Fault Code Help - Codes inside
I was driving the other day, and during a 2nd gear pull the power got real choppy so I backed off, but no CEL etc...vagged the car and pulled these codes. Since then it's been fine. Any suggestions on what to check where these may be all related? When I had a bad coilpack, I had a blinking CEL. When I had a bad MAF, I got a signal too low code iirc. Thanks.
Address 01 ------------------------------------------------------- Controller: 8D0 907 551 A Component: 2.7l V6/5VT G 0003 Coding: 06611 Shop #: WSC 88811 7 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16690 - Cylinder 6 Misfire Detected P0306 - 35-10 - - - Intermittent 16689 - Cylinder 5 Misfire Detected P0305 - 35-10 - - - Intermittent 16685 - Cylinder 1 Misfire Detected P0301 - 35-10 - - - Intermittent 16687 - Cylinder 3 Misfire Detected P0303 - 35-10 - - - Intermittent 16686 - Cylinder 2 Misfire Detected P0302 - 35-10 - - - Intermittent 17658 - Fuel Level too Low P1250 - 35-00 - - Readiness: 0000 0000 |
yer out of gas!
That's what it looks like! I had 3/4 of a tank though...so what fuel component is malfunctioning?
Stage 2 - stock injectors, FPR, replaced fuel filter about a year ago - and it's been fine since...
Could be spark too, ignitors on the airbox? The low fuel code could have been from long ago.
True about the low fuel code for sure - could be those ignitors
Which iirc go for $150 a piece OUCH! It was a real hot day when the stumbling happened - about 95 degrees.
Yeah it might have just been a fluke. If it happens again let me know we can trade ignitors for a
while. I'm in MA too.
Sweet - thanks a lot for the offer
I'll let you know if the problem comes back.
