oem ride height question...
<center><img src="http://pictureposter.audiworld.com/154625/picture_007_rev.jpg"></center><p>
searched, no luck...any help would be appreciated just measured mine...floor to fender lip @ wheel center...note the pic was taken on a sloped surface...the rear is lower by 6" or so... so the front appears a bit higher and the rear lower due to wt transfer... ~3/8 tank of gas avg F & R 26-5/8" very consistent low ~26 8/16 high ~26 11/16 tires are ~26" OD so the gap is 5/8" even all around... I did this because my car seems lower than photos I've seen.. yes, I checked the shocks, no leaks and no weird noises/handling when doing a sharp/fast downhill turn or over bumps... |
26 5/8 F and 25 7/8 rear.........
That is with a full tank of gas and my 46lb sub/box/amp in the trunk
What kinda camera are you using?
Re: 26 5/8 F and 25 7/8 rear.........
thnx...mine would seen normal then...
Re: What kinda camera are you using?
it's got a lens and some electronics & stuff
it takes reflected photons and converts them to a digital image which can be manipulated/conveyed as a 'file' or finite set of bytes... it can also be made to excite an LCD to emit photons in a pattern similar to the original excitation source...but distorted ;) |
I would throw it in the garbage and get a new one : P
