Pipes-A-La-Piggie: DIYer at Luch
I just thought i would do a post and add a few comments on this common mod.
1st- These tools should be added to the list of tools needed. BFH and thick bar , also step downs.
<img src="http://pictureposter.audiworld.com/99442/104_2250.jpg">
2nd- Instead of using a huge drill, use a step down for the hole when relocating the O2 bung.
<img src="http://pictureposter.audiworld.com/99442/104_2248.jpg">
3rd- BFH and bar are used to push out cat-cell out the back side where the cut was made. You can see the removed cells here, I drilled few a holes just to release some pressure. For the most part they came out whole. I took the time to clean up the insides as well.
<img src="http://pictureposter.audiworld.com/99442/104_2247.jpg">
Other than that, the write up was helpfull, it's pretty self explanitory anyways.
Finished pipes going in tonight or tomorrow.
<img src="http://pictureposter.audiworld.com/99442/104_2249.jpg">
