the OEM hitch on.
While I would love to get the OEM hitch, the stealth hitch seems to be a very competitive alternative, especially since its only for a bike rack or storage bin. How happy are you after half a year now? Any issue with corrosion and getting the receiver in and out? |
Still very pleased with it. Forget it's back there really. I've only used it a couple of times for the bike rack this year since we've been limiting travel/trips, but works with no issue each time.
Note to those with 2020 Q5e's considering wiring, did some research and checking around in the car and the 2020 Q5e does NOT have the necessary pre-wiring to allow plug and play install of the Audi wiring harness. If you were to go with an aftermarket trailer hitch and against Audi's wishes you're looking at an after market wiring harness as well.
