- Weird behaviour and movement of the transmission
- a6 c7 prestige quattro drl issue
- Audi A6 / A7 C7 (2012–2018) Upgrade – Factory-Style 9” Retractable Screen
- towbar coding
- Coolant Expansion Tank Lines
- 2016 Audi S6 CarPlay options.
- RS6 C7 2014 Rear Puddle Lights
- '16 S6 Brakes
- RS6 C7 2014 Space Saver in Boot
- S6 rear differential failure
- Iphone 17 Pro Pairing
- What should I ask for my low mile S6 if I was to sell it?
- S6 Old Man Mods
- BLACK FRIDAY SALE ON NOW - STOCK-UP AND SAVE!
- Intergrated Engineering
- Whining from gearbox
- Increasing Ride Height of an A6? Spring kit?
- Considering buying a low mileage C7.5 S6
- Audi rs6 2016 comfort seats to supersport seats no heating. Help!
- Downpipes
- Battery?
- Motor Mount Replacement Time
- Part number help!
- Audi a6 4g cnha 2014 all dashligh apper!help
- NO Headlights/DRL/Front signals
- Coolant Pump 2 help
- How do I read this engine wiring diagram
- APR Ultralink: At Home Flash Tuning is Now Here! (4.0T EA824)
- Alcantara Door Card Swap - Is it Possible?
- S6 With Borla Exhaust
- alignment
- Downpipes
- Does the car need a full recalibration after removing/reinstalling the bumper?
- CODE 2294
- Update
- Should I buy this 2013 S6?
- S6 Long Term Ownership
- 2012 A6 C& 30.T - no start/timing Chain - CODES 0386/12291
- The 2015 A6 project
- Where can I find CAN HIGH and CAN LOW wires in the trunk??
- How big can you go
- Help with Suspension Issue
- Installed an APR catback on my S6 this weekend. OMG it sounds awesome!
- Many Cars-Still love my 14 A6 compared to even new cars.
- 2016 Audi S6 Battery Not Charging
- Engine manual for an Audi RS6 plus Avant quattro 4.0 RS6
- Which coolant?
- Oil Change and Air Suspension
- 2016 s6 wiper motor
- 2018 S6 front and rear pads/rotors
- S6: P003300 - Turbo Bypass Circuit.
- For Audi RS6 S6 2012-2018 12.3inch Touch Screen with Carplay Android Auto
- C7 S6/S7 DL501 to ZF8 HP55 Swap Guide
- Rs6 c7 2014
- Help
- 2013 Audi S6 never ending suspension issue
- S6 C7 differential oil change
- S6 Tire Wheel Fitment?
- Gearbox malfunction
- MMI Update
- Installed new rear shocks and front rotors yesterday
- 10.25″ Vs 12.3″ Android Touch Screen For Audi A6 S6 C7 2012-2019
- 2016 S6 Advice
- Lumpy start
- Throttle position wire won't latch into 60-pin ECU connector (rodent repair carnage)
- Retrofitting OEM reverse camera on C7 Avant
- Ballast pins
- 2018 S6, both turbos “exploded,” shop wants to replace engine!
- 2013 S6 Wheel Tire fitment?
- HELP! Whistling wont stop
- Wheel fitment?
- Are stock/OEM rotor vanes directional or straight?
- Driving Modes and Transmission (new owner)
- Back to an A8. Thanks for the help!
- Red line differences between years
- 15 A6 AC isn't working
- 034 Motorsport 2-piece front rotors installed - initial impressions (not happy)
- S6 7.5 Center jacking points
- S7 7.5 Center jacking points
- Exhaust tip installation 2018 S6
- air suspension fault.....on 2013 S6
- 2016 TDI - Steering wheel mild tension
- Audi a6 3.0T RXP Catch Can install (twin)
- 14’ S6 HPFP
- 2018 S6 tire cupping... vibration... Ugggh....
- RO: A6 headlight 4GO.941.033.C vs 4GO.941.033.D
- noise like short circuit every time if I start
- Exhaust sounds like it’s starving for air
- 2014 S6 C7 Service Position -doesn't seem to make much room?
- DE: A6 2016 competition multiple faults
- HUD Malfunction, LED Arrays Throwing Error Codes
- C7 S6 TTV8 Rough start after drives w/ AC. O2 Sensors
- Anyone here done the Direct TPMS retrofit on their S6?
- C7.5 RS7 B&O Front Midrange Speaker Specs/Location?
- Weird whining gearbox while driving
- Shaking/Shuddering at 50+ MPH Audi S6 C7
- O2 rear sensors interchangable left to right?
- A6 TDI Horn Honks When Starting
- 2016 s6 what type of transmission do I have? PDK is the code on build sticker
- Replace Air Suspension
- Audi RS6 C7 carbon trim
- RMP surge after stopping
- Wheel Noise Each Rotation Like Something is Hitting Underside
- BG: A6 C7 2018 Sedan USA to EU Tail lights conversion
- Starting my Due Diligence
- Transmission issues
- Slight fuel smell in cabin
- Christmas Holiday Sale
- 2017 S6 ECU Tuning
- Visualization parking sensor
- New 1st time Audi Buyer
- Audi s6 Staggerd Wheels
- audi s6 c7 sport differential system fault when drifting
- FINALLY!
- OBDeleven
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- urotuning
- No voltage to altenator
- 2014 S6 C7 Transmission Malfunction Warning
- 2012 A6 Premium Plus
- HELP valve location please!!!
- All Warning lights on dashboard and vehicle shuts off immediately after starting
- Downpipes
- I need your help to get my car fixed!
- P0299 code (underboost)
- Oil Leak Help!
- Front Grill
- I can not able to find ignition coil fuse
- 2017 S6 & car sickness
- Audi S6 C7 Vibrating
- Dealer vs Independent Bushing Replacement Quote
- ANZO Sequential Signal
- Overhead console removal, non-prestige.
- Audi A6 Steering problem
- Considering buying a 2016 S6 with a manufacturers buyback title.
- Change 3rd brake light Audi A6 C7 Avant
- New Key Fob?
- 2018 S6 strange noise at >1400 rpm
- American message board members.....
- Lessons learned from lowering suspension w/ air ride?
- Transferring HUD from one car to another
- Help with engine removal.
- AC cutting out after long trip
- '15 S6 C7 overheating.
- Greetings from SuperSprint Italy
- Rotors
- Replaced Comfort Control Module - Key not recognised
- 2016 S6 75K Service
- BG: Looking for an cooling upgrade
- UK: 2016 C7.5 RS6 Performance - Critical Electrical Issue Please Help!
- Transfer case oil change question
- Replacement Transmission for my S6
- NEW MEMBER PLEASE READ
- S6 Avant 2013 - Intermittent Starting Issues
- Are S6 and RS exhaust manifolds the same?
- Wheel alignment in different drive modes?
- O2 Sensos Bank 2 Downstream Location of Wiring
- Exhaust sound of S7 in comfort mode?
- Thinking of moving from S5 to S/RS7
- Tie rod end adjustable sleeve?
- Major Issues: Just bought an Audi A6 (C7) 2015.
- Unknown Wires in the from the front of the car
- Intake manifold flaps - life span?
- metal dragging sound when driving
- S6 Coolant system issue with warming up.
- C7/7.5 S6/A6 center console controls
- A6 C7 BiTdi 320 PS injectors fault
- Low Tire Pressure message but pressure is not low
- Rotors and wheels
- '16 4.0 luvnit
- HUD on 2017 audi a6 3.0T
- 2016-2018 S6: What to look for?
- A6 C7.5 US->EU tail light swap
- 2013 Audi S6 Parts Car
- 14 S6 Fault Code p2279
- C7 S6 Air suspension lines
- 2017 audi a6 tdi bypassing d1 and stalling
- FS: 2013 S6 w/OEM RS7 Turbos & APR Stg 3 Upgrade. San Diego, CA. $25,995. Very fast!
- 2018 S6 parking heater retrofit?
- Intermittent hesitation
- Break pads and rotors for Audi S6 2018?
- Audi Parts - Front right grille 2013 Audi S6
- Brake rotors and pads suggestion
- 2013 S6 - New Owner - Mechatronic
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 2016 Audi S6 Oil overfill
- Are the S6 and S8 turbos the same ?
- 2000 a6 quattro 4.2l tcm issue
- New A6 owner
- S6 brake pad options
- Wheel offset?
- S6 engine failure after oil strainer recall
- Air Suspension Puzzle
- 2017 S6 MMI Knob Feedback Question
- Wheels?
- UK: Are these wheels genuine?
- Code assistance
- Code assistance
- 29 codes appeared- pls help
- New S6 owner!
- Clutch problem..Software issue?
- led reading light
- [video] High pitched buzzing noise behind dashboard when AC is on
- Windshield Washer Fluid leak
- New to the Audi world
- MMI w/ broken winch cord
- New Owner. Need help!
- Oil Strainer Recall
- Need link to Febi front control arm kit c7 '16 s6 prestige
- Audi having trouble shifting from R to D
- MMI swap from Bose to bang and olufsen
- NO: Engine oil
- S6 MTM
- Cyl 8 Misfires, Oil on Spark Plug Electrodes
- Looking to purchase 2018 S6 as daily driver.
- NO: Which Motor oil should I choose?
- Multiple headlight failure
- RS6 C7 Exhaust experience-cutout (flaps)
- AUDI RS6 C7 OPTIONAL EXTRAS
- Steelership quote. What does everyone think?
- Mechatronic issue or something else?
- Head gasket water leak with only 60000km 2013 have to change Why?
- UK: Wing mirror knocked off - what replacement do I need?
- 2017 S6 Steering Wheel Loose
- 2014 Audi A6 - door will not lock.
- 2014 Audi A6 - fan will not shut off
- 2018 S6 Strange noise left front
- Coolant pipe name?
- Emission Inspection DENIED
- Removing rear seat bench
- Thoughts On this 1 Owner 2013 S6 I Found For Sale?
- Disabling Center Rear Seat Belt Igniter in VCDS
- P2B2F00 - Fan 1 Performance/Stuck Off
- Where to tap for aftermarket amplifier power?
- BG: Audi S6 2016 Boost issues Over 130mph/200kmph
- Looking at Purchasing an S6 and Would Welcome Advice/Feedback
- Check Engine Light
- looking to purchase a 2016 Audi S6
- Wheel/Tire Advice
- p2004 audi 4.0T IMRC intake manifold stuck open
- 2016 S6 Tire Pressure-what should it be?
- Recall Coming
- Rear Door Locks
- just bought a 2014 S6 and already issues
- New Owner! Question about windshield
- Hit Pot Hole Hard A6 with Sport Package
- HUGE NEWS - AOA Warranties Turbos on C7 S6
