ESC & TPMS error. Car will not go into gear?
Hope everyone had a great new year. My family and I were driving back home from Utah to California the other night and as we were driving down highway 15 the car made a thunk and threw two errors on the dash. One was "Electronic Stability Control" fault and a TPMS malfunction. After it threw the error it went into some kind of limp mode and wouldnt shift gears.
I decided to pull over and see if I could reset it by stopping and then re-starting the car. I restarted and both errors were still there but it would not go into gear, I was able to use the emergency park override but it would not change gears. At this point I was pulled off on ZZYZS road with my family so I had it towed back to Victorville. I had a buddy of mine drive up my Vag-Com and tried to clear all the codes but it still persists, anyone have any idea what might be the problem? Not sure if this is related but a few days earlier it had the TPMS malfunction and I just did the in car TPMS reset and it went away. Here's the logs I pulled: Monday,02,January,2023,23:42:16:13261 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: WA1VMAFE0DD010815 License Plate: STPNRZR Mileage: 160050km-99450mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FE-AU56 (4F0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55 56 5F 62 69 6C 6D 6F 72 VIN: WA1VMAFE0DD010815 Mileage: 160050km-99450miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb Part No SW: 4L2 910 401 A HW: 4L0 907 401 E Component: 3.0TDI FSA H21 0014 Revision: 54H21--- Serial number: CVN: 1B2B2502D45710C1755A21130E1FC39E Coding: 2A2A401C257600050000 Shop #: WSC 09355 004 1048576 ASAM Dataset: EV_ECM30TDI0114L2910401A 001015 ROD: EV_ECM30TDI0114L2910401A.rod VCID: 221EE361644CCDCBDD6-8076 VINID: 9D1066751595014500040201144663E20A 1 Fault Found: 4718 - No Communication with Transmission Control Module U0101 00 [039] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 160052 km Date: 2023.01.02 Time: 23:38:04 Engine RPM: 999.50 /min Normed load value: 42.4 % Vehicle speed: 0 km/h Coolant temperature: 68 °C Intake air temperature: 10 °C Ambient air pressure: 900 mbar Voltage terminal 30: 13.740 V Unlearning counter according OBD: 40 Limitation: accelerator pedal: 0.0 Nm CAN status - engine control module-Bits 0-7: 0 Cruise Control System (CCS): status-Bits 0-7: 247 CAN status - transmission control module-Bits 0-7: 0 CAN status - brake control module 1-Bits 0-7: 0 CAN status - brake control module 2-Bits 0-7: 0 selected gear-Bits 0-7: 0 Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0623729 Shop #: WSC 15315 004 1048576 VCID: 34321539C238537B3FA-8060 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:33:44 Freeze Frame: Count: 128 Count: 321 Count: 8195 Count: 44032 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ Component: KLIMA 4 ZONEN H15 0070 Revision: 00---031 Serial number: 00000000357226 Coding: 0302A036 Shop #: WSC 31414 790 00001 VCID: 2514F87D75E23AF3B84-8070 Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0046354925 Coding: 070000 Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0046327867 Coding: 070000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C Component: ILM Fahrer H31 0400 Revision: 00000000 Serial number: 4F0907279 Coding: 0139123 Shop #: WSC 31414 790 00001 VCID: 6E86C751EC9439AB09E-803A Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H18 0110 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150059 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb Part No SW: 4L0 919 475 A HW: 4H0 919 475 C Component: PARKHILFE 8K H07 0011 Revision: 11001001 Serial number: 55961300200310 Coding: 29011E Shop #: WSC 31414 790 00001 ASAM Dataset: EV_EPHVA18AU7160000 001001 ROD: EV_EPHVA18AU7160000.rod VCID: 34321539CEB8537B3FA-8060 1 Fault Found: 12648736 - Databus U1121 00 [009] - Missing Message [Getriebesteuergerät - mGetriebe_1 - kein Signal/keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Date: 2023.01.02 Time: 23:34:23 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4L0 910 561 A HW: 4L0 907 561 Component: ABSTANDSREGELUNGH07 0160 Revision: -------- Serial number: 00000000000000 Coding: 0031111 Shop #: WSC 31414 790 00001 VCID: 2708F27503EE28E38A8-8072 3 Faults Found: 01315 - Transmission Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:34:54 Freeze Frame: Temperature: 17.0°C Voltage: 12.03 V Bin. Bits: 01000 Hex Value: 0x044F Hex Value: 0x0054 Speed: -3.6 km/h Lateral Accel.: 0.00 m/s^2 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 2 Fault Frequency: 3 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:34:54 Freeze Frame: Temperature: 17.0°C Voltage: 12.03 V Bin. Bits: 01000 Hex Value: 0x0442 Hex Value: 0x0002 Speed: -3.6 km/h Lateral Accel.: 0.00 m/s^2 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 2 Fault Frequency: 3 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:34:54 Freeze Frame: Temperature: 17.0°C Voltage: 12.03 V Bin. Bits: 01000 Hex Value: 0x0444 Hex Value: 0x0006 Speed: -3.6 km/h Lateral Accel.: 0.00 m/s^2 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH44 0230 Revision: 08H44000 Serial number: 0038QD0C0L85 Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B000E451F060C836E0-807E Subsystem 1 - Part No: 4L0 959 339 C Component: BF-Gewichtsens. H05 0040 Subsystem 2 - Serial number: 6332QSME67281E5AS Subsystem 3 - Serial number: 6342QSME182704604 Subsystem 4 - Serial number: 6352QSME2B261272A Subsystem 5 - Serial number: 6362QSME2B274C7E. Subsystem 6 - Serial number: 63734SME1E26324E4 Subsystem 7 - Serial number: 63834SME43261678$ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 B HW: 4F0 953 549 E Component: J0527 0830 Revision: 00H08000 Serial number: 90026123110276 Coding: 0012152 Shop #: WSC 31414 790 00001 VCID: 280AF1490EF0279B832-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H03 0040 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb Part No SW: 4L0 920 985 G HW: 4L0 920 985 G Component: KOMBIINSTR. H35 0316 Revision: 00000000 Serial number: NGF22AJDD Coding: 8BDE64040D00CF05020205 Shop #: WSC 12345 123 61029 VCID: 382A2109D250B71B132-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb Part No SW: 4F0 907 468 S HW: 4F0 907 468 G Component: GW-BEM 5CAN-M H06 0058 Revision: MB700037 Serial number: 3700M12C128015 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3FD84A15F77E8023D28-806A Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 Serial number: 00000000004120816904 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:35:14 Freeze Frame: Bin. Bits: 10111 Voltage: 11.90 V Count: 7 Bin. Bits: 10011 Time: 25.40 s ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AD Component: KLIMABETAETIGUNGH06 0060 Revision: 00---011 Serial number: 00000030266670 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 688AB149CE70E79B432-803C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0064 Revision: AA000000 Serial number: 00000046314256 Coding: 00581B00000011110000 Shop #: WSC 31414 790 00001 VCID: 323E1321342C5D4B2D6-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH02 0050 Revision: 00H02000 Serial number: 6PZ 009 014-10 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2E0607512C1479AB49E-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H02 0050 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F05.12.1200H02000AMS16476˙ Subsystem 4 - Serial number: S16476˙ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0362 Revision: Serial number: 0000048563639 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 48CA51C9A2B0C79B632-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 K HW: 4L0 907 289 K Component: Komfortgeraet H12 0130 Revision: 0130 --- Serial number: 01891267090000 Coding: 3570077 Shop #: WSC 31414 790 00001 VCID: 382A2109DE50B71B132-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 223 J HW: 4L0 035 223 G Component: BOSE G3 Q7 H04 0160 Revision: CH004000 Serial number: 00000000010347 Coding: 030000 Shop #: WSC 31414 790 00001 VCID: 290CF44D19FA1E939CC-807C No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb Part No SW: 4F0 910 274 B HW: 4F0 907 274 Component: J793 RKA+ H04 0110 Revision: 00000519 Serial number: 00005190069220 Coding: 0758477 Shop #: WSC 31414 790 00001 VCID: 2310E66577D6C4C3D60-8076 2 Faults Found: 01316 - ABS Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 3 Fault Frequency: 3 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:35:27 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0001 Voltage: 12.10 V Temperature: 6.0°C (no units): 0.0 01315 - Transmission Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Time Indication: 0 Date: 2023.01.02 Time: 23:35:27 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0001 Voltage: 12.10 V Temperature: 6.0°C (no units): 0.0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H16 0100 Revision: Serial number: 00000000129723 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EE697911C34A92BB9E-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb Part No SW: 4F0 959 792 T HW: 8K0 959 792 M Component: TSG BF H12 0362 Revision: Serial number: 0000049027783 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 47C852F5AFAEC8E36A8-8012 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 B HW: 4L0 907 357 B Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000031 Shop #: WSC 31414 790 00001 VCID: 2B000E451F060C836E0-807E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H07 0004 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH07 0004 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 156LC0C7678861 Coding: 020007010000000000 Shop #: WSC 31414 790 00001 VCID: 2412E5797ED8C3FBAFA-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4L2 035 746 G HW: 4L2 035 746 A Component: H-BNT-NA H44 0901 Revision: -------- Serial number: 224AV0D7515870 Coding: 180200060004EBEF710003456F632003140000000100000000 Shop #: WSC 31414 790 00001 VCID: 323E1321342C5D4B2D6-8066 Subsystem 1 - Part No: 8R0 060 884 BA Component: NAR 2013 0703 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130L$0C2629358 Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C Component: E0380 Bedient H01 0060 Serial number: 00000002069836 Subsystem 4 - Part No: 8R0 060 961 E Component: CD-Database 4949 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HL H11 0362 Revision: Serial number: 0000048727611 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46D65FF1A8A4D1EB91E-8012 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb Part No SW: 4E0 907 383 J HW: 4E0 907 383 J Component: Anhaenger H12 0100 Revision: 2A001001 Serial number: 00000375154708 Coding: 0200000000000000 Shop #: WSC 12345 123 12345 VCID: 313C1C2D312A665354C-8064 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4L0 907 428 HW: 7P6 907 441 D Component: TopView H05 0293 Revision: 11001001 Serial number: 82330JF0068029 Coding: 020C010001000100010102000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_CamSysteCorneViewAUDI 004005 ROD: EV_CamSysteCorneViewAUDI.rod VCID: 6E86C751E01439AB09E-803A 1 Fault Found: 13701377 - Databus U1121 00 [009] - Missing Message [Funktionseinschränkung wegen fehlender Botschaft (Getriebe_1)] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 72 Mileage: 160052 km Date: 2023.01.02 Time: 23:35:44 Voltage terminal 30: 12.0 V Terminal 15 status: Terminal 15 on ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: 4L0-910-945.clb Part No SW: 4L0 910 945 HW: 4L0 827 851 E Component: ValeoHeckdeckel H57 0500 Revision: --H57001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6C82CD59DA88CBBB27A-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H57 0500 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD10.01.13--H57001001C0350˙ Subsystem 4 - Serial number: 1C0350˙ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H08 0080 Revision: AAH08080 Serial number: 129541802----- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 2616FF7104E431EBB1E-8072 Subsystem 1 - Part No: 4L0 910 591 A Component: J_245_EE16_SKB10H13 0220 Subsystem 2 - Part No: 4L0 910 591 A Component: J_394_EE16_SKB10H13 0220 Subsystem 3 - Part No: 4L0 910 591 A Component: J_392_EE16_SKB10H13 0220 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HR H11 0362 Revision: Serial number: 0000048727612 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46D65FF1A8A4D1EB91E-8012 No fault code found. End----------(Elapsed Time: 02:27, VBatt start/end: 12.3V/12.1V)----------- |
That's major bad juju; no reply from the TCU...comms are down completely. Perhaps you ran over something in the roadway (the big Thump noise), which impacted some wiring to the tranny and/or the wheel ABS sensors, which are tied into lots of modules on this car.
I'd get the car up in the air and look for damaged wiring, but the noise you heard could also relate to a mechanical failure in the driveline also; best see what you can see, if you DIY. If not a car-minded person/DIYer, best to get a pro to look it over. Since there is no comms from the TCU, it appears likely that is the root cause, or central to the issue. If you have a TDI that's still in extended warranty, the ECU & TCU, as well as tranny and engine block are covered items, and that's where I'd be towing it if there are no signs of a road hazard impact/wiring damaged beneath the car, etc., but only if it's in warranty. ;) |
Originally Posted by '10Q7TDI_Prestige'
(Post 25777611)
Yippee!!!! That'll sure help to turn that frown upside down. ;)
Best you get to know this forum, as there's a fairly consistent set of known issues with parasitic battery drains (from door handles), emissions systems known issues, high-pressure fuel pumps, and coolant/oil leak points on the TDI models. The TDI warranty covers a lot more than the majority of owners realize. Dealerships are infamous for denying valid warranty claims. You will want to pull your own warranty document by VIN # on the TDI settlement website, print a few copies or save to file, and get very familiar with that document. You will almost certainly get dealer 'denial of warranty claim' syndrome at some future point. Don't fret when it happens; just call Audi's corporate number for feedback/problem resolution. Do be careful at the dealer with the financial responsibility form and/or accepting diagnostic fees they will often try to apply when you are taking it in for warranty services. They can't charge you a 'diagnostic fee' on warranted items. Be sure to ask them for your free fill up on Adblue fluid while it's in the Audi shop too...that's part of the emissions settlement, and a decent perk. You'll likely be more interested in the loaner car program, but you can also get reimbursed for a rental if the dealer has no loan cars available, which is often overlooked. Best of health in the new year, |
