Blue Tooth & RS6
Has anyone looking into what it would take to "add" bluetooth compatibility to the existing hands free system in the RS6? I know there are after market systems to install but I'd like to use the existing v60 integrated system if I can. I was going to ask my dealer but I wanted to see if anyone had done that first.
Re: That v60 integrated system will only work w/ audis v60 phone so my dealership tells me or
I would love my v60 phone to work in it if there is a way ?
I put in a Motorola HF850 bluetooth kit...
pretty simple, all you need are radio removal keys and some eletrical connectors. GO to the tech section and see the Integrated Motorola handsfree kit install that I wroet up. Same thing for the bluetooth, only no phone cradle is needed. Everything else is the same.
Here is my setup, which mutes the radio when a call comes in or is placed. Sound comes from the B-pillar speaker, but if you have no phone option in the car, it will default to the lower speaker in the driver's door. ...sorry for the dusty dash... <img src="http://img.photobucket.com/albums/v739/hliu55/DSC02008.jpg"> Here is a link to my tech writeup for my previous handsfree kit install:<ul><li><a href="https://www.audiworld.com/tech/elec95.shtml">Tech article</a></li></ul> |
The Parrot 3100 is a great kit
I've installed a bunch of these in the 04 and 05 A8L's....and you could get a new phone cradle for your new phone to use the external antenna function and charge function, but you would have to have it modified.
<img src="http://www.audipages.com/upgrades/handsfreed391.JPG"> |
Re: Blue Tooth & RS6
<center><img src="http://pictureposter.audiworld.com/52778/_mg_0069.jpg"></center><p>Hey I already instaled tha OEM Blue Tooth
made by Audi Everythings is working fine I tested with Motorola Razor and Nokia Phones! |
Re: I put in a Motorola HF850 bluetooth kit...
Did you upgrade from the original wired Motorola kit to the HF850? Are the plugs (power, speaker, mic) the same so that I can just swap out the control box?
Thanks! |
