View Full Version : Q3 Discussion
- USB Stick with FLAC files
- Lane Centering, Adaptive Cruise Assist. Disappeared one day and never came back.
- New alignment readings...can they be better?
- Considering buying a q3 salvage for repair.
- No jack in q3?
- Q3 Quattro hatch lights stopped working
- 20" TIRES?
- Oil leak from dipstick tube
- Audi Q3 Sportback delivery delays
- Audi Dealer touch up paint stick off
- Fuel Gauge / Sensor Not Working Properly
- BROCHURE?
- Road not showing on map (EU)
- Q2 2019 Rear Undertray help
- Changing / Skipping tracks on the Q3
- Sunroof
- Intercooler upgrade//chasing power
- Q3 - Program Physical Garage Door button / MMI Homelink
- 2022 Q3 Wheel Question
- 2022 Q3 Steering wheel
- Key remote battery died
- 2022 Audi Q3 Front and Back Plates
- RSQ3 Rear feature question
- 22 Q3 MMI issues
- "Inspection in 29 days" notice. What gives ??
- 2022 Q3 delivery delays?
- Key lock in
- Better gas milage!!
- UK: Need help with a few things
- Recommended shocks for more comfortable ride, 8U
- Audi q3 water leak at headliner light
- Default audio source when starting car
- Rear Seat Removal / Belt Buckle Socket Replacement
- Oil Level?
- UK: Bluetooth
- IL: Q3 2022 40TFSI | High sounds during phone call
- Newbie - Racechip Question
- Audi Care or just pay and service?
- 2022 Audi Q3 Whistle Noise from driver side mirror
- 2022 Q3 under engine splash guard
- Q3 struck by chip shortages
- TPMS - does it show the actual pressure?
- 2018 audi Q3 driver side axle removal
- Tilted steering wheel?
- Door ajar warning?
- So AT&T 3G doesn't work anymore
- Rhythmic humming sounds at low speeds
- GR: Q3 TFSIe Lead Time
- Reversing camera not engaging when I choose reverse gear in my 2012 Q3
- IL: Q3 hard start after parking a while 😟
- 2020 Q3 oil capacity
- 2021 q3 front suspension sqeak
- Q3 Heated Seats
- 2018 q3 multiple warning lights came on during startup.
- Please Help! 2021 Q3 - S-line premium plus
- Anyway to install side assist?
- Buy it again?
- Trailer Hitch
- Chrome trim on grill colour code help
- 2022 Q3 Rearview Camera Software Recall
- New Q3 order questions
- Black panel on both sides of the navigation
- Hit Curb Rear Wheel Control Arm Bent Audi Q3
- Navi
- Q3 Use of Seat Cushions
- New Q3 Rubber Mat Original
- Apple Carplay remote start?
- A/C blowing warm air
- UK: RS Q3 Spec Change - Superconductor shortage
- Pandemic Parts Bin Car?
- For free: Disable auto start/stop
- Keyless lock/unlock handle touch issues? 2020 Q3
- 2019 Leaking Oil and Coolant
- 2020 Q3 Problems Starting in Cold Weather (below -30C)
- Gateway control recall
- 2021 Q3 - Crooked Steering Wheel
- New key shell
- Win a 2022 Audi Q3!
- 2015 Q3 Nav and voice
- Reprogram Keys After Battery Change?
- 2014 q5 tdi trailer hitch
- problem for wireless carplay Q3 Sportpack
- Audi Q3 Front Grill replacement
- ZA: Mr?
- My Audi Q3 S line Build
- 2021 Q3 AM static
- Trunk not closing
- Clicking noise from shifter
- Is it true with 2022 AudiQ3 Premium 45 S line?
- RADIO SEEK SCAN?
- 2020 Q3 - Radio keeps playing when door is opened
- 2015 Q3 Quattro Misfiring at idle
- MY AUDI APP
- Mild hybridization?
- 2022 Audi Q3 - S-line Prem -Engine oil change
- Newbie/Lighting Q
- Largest Wheel Size/'22 Q3 S Line?
- Collision Mitigation?
- Pin Stripe?
- Rear Seat Belt
- 5W 40 oil?
- Door unlatched while driving.
- 2020 Q3 - Excessive Oil Consumption?
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- 2020 Q3 sunroof pouring water!!
- Inflation Relief - Black Friday thru the end of November Sale...
- Q3 F3 S-line blacking out bumper trims
- Installing larger screen in 2022 Q3
- 2021 sunshade fit 2022?
- Lane departure warning issue
- Need stick downpipe and cat for 2018 Q3 asap.
- clunk starting in reverse?
- Washer fluid
- Software update
- Headlights upgrade.
- Audi Q3 Exhaust mods
- Accessory Power
- change out backup camera?
- Interior Lightng
- Hail car cover?
- q3 45 2022 only ABS, PRE-SENSE, PARKING, AIRBAG sensors went off
- Electric seat will not tilt
- oil type for q3 2022
- DK: Warnings in myAudi
- Cleaning armor all out of leather?
- Navigation problem 2016 Q3
- Q3 wheel fitment
- Buying a new Q3, can you get good deals these days?
- Premium or regular in q3 2022?
- take out headlamp on q3 2022
- New Top Hat (Engine Cover) for My Plain Jane 2020 F3 Q3 USA 2.0T Motor
- How to setup alexa
- How much will it cost to repair this?
- Back of seat warms up
- Fuel economy 2019 Q3
- Audi Q3 2022 high speed gear problem?
- about to pull the trigger, already have a Q5
- Rear bumper protector
- 2022 Q3 leg room lighting
- Audi Q3 Downpipe
- Is Car mat a default accessory in Q3
- How to add speed numbers in the smaller-sized speedometer (pic included)?
- Wider tires stock 20's 255/40/20
- Rear Sway Bar for 2019+ (MQB) Q3?
- Reprogramming Old Key Fobs?
- SONOS replacing B&O for 2022?
- Prograsmming Gear Display in DIS?
- The time was automatic changed to incorrect time
- Now two Q3’s in family, and a “heads up”
- Thud sound when gear shifting from 6th to 7th to 8th gear
- Q3 Dyno test
- 2021 Q3 - Volume of Chirp When Doors Are Locked Using Remote?
- 20" TIRES
- 2019 Q3 Sunroof Leaking
- Q3 2018 steering swap help please
- Q3 MMI Keyboard locked when driving => Unlock possible?
- Paint chips- paint pen?
- Q3 but have question about the year/package
- MyAudi app Climate Control?
- 2021 Q3 35TFSI engine and transmission code
- Q3 2017 horn issue
- How does one disable the Adaptive Cruise Control on the 2021 model?
- What to do with the F-pin / 2021 Q3 45 TFSI
- Cooling Fans
- MMI Radio Favorites (pre-sets)
- 2015 Audi Q3 S-Line TFSI S-Tronic 101,000km
- Looking to buy a Q3 Premium - Discount code?
- Carbon dash trim 2021?
- Just Took Delivery: 2021 Q3 PP Navarra Blue/Rotor Gray
- Winter Wheel/Tire Options & Questions
- 2013 Q3 - MMI-music media devices
- Carplay help needed on Audi Q3 2018 Technik trim
- 2012 Q3 Engine rattle at low RPM
- 2012 Q3 Engine rattle, intermittent EPC and CEL
- wiper / washer fluid synch
- Factory spark plug for 2016 Q3 Quattro?
- Auxiliary fan issues. Maybe, maybe not!
- "Leather" Seating Surface
- 2018 q3
- This can’t be true (Audi Connect)
- BO subwoofer and back speakers not working
- UK: Replacing Rear Number Plate?
- Oil leak ? Can you help pls ?
- Q3 Dash Cam Battery Fuse
- AL: Audi Q3 2016 2.0 Tdi Engine noise?
- Cargo Net
- Delayed ignition start 2018 Q3
- ‘21 Q3 40 Radio Issue
- Q3 (2021) Roof Rack
- 2020 F3 Q3 trailer Stealth Hitch install ; first on road towing impressions
- 2015 Q3 ESC light on.
- 2019 Q3 P.P. MMI Screen Blank on Startup
- 2021 Audi Q3 45 S line Premium Plus - Black Optic ?
- Q3 motion sickness - air suspension system?
- Windshield replacement for 2019 q3 premium?
- Q3 parking module help needed
- What kind of discount?
- Q3 Windshield Question
- Impressive fuel economy
- 2019 Audi Q3 here - What average oil temps do you see on your Q3?
- Q3 Sportback 4.0 TFSI Quattro
- Seat Belt Pretensioner Fault
- 2020 Audi Q3 45 S Line
- Audi Extended Warranty
- Stain on piano black window trim
- Installing Thule Hull-a-port Aero on Audi Crossbars?
- Paddle Shifters: How do you use them?
- Idle RPM
- Aftermarket Carplay 2016 Q3
- Apple Maps in CarPlay shows previous location on startup
- getAudiparts.com | Stay Cool with Genuine Audi Sun Protection Accessories!
- Q3 Cold start rattle - solutions? (MY21 2.0T)
- 2020 Audi Q3 Technik 45 TFSI quattro **Lease Takeover** in Canada
- 2020 Q3 ENGINE COVER
- Oil in coolant reservoir 2014 Q3 Quattro 2.0
- Soft Brake Pedal
- Turning Hall Sensor to Keep Taillight and Rear Bumper Lights Both On at the Same Time
- Broken fender trim?
- 2017 Q3 tow hitch
- Any ODB-11 coding for the 2021 Q3?
- Is there suppose to be suction/leak here?
- Nextbase windscreen camera power source.
- 2022 Q3 Order Guide?
- Windshield camera, but no adaptive cruise and lane assist
- myAudi APP in Canada - no remote control?
- Q3 2019 40tfsi S-tronic gearbox issue
- MyAudi can't automatic login MMI system
- Genuine Audi engine oil?
- 2021 Q3 Technik - Electronic Parking Brake Question
- Update rmc_eu_p11474
- Clicking/whining noise on acceleration. Anyone familiar with it? (2012 Q3 Quattro)
- Radio/MMI
- Q4 introduction live stream
- Q3 Interior Fuse Compartment Cover Dropdown
- Install front Sway Bar Links cost
- RS grille for 2017 Q3
- Audi MMI Fast scroll
- Great Audi quality!
- Need Help Applying Touch Up Paint
- ECM Update
- Thinking of buying a new steering wheel
- Anyone drive the PHEV q3?
- 2021 Q3 - Infotainment Resetting?
- Accessory outlet & auto stop/start - heads up
- Buying 2019 Q3?
- 2021: Ride Quality 19" vs 20"
- Rear license plate screws. NEED HELP!
- UNRESOLVED - Sound coming from 2020 Q3 passenger side
- ** Q3 2016 S-Line Quattro gearbox fluid + filter service **
