oem ride height question...
<center><img src="http://pictureposter.audiworld.com/154625/picture_007_rev.jpg"></center><p>
searched, no luck...any help would be appreciated
just measured mine...floor to fender lip @ wheel center...note the pic was taken on a sloped surface...the rear is lower by 6" or so...
so the front appears a bit higher and the rear lower due to wt transfer...
~3/8 tank of gas
avg F & R 26-5/8"
very consistent
low ~26 8/16
high ~26 11/16
tires are ~26" OD so the gap is 5/8" even all around...
I did this because my car seems lower than photos I've seen..
yes, I checked the shocks, no leaks and no weird noises/handling when doing a sharp/fast downhill turn or over bumps...
~3/8 tank of gas
avg F & R 26-5/8"
very consistent
low ~26 8/16
high ~26 11/16
Re: What kinda camera are you using?
it's got a lens and some electronics & stuff
it takes reflected photons and converts them to a digital image which can be manipulated/conveyed as a 'file' or finite set of bytes...
it can also be made to excite an LCD to emit photons in a pattern similar to the original excitation source...but distorted
Lago Blue
18
03-03-2023 08:33 AM
Lago Blue
10
09-04-2008 05:55 AM
JVond
05-13-2003 09:12 PM
