So, here are my codes..
Control Module Part Number:-------------------------------------
Component and/or Version: 2.7l V6/5VT G03 0003 Software Coding: 06611 Work Shop Code: WSC 06325 8 Faults Found :( 17964 - Charge Pressure Control: Negative Deviation P1556 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16685 - Cylinder #1 - Misfire Detected P0301 - 35-10 - 16690 - Cylinder #6 - Misfire Detected P0306 - 35-10 - 16686 - Cylinder #2 Misfire Detected P0302 - 35-10 - - - Intermittent 16689 - Cylinder #5 - Misfire Detected P0305 - 35-10 - 16688 - Cylinder #4 - Misfire Detected P0304 - 35-10 - 18010 - Power Supply (B+) Terminal 30 - Low Voltage P1602 - 35-10 Intermittent |
here is my code
Im getting a "unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING " error in the next php call after this one:
<?php switch ($row_detail2page['pageid']) { case 1: echo "<li><a href=\"index.php\">{$row_detail2page['pagetitle']}</a></li>"; break; case 47: echo "<li><a href=\"contact.php\">{$row_detail2page['pagetitle']}</a></li>"; break; case 48: echo "<li><a href=\"location.php\">{$row_detail2page['pagetitle']}</a></li>"; break; default: echo "<li><a href=\"content-page-{$row_detail2page['pageid']}-{$row_detail2page['pagetitle']}.html\">{$row_detail2page['pagetitle']}</a></li>; } ?> |
FVCKTHAWHAT?
if I saw 'ORA' in there I would say you are getting some Oracle message
I thought this was a post-ur-code thread...
Here is the line that is causing the error
<?php // Show IF Menu Type is 3 if (@$row_master1menu['menutype'] == 3) { ?> throws this: Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING Any ideas? |
nah...its all php/mysql
try closing your quotes after </a></li>
vim (or any real editor) would show you the quote isn't closed.
ever pressure tested? Maf?
winnar!
thanks nye
also, consider using a templating library (like phpsmarty) to separate code from content
