Reliability of Triptronic vs Reliability of Manual
Guys,
I did search and read about the various Manual Vs Auto Threads. Somehow there isn't much material addressing the reliability of the TripTronic transmission vs the Manual Transmission when buying a used car so I thought I would post on here. There are quite a few 100k+ mile B5 S4s on sale nowadays and I was wondering if someone shopping for a used S4 would have a reason to consider a manual transmission instead of a triptronic or vice-versa. From my reading, here is what I found. Triptronic - Failure mode can be two components : Transmission/Torque converter. Cons 1. Higher rebuild or replacement cost. ~4k 2. Not as capable as the manual in handling a modded engine (350-400hp) Pros 1. Potentially has lead an easier life than a car with a manual trans. 2. Perhaps better for a commuter road car. Manual Transmission - Failure mode can be two components : Clutch/Transmission. Cons 1. Potentially Higher hoonage wear and tear. (Manual cars are driven harder) 2. Perhaps better for a track oriented car. Pros 1. Potentially lower replacement cost for clutch or gear box. 2. Capable of handling higher power limits. Is there anything more that folks can think off? Any comments would be helpful. Thanks |
I think used transmissions go for 1-1.5k for both these days.
If you want to go fast and enjoy driving get a manual. If you have a wet hole in your crotch get a chicktronic.
Originally Posted by RolledMySTi
(Post 23799090)
Well don, looks like you picked up the wrong one after all...
Originally Posted by complacentsee
(Post 23799121)
Originally Posted by donromani
(Post 23799112)
Oh snap!
(Post 23799074)
(Post 23799162)
Making fun of chicktronics is a hobby of mine. Plus you, complacentsee and I seem to be the only people on this forum so I had to take some shots :)
...too bad Comp has the TIP, but I guess he needs both hands free to apply his make-up on the morning drive to work. :D |
Naw, I need it free to masturbate passionatly while on my way to work. Es ist wunderbar!
