How do you recode your instrument cluster to have auto up windows with the remote?
And also how can I change what mpg my cluster says my car is getting? There is something in VAG com that allows you to modify it isn't there? I already STFA...
Thanks |
you add 64 to the number that you can change.
Isn't there a list of modifications you can make or something? And you go into...
instruments on VAG and then recode? Software code? which number do I change? Thanks
Cluster has nothing to do with windows,and you want your cluster to indicate a false mpg?
it is in the central convenience menu. It is all on Ross-Tech's website.
Read this all info inside.. ==>
35-Central Locks: -- KWP-1281
VAG-COM Works fine (note: pre-'97 A4's may not have this module). Recode locking options [Select] [35 - Cent. Locks] [Recode - 07] Enter the coding below [Do It!] Write down the existing coding for future reference. A4 pre-1998 with Delta radio and anti-theft system Standard Coding: 03468 A4 pre-1998 with Delta radio, anti-theft system and keyless entry Standard Coding: 12172 A4 1998+ with Concert/Symphony radio and anti-theft system Standard Coding: 03340 S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry Standard Coding: 16140 Add the following options to your coding number: +64 Windows up, sunroof close, and windows down with remote. -04 One touch unlock of all 4 doors and trunk -1024 Remove horn honk when arming +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed) So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then: add 03340+64+32= 03436 |
I don't understand either.
Right now it indicates a false mpg because of the stage 3 fueling. I seem...
to remember someone mentioning the ability to change the mpg reading by up to 20% or something. That would help. And I also remember people talking about being able to use the VAG com to enable your remote to put up and down the windows. There is a list of numbers that you add or subtract to the base number to make these remote mods....I just don't know what the numbers are or where to make the changes.
Thank you sir that was the list I was referring to. Now, anybody know how to change mpg readout?
You do know you have buttons 'up and down' on the windshield wiper stalk right?
