So, here are my codes..
Control Module Part Number:-------------------------------------
Component and/or Version: 2.7l V6/5VT G03 0003
Software Coding: 06611
Work Shop Code: WSC 06325
8 Faults Found
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder #1 - Misfire Detected
P0301 - 35-10 -
16690 - Cylinder #6 - Misfire Detected
P0306 - 35-10 -
16686 - Cylinder #2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16689 - Cylinder #5 - Misfire Detected
P0305 - 35-10 -
16688 - Cylinder #4 - Misfire Detected
P0304 - 35-10 -
18010 - Power Supply (B+) Terminal 30 - Low Voltage
P1602 - 35-10 Intermittent
8 Faults Found
P0301 - 35-10 -
P0306 - 35-10 -
P0305 - 35-10 -
P0304 - 35-10 -
here is my code
Im getting a "unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING " error in the next php call after this one:
<?php
switch ($row_detail2page['pageid'])
case 1:
echo "<li><a href=\"index.php\">{$row_detail2page['pagetitle']}</a></li>";
break;
case 47:
echo "<li><a href=\"contact.php\">{$row_detail2page['pagetitle']}</a></li>";
break;
case 48:
echo "<li><a href=\"location.php\">{$row_detail2page['pagetitle']}</a></li>";
break;
default:
echo "<li><a href=\"content-page-{$row_detail2page['pageid']}-{$row_detail2page['pagetitle']}.html\">{$row_detail2page['pagetitle']}</a></li>;
<?php
case 1:
break;
case 47:
break;
case 48:
break;
default:
I thought this was a post-ur-code thread...
Here is the line that is causing the error
<?php
// Show IF Menu Type is 3
if (@$row_master1menu['menutype'] == 3) {
throws this: Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING
Any ideas?
<?php
Any ideas?
