PDA
View Full Version : S6 / RS6 (C7 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. Dashboard and MMI dead 2013 A6
  2. C7.5 S6 does not blow hot air until on HI
  3. Air bag light causing bizarre codes?
  4. 2017 s6 Key fob not recognized
  5. TDI Settlement Update - Check Your Mail
  6. 2017 S6 production numbers
  7. turbo whistle at WOT and high RPM
  8. Fans on A6 C7 3:0
  9. 4050 - Leak in Air Intake System
  10. 2018 Audi s6 prestige
  11. Bad News Coming?
  12. Power loss, Ignition coil?
  13. Rough Uturn with acceleration only.
  14. Anyone lift an A6 for better ground clearance? Is it possible?
  15. S6 Problems
  16. low pressure fuel sensor
  17. New left headlight problem
  18. Textar brakes
  19. No Crank P3054 code...
  20. How to replace parking brake control module??
  21. CAR WONT START AFTER JUMPING IT .... HELP!
  22. Air Intake Upgrade
  23. P2181 RS6 V8
  24. VCDS Fault 21583
  25. Audi pre sense not available.
  26. Inflation Relief - Black Friday thru the end of November Sale...
  27. S6 2013 runs fine without oil cap wont run with please help
  28. Sudden exhaust noise increase rough running after full throttle fun
  29. Sell my S6?
  30. rear diffuser
  31. S6 to RS6
  32. Fuel Housing Drain Hose
  33. Flashing cel
  34. This might be a dumb question but here it goes
  35. P0240 & P0045(F3) codes once a month
  36. 2016 S6 4.0
  37. o2 sensor signal biased/stuck Rich bank 1 sensor 1
  38. Seafoam
  39. 2017 S6 - 52K - New Engine required!! WTF
  40. 2016 S6 side mirror folding issues
  41. 2.0TDI 177BHP - Never reaches 90C temperature
  42. Rattling noise, probably from driver door, 2018 S6
  43. Front brake caliper piston stuck? Seized?
  44. Power tune?
  45. Accidental cosmetic mod
  46. Purchasing S6 Questions/Opinions
  47. Changing gear sensor module tricks??
  48. S6 Maintenance?
  49. Andover Cars Coffee Tomorrow
  50. 2014 C7 S6 TopView Camera issues
  51. Selector lever malfunction
  52. 12 volt outlet?
  53. New 2016 A6 Owner Looking For Tune
  54. New owner here!
  55. Oil Change after a year (but 1500 miles)
  56. LT: S-tronic DL501 replacement to ZF 8HP?
  57. Transmission Whine after Scheduled Service
  58. NHTSA opens probe into failing 4.0T turbo failers
  59. 2018 S6
  60. 2014 S6 Strange Chirping noise
  61. The reign of the V8, coming to pass...
  62. Carbon Fiber Dekor ONLY FOR GERMANY
  63. Interested in 2017+ S6
  64. New 2021 S6 exhaust upgrade
  65. powder coated brake calipers
  66. 40k transmission service
  67. 2018 S6 - Oil Consumption leading to other issues
  68. S5 vs S6 Comparison Thoughts?
  69. S6 Turbo Replacement
  70. 40,000 Mile Spark plugs...
  71. No connection to OBD2 port
  72. JB4 for Sale for 4.0 (2016 S6)
  73. ISO Best settings for Launch?
  74. 2011 S6 Throttle body removal question
  75. Audi MMI 3GP HN+R_US_AU_K0942_3 Firmware
  76. Tranny Noise in first gear from start to 15 mph
  77. Key fob locks the car, but I can still unlock it with the door handle
  78. 2018 S6 subwoofer upgrade
  79. Engine cover heat shield replacement
  80. Wiring Into Amp/Subamp?
  81. Considering purchasing an S6, Advice Appreciated
  82. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  83. Audi A6 C7 2012 Wont Start, no dash light, no horn, no Indicator Light no AC
  84. Ceramic coatings
  85. The maximum power and torque that the motors hold is 4.0 TFSI ?
  86. S6 - 2014 vs 2016
  87. Battery replacement 2013 Audi S6?
  88. 2014 A6 - Electrical Connectors
  89. Best Tire Size for 20 x 9 Wheels?
  90. A6 Electrical issue help please plus scan
  91. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  92. Bought a 2018 S6 - winter wheels
  93. S6 trailer hitch options
  94. Looking at a 2017 S6 - Thoughts and warranty options?
  95. Brakes
  96. Audi RS6 chased by police all out
  97. audi a6 c7 3.0tdi transmition acting weird uphill and when stopping
  98. RS Flat Bottom Steering Wheel
  99. Black Out Emblem Tips
  100. Tow Hook Camera Mount
  101. carbon fiber rear diffuser
  102. I think I lost my 2016 S6 Yesterday....
  103. 2017 vs 2018 fuel economy mistique
  104. best tire options for 2018 S6?
  105. Any changes from 14 A6 TDI to newest year it was sold?
  106. New Wheels & Tires 20" Recommendations?
  107. S6 2017 C7 Honey Comb Grille
  108. Issue with locking/unlocking
  109. rs6 vcds scan
  110. Cannonball Record 2016 S6
  111. Drivers Window Regulator Cable Snapped
  112. Custom wheels?
  113. Fault codes
  114. 2013 A6 Intermittent Power Window Issues
  115. Brake noise without brake pedal.
  116. 2012 Audi A6 honeycomb grill
  117. S6 - intake manifold flaps stuck
  118. Tv and Key problems
  119. Can't maintain constant low speed
  120. 100,000 Miles
  121. New car, new to this.
  122. S6 cylinder deactivation
  123. S6/A6 used car pricing?
  124. A6 C7 2.0 TDI (177) timing belt tensioner reading high
  125. A6 Comp or S6?
  126. How to restore, clean and maintain leather seats
  127. Help! Stage 3 S6 with a ton of codes
  128. software
  129. Looking For Suggestions; S6 20" Wheels < $350
  130. Mysterious error display
  131. I'm about to buy a 2015 A6 3.0T Quattro Prestige
  132. Bolt Pattern and Offset Question??
  133. SK: S6 2015 - Stronic?
  134. Lease ending, will probably buy the car
  135. Sustained Coolant Issue and now smoke a after turbo failure
  136. 2012 Audi A6 PRESTIGE Auction Buy
  137. Full LED dipped beams problem
  138. 2018 S6
  139. C7 Service Manual?
  140. S6 Oil and filter change?
  141. Fuel Injectors.
  142. radio off when starting
  143. Lease End Miles Discount?
  144. Help No ignition...
  145. Spare Key Fob Programming
  146. Donate to Discount so you can Quarantine in Your Garage...
  147. Skipping Tracks from the Steering Wheel
  148. Audi Coloring Book
  149. X-Pipe Or H-Pipe Install?
  150. SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
  151. P0456 (No leak found) and P190F00 for 2012 Audi A6 Quattro
  152. Used 2013 S6: Am I C5 or C7?
  153. 2018 S6 - New Car, New Questions
  154. 2013 vs 2114 S6, any differences?
  155. A Few S6 Questions
  156. Ibis and Glacier White
  157. GPS A6
  158. Dealer thread?
  159. Looking For the answer to the RS6 grill for a 2014 S6
  160. 4.0 leaking coolant somewhere
  161. HID high beam issues
  162. MMI Volume Control - Fixed for $7.00
  163. What is the smoothest riding C7?
  164. Pothole destroyed wheel: Tips on finding OEM replacement?
  165. So I hit the speed limiter on my S6...
  166. Audi S6 Custom Exhaust Advice?
  167. We Build Faster. Shorter lead times on AWE Exhausts.
  168. Dashcam and "Trunkcam" suggestions
  169. Front Calipers for 400mm rotors
  170. S6 c7 buyers guide
  171. 2012 A6 Quattro AC Relay
  172. Supplemental lighting
  173. All dash lights on - limited power
  174. Front/rear brake cost thru dealer 2015 S6...
  175. could use a little help..Stereo
  176. Constant rattling misfire Audi A6 3.0l v6 p0136 p0133 p0171
  177. Service reminder reset?
  178. Checking for TD1
  179. 2016 S6 35K service done, 200 miles later turbo blows
  180. Best ECU/TCU and why: 2016 Audi S6
  181. 2017 S6 purchase, not a smart choice?
  182. RSNAV fundraiser for c7/c7.5 10.25 MMI Upgrade
  183. What model should I buy ? (Used)
  184. AWE's Annual Holiday Special Pricing Event Starts Now.
  185. Second key seat memory
  186. Pagid y19 brake pads
  187. Crankshaft bearings looseness problem
  188. getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
  189. stock boost pressure on lap timer
  190. Looking for DIY guide to PCV replacement
  191. Audi A6 C7 Avant electric hatch.
  192. WTF Electronic Parking Brake
  193. AWE BLACK FRIDAY 2019 STARTS NOW.
  194. Looking for a Audi shop in SW Florida
  195. APR exhaust shooting glitter out
  196. s6 sxhaust question
  197. Sold my 2013 S6 to Carvana last night
  198. External SIM slot OBD eleven coding 2013 S6?
  199. National Breast Cancer Awareness - Donate, Save Lives and more...
  200. Headlight washer cap, how to remove.
  201. Tune
  202. Gasoline Brand and Additives?
  203. Just upgraded from a 2001 2.7T to a 2017 CPO S6 Prestige
  204. PSS Sport exhaust/diff package availability?
  205. TPMS. Disappointed.
  206. Android Auto Finally Works!!
  207. 2013 S6 Navigation update
  208. Help matching Arras Red Dye
  209. Misfires on 2014 A6 3.0T
  210. PSS retrofitting on C7.5?
  211. Custom Grille for 2014 A6 in the U.S.
  212. Purchasing Advice - S6 2016
  213. Purchasing advice
  214. looking for new exhaust
  215. Looking to buy 2016 Audi S6 Prestige with 63k miles.
  216. 2016 S6 Audi Prestige
  217. XL tires.
  218. The C7's are officially gone
  219. 2017 Audi S6 Salvage due to flood
  220. Is the Extended Warranty a Good Investment?
  221. Value of Factory Warranty vs TD1
  222. Should I replace 2016 S6 brake pads and rotors?
  223. Looking to possibly trade up.
  224. 2014 S6: Multiple Faults, Dealer can't replicate
  225. Europrice - New Website - New Products...
  226. 2012 Audi a6 supercharge/ ac
  227. Exhaust electronic valve cutoff and warranty
  228. Oxygen Sensor Location: Bank 1 Downstream
  229. JHM oil screen replacement kit
  230. Functionallity Exhaust Acitve Valve in S6 Facelift
  231. 2018 S6 - back Door wont lock / no confirmation sound when locking vehicle
  232. 2018 S6 - back right Door won’t lock / no confirmation sound when locking
  233. Audi Care Select Plan 1 35/45k Services $879 Good price?
  234. Need your advice - Should I sell my S6 or am I crazy?
  235. Wheel Alignment Question
  236. Picking my first Audi
  237. 255/40/20 or 265/35/20 for 18' S6? Advice needed
  238. best S6 model year for reliability
  239. About to purchase an S6
  240. 4.0T APR Catback-Exhaust System!
  241. FS: 2018 Audi S6 with only 223 miles! Florett Silver with Black Optics. Carbon inlays
  242. Noise driving me crazy
  243. getAudiparts.com | Genuine Audi Black Rings Sets!
  244. Do dealers "deal" on RS models?
  245. Transmission Malfunction - 2014 Audi A6 - 3.0 TDI Diesel
  246. OBELEVEN
  247. 2020 S6 review up...
  248. CPO Warranty worked in my favor, now I must sell... maybe?
  249. New to me 2017 S6
  250. Budding Dealer Dilemma to the tune of $12k
