I just read a Tech article "Adjusting Xenon's after Lowering" and now I have
a question. If I put on a coilover suspension and lower the car, say 1.5" all around, do I have to worry about adjusting my headlights?
possibility. the susp will settle and you may have to readjust.
a few degrees will make a huge difference 1/8mile down the road.
Yes, but just do it yourself with the white adjustments supplied.
I'm considering never to post on AW again.
I have variable height HID's.
With my own controller.
If it lowers evenly, you'll be fine. Many suspensions don't.
My Intrax setup lowered the rear a bit more than the front, and I had to adjust mine.
I did them in a parking lot pointing at the side of a building, tweaked them until I thought it was a decent light spread, and then lowered them over time until I didn't get flashed very often. They're still probably higher than they should be, but I can see well, and I don't really give a crap about anyone else anyway. ;-) |
Thanks. Now, it's a VAG adjustment - no mech. adj.?
huh? ^^^
Are you having a hard day? :)
