Pipes-A-La-Piggie: DIYer at Luch
I just thought i would do a post and add a few comments on this common mod.
1st- These tools should be added to the list of tools needed. BFH and thick bar , also step downs. <img src="http://pictureposter.audiworld.com/99442/104_2250.jpg"> 2nd- Instead of using a huge drill, use a step down for the hole when relocating the O2 bung. <img src="http://pictureposter.audiworld.com/99442/104_2248.jpg"> 3rd- BFH and bar are used to push out cat-cell out the back side where the cut was made. You can see the removed cells here, I drilled few a holes just to release some pressure. For the most part they came out whole. I took the time to clean up the insides as well. <img src="http://pictureposter.audiworld.com/99442/104_2247.jpg"> Other than that, the write up was helpfull, it's pretty self explanitory anyways. Finished pipes going in tonight or tomorrow. <img src="http://pictureposter.audiworld.com/99442/104_2249.jpg"> |
Nice work, all on your lunch hour! Impressive. Now put those bitches on!
Nice, how did you get them precat materials to come out in such nice big chunks?
I am still waiting for someone to do that to some of the RS4 DPs that were imported to the US
I still got one set left ;-)
just get the non foulers to keep things easy (no splicing extra wire in) and clean-ER ;)
i can do it .
I had read somewhere about problems, this was that complicated anyway.
Read again, I hammered them out when I had the pipes open.
oops wasn't
