P05A0 Check Engine Light 2017 Q7
Hi all, has any of you had a CEL for P05A0?
This what i found..
P05A0 Active Grille Air Shutter “A” Stuck On P05A1 Active Grille Air Shutter “A” Position Sensor Minimum/Maximum Stop Performance P05A2 Active Grille Air Shutter “A” Control Circuit/Open there was a technical Service Bulletin for it.. https://static.nhtsa.gov/odi/tsbs/20...44971-9999.pdf |
Yes. Do your research. Claim it under FEW. You shouldn’t pay anything. I’m going to save another person ~$1000
https://www.audiworld.com/forums/q7-...ction-2956932/ |
Got the same P05A0 “Active Grille Air Shutter “A” Stuck On” error code yesterday. Cleared it with my Obdeleven and it came back on 5 minutes later. It also caused the start/stop function unavailable error code as well. Took it to the dealer and brought the above TSB with me. They checked the software and determined it was not software related and required the shutter motor to be replaced. Based on my conversation with the SA and Tech because I am tuned they will be unable to file the federal emission warranty since it will be required for my car to be hooked up to the Audi Mothership and that alone will TD1 me. Cost of replacing the shutter motor is $1900 before taxes and shop equipment. Indy shop don’t have any appointments in the near term.
Originally Posted by Ktran350
(Post 25578091)
Just an update. Part cost was $80, Labor was $1800 ($178ish per hour) for 10.5 hours of work. Took the car home last night and half way home the car threw the same warning again. Took it back this morning 🤞
(Post 25579652)
Update II: The tech messed up the basic adaptation coding. They cleared the errors, recoded the module and test drove it. Everything is working fine now.
I'm fighting with my dealer about it today, and they wont budge
I might be eating this cost unless someone educate the Audi South Orlando dealership. |
Originally Posted by fdevilleres17
(Post 25711563)
I might be eating this cost unless someone educate the Audi South Orlando dealership. Here in MA there is an emissions inspection where the car is plugged into a computer and codes are read. if the car throws a CEL/MIL, the car will immediately fail the inspection process. because of this dealers are required to fix any issue that throws a CEL on a car that gets MA state (emissions) inspection during it's 8yr/80k E1E (federal emissions) warranty period. does Georgia have a vehicle inspection requirement? maybe a phone call and road trip might be worth it if the dealership in FL isn't cooperating. best of luck. |
