Couple Brake Questions
First off, I did read through the past year on post for pads. But wanted to make sure nothing has changed.
1. My brakes squeal and it drives me crazy. I feel like I am driving a ugo when it squeaks in front of everyone. Is this normal? Audi said pads and rotors are fine. 2. I read the Zechausen Post on Bedding in your brakes. Can I do that on brakes already in use like my situation? 3. If I do need new pads I want something with low brake dust and no squeaking, more for spirited driving than track time. Is the Centric Posi Quiet Semi-Metallic pads the way to go? I know this might sound crazy but what about Monroe Premium Brake Ceramics? Thanks, |
If your OEM pads squeal - then you have a issue.
Centric Posi Quiet Semi-Metallic pads are great for removing dust as a issue but you need to figure out what is wrong with yours running the OEM pads. |
Squealing usually can means that you may need to add some anti squeal grease or take a look at the anti squeal brackets in the outside of the pads. You may have to take the pads out and re apply the anti squeal grease and maybe replace the brackets. Also use brake cleaner to clear all brake dust on the calipers and pistons.
On the bedding thing yes you can re bed your pads. I am not sure how good they would do but it is worth a try and it is free. Most likely your brakes are fine in regards of stopping power. By the way did you change the pads? How long you had them/how many miles? Did you have brake work done? A few years back I put I had a very "sqeally" Volvo 850 and the noise would not go away. I had the pads out put grease replaced the brackets. I finally realized that the problem was the aftermarket pads. The moment I wen back to the stock dusty stock ones the squeal went away. I have the Centric Posi Quiet Semi-Metallic pads and had no problem with noise or squealing. Cheers and good luck Nick |
I just installed the Centric Posi Quiet Semi-Metallic pads on Sunday and put about 150 miles on them since then. So far all is well. I don't believe you have to bed them, but I did a couple of 60-10mph stops anyway. No squeals or weird pedal vibrations. I had 36k on the original pads and I'm still using the original rotors.
Cool. I changed mine since all the comments people were making about the OEM pads having rivets and scoring a very expensive rotor.
I as well did only a few medium/hard stops to bed in the rotor and I have had no issues with the pads. Another added benefit is the next to no dusting from these pads. Cheers Nick |
Originally Posted by titsataki
(Post 23837762)
Very pleased with my Centrics. I get less dust in one week than in one day on stock pads. Slightly softer pedal to start with, should be better when the surfaces are matched, I had a small amount of grooving from the rivets on the stock pads :mad:
Originally Posted by GotRS?
(Post 23838541)
I need some new tires in about a month so I think I will replace the pads with the Centrics at that time regardless of the pads condition. Can I use the factory tires in the winter months, Pirelli PZero? The car will hardly be driven in snow if we get any. |
I just ordered a new set of rubber this morning from Tire Rack. Pirrelli PZero Rosso for $190 each. OE. Seems like a good price to me, I thought I was going to be spending over $300 a tire. Once I have those on and broken in I would like to go for a top speed run to see how the car handles with the KW’s.
I also ordered a set of F & R pads from Zeckhausen.com, they are great to work with and I look forward to what I hope is minimal brake dust. |
it seems that they have a special on them. they are OEM replacement tire for our cars...
They seem to be strictly summer max performance tires thus I would not drive them on snowy days. Not sure how bad does it get where you live but I am in CT and I have a winter setup for all of our cars. The RS is more like a weekend runner but when I bought it the old owner had a set of winter wheels/tires that I bought off him for a good price. Not even sure I will drive the car in the snow but I guess I have the option. I am at 16.5k miles on my car and I know that the tires will be due by next spring and I am tempted to get a set but work does not look look good(layoffs) so spending ~ $800 is not an option. Cheers Nick |
