Headlight removal
Does the bumper cover need to come off to remove the headlight assy?
TIA |
Are you removing the amber?
Please let me know how that works out if thats the case...I notice you're in Irvine as well...
"Eddie Man" on the B7 S4 board came up w/ a way to remove
the housings w/o fully dropping the bumper. I would assume the RS4 would be similar in its bumper mounting points.
crowbar?
Jersey?
C4.
He cranked the wheel on the side he was working on so he could access the wheel liner fasteners, and then just loosed a few of the bumper screws as opposed to all of them.
Yep, clear corner mod.
I'm not far from the Tustin Market place.
Will u be participating in the GMG track day? |
Re: "Eddie Man" on the B7 S4 board came up w/ a way to remove
found his write up. I'll give it a try.
I'm near Fletcher Jones...my E30 M3 is getting the 2.5 upgrade
so next time. Are you doing this this yourself? What's involved?
These are sealed correct? so you heat them, seperate and what the amber piece comes out? do you replace it with a clear? Thanks Funny, we live near each other and probably plenty of other RS4s and I have yet to see another. |
Re: I'm near Fletcher Jones...my E30 M3 is getting the 2.5 upgrade
Gonna try the DIY using this write -up as a reference.
Doesn't look to complicated. You don't replace the lens, the bulb is replaced with a silvervision bulb. The amber lens is removed.<ul><li><a href="https://forums.audiworld.com/s4b7/msgs/49114.phtml">https://forums.audiworld.com/s4b7/msgs/49114.phtml</a</li></ul> |
