Metallic Rattle Sound When Cold
Our 7 has develped a metallic rattle sound at idle coming from under the car when cold which mostly dissapates at FOT...anyone else?
No but I’ve had this on another car. Part of the exhaust shielding had loosened and rattled when cold. As it heated up and the metal expanded it went away. |
Can you post an audio clip? |
Originally Posted by KevinGary
(Post 25283969)
Originally Posted by Corgiman
(Post 25283973)
Don’t have the car any more but it was a loose metallic rattle. They replaced part of the exhaust and it went away. |
(Post 25283858)
Thanks for the replies, it could very well be a heat shield but to clarify, it sounds more like a metallic ticking. II'll try to make a decent recrding but the regular engin/fan noise seems to drown it out.
Originally Posted by RJC 1
(Post 25284427)
same here but I have the 2.0TFSI engine |
Originally Posted by whyman
(Post 25285010)
Ok more info, I tracked down the noise to the rear of the vehicle and it occurs after I rev it and as the revs drops it almost sounds like a rapid ticking of an old school typewriter, must be somehting in the exhaust or in a muffler. Sound does not go away when at FOT. tried to make another recording but the background noise from the engine drowned it out too much. Will try agin.
