ESC & TPMS error. Car will not go into gear?
Hope everyone had a great new year. My family and I were driving back home from Utah to California the other night and as we were driving down highway 15 the car made a thunk and threw two errors on the dash. One was "Electronic Stability Control" fault and a TPMS malfunction. After it threw the error it went into some kind of limp mode and wouldnt shift gears.
I decided to pull over and see if I could reset it by stopping and then re-starting the car. I restarted and both errors were still there but it would not go into gear, I was able to use the emergency park override but it would not change gears. At this point I was pulled off on ZZYZS road with my family so I had it towed back to Victorville. I had a buddy of mine drive up my Vag-Com and tried to clear all the codes but it still persists, anyone have any idea what might be the problem? Not sure if this is related but a few days earlier it had the TPMS malfunction and I just did the in car TPMS reset and it went away.
Here's the logs I pulled:
Monday,02,January,2023,23:42:16:13261
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WA1VMAFE0DD010815 License Plate: STPNRZR
Mileage: 160050km-99450mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE0DD010815 Mileage: 160050km-99450miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H21 0014
Revision: 54H21--- Serial number: CVN: 1B2B2502D45710C1755A21130E1FC39E
Coding: 2A2A401C257600050000
Shop #: WSC 09355 004 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 221EE361644CCDCBDD6-8076
VINID: 9D1066751595014500040201144663E20A
1 Fault Found:
4718 - No Communication with Transmission Control Module
U0101 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 160052 km
Date: 2023.01.02
Time: 23:38:04
Engine RPM: 999.50 /min
Normed load value: 42.4 %
Vehicle speed: 0 km/h
Coolant temperature: 68 °C
Intake air temperature: 10 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 13.740 V
Unlearning counter according OBD: 40
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 247
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 0 0 0 1 1
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0623729
Shop #: WSC 15315 004 1048576
VCID: 34321539C238537B3FA-8060
1 Fault Found:
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:33:44
Freeze Frame:
Count: 128
Count: 321
Count: 8195
Count: 44032
Address 05: Acc/Start Auth.
Cannot be reached
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000357226
Coding: 0302A036
Shop #: WSC 31414 790 00001
VCID: 2514F87D75E23AF3B84-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0046354925
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0046327867
Coding: 070000
No fault code found.
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6E86C751EC9439AB09E-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961300200310
Coding: 29011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34321539CEB8537B3FA-8060
1 Fault Found:
12648736 - Databus
U1121 00 [009] - Missing Message
[Getriebesteuergerät - mGetriebe_1 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Date: 2023.01.02
Time: 23:34:23
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031111
VCID: 2708F27503EE28E38A8-8072
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x044F
Hex Value: 0x0054
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: -3.6 km/h
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x0444
Hex Value: 0x0006
Speed: -3.6 km/h
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0C0L85
Coding: 0014131
VCID: 2B000E451F060C836E0-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME67281E5AS
Subsystem 3 - Serial number: 6342QSME182704604
Subsystem 4 - Serial number: 6352QSME2B261272A
Subsystem 5 - Serial number: 6362QSME2B274C7E.
Subsystem 6 - Serial number: 63734SME1E26324E4
Subsystem 7 - Serial number: 63834SME43261678$
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026123110276
Coding: 0012152
VCID: 280AF1490EF0279B832-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGF22AJDD
Coding: 8BDE64040D00CF05020205
Shop #: WSC 12345 123 61029
VCID: 382A2109D250B71B132-806C
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M12C128015
Coding: 00C303
VCID: 3FD84A15F77E8023D28-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000004120816904
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:14
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 7
Bin. Bits: 10011
Time: 25.40 s
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030266670
Coding: 0000006
VCID: 688AB149CE70E79B432-803C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000046314256
Coding: 00581B00000011110000
VCID: 323E1321342C5D4B2D6-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E0607512C1479AB49E-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H02 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F05.12.1200H02000AMS16476ÿ
Subsystem 4 - Serial number: S16476ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000048563639
Coding: 011F57205E40440004
VCID: 48CA51C9A2B0C79B632-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01891267090000
Coding: 3570077
VCID: 382A2109DE50B71B132-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000010347
Coding: 030000
VCID: 290CF44D19FA1E939CC-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190069220
Coding: 0758477
VCID: 2310E66577D6C4C3D60-8076
2 Faults Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.10 V
Temperature: 6.0°C
(no units): 0.0
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.10 V
Temperature: 6.0°C
(no units): 0.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000129723
Coding: 0012001
VCID: 5EE697911C34A92BB9E-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000049027783
VCID: 47C852F5AFAEC8E36A8-8012
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000031
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156LC0C7678861
Coding: 020007010000000000
VCID: 2412E5797ED8C3FBAFA-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 G HW: 4L2 035 746 A
Component: H-BNT-NA H44 0901
Revision: -------- Serial number: 224AV0D7515870
Coding: 180200060004EBEF710003456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130L$0C2629358
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002069836
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000048727611
Coding: 010E57204040230004
VCID: 46D65FF1A8A4D1EB91E-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000375154708
Coding: 0200000000000000
Shop #: WSC 12345 123 12345
VCID: 313C1C2D312A665354C-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0068029
Coding: 020C010001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E86C751E01439AB09E-803A
1 Fault Found:
13701377 - Databus
[Funktionseinschränkung wegen fehlender Botschaft (Getriebe_1)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Date: 2023.01.02
Time: 23:35:44
Voltage terminal 30: 12.0 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C82CD59DA88CBBB27A-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD10.01.13--H57001001C0350ÿ
Subsystem 4 - Serial number: 1C0350ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 129541802-----
Coding: 0003595
VCID: 2616FF7104E431EBB1E-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H13 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H13 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H13 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000048727612
End----------(Elapsed Time: 02:27, VBatt start/end: 12.3V/12.1V)-----------
www.Ross-Tech.com
1 Fault Found:
U0101 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 160052 km
Date: 2023.01.02
Time: 23:38:04
Cannot be reached
Revision: 00H02001
Coding: 0623729
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:33:44
Freeze Frame:
Count: 128
Count: 321
Count: 8195
Count: 44032
Cannot be reached
Coding: 0302A036
Coding: 070000
Coding: 070000
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011E
1 Fault Found:
12648736 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Date: 2023.01.02
Time: 23:34:23
Coding: 0031111
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x044F
Hex Value: 0x0054
Speed: -3.6 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: -3.6 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:34:54
Freeze Frame:
Temperature: 17.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x0444
Hex Value: 0x0006
Speed: -3.6 km/h
Coding: 0014131
Coding: 0012152
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:14
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 7
Bin. Bits: 10011
Time: 25.40 s
Coding: 0000006
Coding: 0010001
Coding: 3570077
Coding: 030000
Coding: 0758477
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.10 V
Temperature: 6.0°C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Time Indication: 0
Date: 2023.01.02
Time: 23:35:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.10 V
Temperature: 6.0°C
(no units): 0.0
Coding: 0012001
Coding: 0000031
1 Fault Found:
13701377 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 160052 km
Date: 2023.01.02
Time: 23:35:44
Coding: 0003595
That's major bad juju; no reply from the TCU...comms are down completely. Perhaps you ran over something in the roadway (the big Thump noise), which impacted some wiring to the tranny and/or the wheel ABS sensors, which are tied into lots of modules on this car.
I'd get the car up in the air and look for damaged wiring, but the noise you heard could also relate to a mechanical failure in the driveline also; best see what you can see, if you DIY. If not a car-minded person/DIYer, best to get a pro to look it over. Since there is no comms from the TCU, it appears likely that is the root cause, or central to the issue.
If you have a TDI that's still in extended warranty, the ECU & TCU, as well as tranny and engine block are covered items, and that's where I'd be towing it if there are no signs of a road hazard impact/wiring damaged beneath the car, etc., but only if it's in warranty.
-Wes- (01-06-2023)
Yippee!!!! That'll sure help to turn that frown upside down.
Best you get to know this forum, as there's a fairly consistent set of known issues with parasitic battery drains (from door handles), emissions systems known issues, high-pressure fuel pumps, and coolant/oil leak points on the TDI models. The TDI warranty covers a lot more than the majority of owners realize. Dealerships are infamous for denying valid warranty claims.
You will want to pull your own warranty document by VIN # on the TDI settlement website, print a few copies or save to file, and get very familiar with that document. You will almost certainly get dealer 'denial of warranty claim' syndrome at some future point. Don't fret when it happens; just call Audi's corporate number for feedback/problem resolution.
Do be careful at the dealer with the financial responsibility form and/or accepting diagnostic fees they will often try to apply when you are taking it in for warranty services. They can't charge you a 'diagnostic fee' on warranted items. Be sure to ask them for your free fill up on Adblue fluid while it's in the Audi shop too...that's part of the emissions settlement, and a decent perk. You'll likely be more interested in the loaner car program, but you can also get reimbursed for a rental if the dealer has no loan cars available, which is often overlooked.
Best of health in the new year,
thorium
Q7 MK 1 Discussion
21
04-10-2024 03:02 AM
