RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Braking Problems
Old Mar 10, 2011 | 06:59 AM
laxman1100's Avatar
Default Braking Problems
Hi, I recently started having problems with my ABS Braking. When I brake, it feels like the ABS is going off and the pedal is mushy. However, at some point the ABS and ESP tractional control lights illuminate on the dash and the brakes start working again. Albiet, still kind of mushy.
I did some searching, but didn't see anything identical to this issue. Please help!
Old Mar 10, 2011 | 07:13 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
How many miles do you have on the pads? Most people started seeing their pads go as early as 15K miles depending on how aggressive of a driver they are. Your symptoms seem to indicate you have a issue with your master cylinder or have air in the system.
Old Mar 10, 2011 | 07:35 AM
laxman1100's Avatar
The pads look fine, but would it just all of a sudden start acting up like this?
I've been reading about ABS sensors going bad, would that effect ESP?
Old Mar 10, 2011 | 08:43 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
I doubt that would cause a mushy feel in the pedal - That is why I suspect there is a issue with your Master/slave cylinders or that you have air in your system.
Old Mar 20, 2011 | 05:32 PM
laxman1100's Avatar
It ended up being the ABS sensor. My shop also bled the brakes and braking feels solid.
Old Apr 7, 2011 | 08:10 PM
Ragdoll's Avatar
Thanks for updating! More people should come back to their threads to update.
Old Apr 7, 2011 | 11:24 PM
s4master1's Avatar
Default mushy
Agree with Reggie, no abs speed sensor failure would cause this symptom, at one point the brake fluid must have reach it's boiling point and needs to be flushed out completely, or even the master cylinder has already been damaged.
Jim Graham
Nov 29, 2003 03:45 PM
Silver Coupe
May 1, 2003 11:42 AM
darkhelmet
Audi 100 / A6 (C4 Platform)
Mar 1, 2003 03:21 PM
Mitch S
Apr 4, 2000 07:23 AM
Liz
Dec 21, 1999 07:10 AM
