Braking Problems
Hi, I recently started having problems with my ABS Braking. When I brake, it feels like the ABS is going off and the pedal is mushy. However, at some point the ABS and ESP tractional control lights illuminate on the dash and the brakes start working again. Albiet, still kind of mushy.
I did some searching, but didn't see anything identical to this issue. Please help! |
Originally Posted by laxman1100
(Post 24115138)
Originally Posted by Reggie
(Post 24115144)
How many miles do you have on the pads? Most people started seeing their pads go as early as 15K miles depending on how aggressive of a driver they are. Your symptoms seem to indicate you have a issue with your master cylinder or have air in the system.
I've been reading about ABS sensors going bad, would that effect ESP? |
(Post 24115154)
The pads look fine, but would it just all of a sudden start acting up like this?
It ended up being the ABS sensor. My shop also bled the brakes and braking feels solid.
Thanks for updating! More people should come back to their threads to update.
mushy
(Post 24119327)
