Diagnosis of strange problem.
Hello, I am experiencing a strange problem.
Say I accelerate in WOP 1st, 2nd, 3d @ 19-21 Lbs. boost. The boost will hold steady and smooth until high 3d gear and sometimes even in 4th the car looses power and makes this noise as if it just released all pressure with some weird oscillation sound. At that moment, the cars "Check engine light" starts to blink. It blinks around 10-15 times and then stays "on" solid. The car will drive fine again and I can get full power but will do the same thing if boost pressure loads again. I replaced the BPVs yesterday. My cars spec: "X" chip K04 Turbos Dual Exhaust K&N Filter Any help would be appreciated. |
is the chip supposed run that high of boost?
fuel cut? then it blows off? dunno.
Good question....don't know but it usually spikes to 21 and hangs at 19
This is what I imagine too but not too sure.
do you have a pocket logger?
pocket logger?????
palm pilot that hooks into your obdII port.
you can user it to log.
no, I can log with Audi Tool & Laptop
ok log with that and see what happens when it cuts off.
