- Xpost from TT : any pics of Mille Miglia MM-S Sport on a TT?
- 16" ASA JS1 for a '91 90? Gary?
- Gary, do you have any info on the O.Z. Gallileo III?
- Gary, can you confirm the width on the 17" SSR-Comps? Copy says 8-1/2" but that seems too wide.
- are yokohama avs intermediate tires still considered good?
- Gary: BBS RXII 18x8.5
- Class action tire settlement question
- Tirerack Winter Wheel & Tire Packages
- are hankook tires any good?
- Gary: I'm thinking about putting the BBS RK's (17x8) that I have on my A4 onto my GF's 02 SLK.
- I need opinons on speedline 2210. Does anyone have pics of these wheels on an audi?
- Will 17" SSR-Comps fit over '02 A4 Brembos? StopTechs?
- what are some tires that is less harsh in ride comfort.
- i'm about to widen the holes in my wheels. GOOD idea or BAD???
- flik tdr's
- what are ppl's feelings about the potenza RE950s?
- need new tires, it's either, KUMHO, NITTO, OR PILOTs what is everyone running?
- Whats the lightest wheel that Edge sells in 17 and 18" format?
- AEZ Wheels in USA
- Goodyear F1 number one from MAX performance?
- S03's ride too harshly -- any recs for good wet traction and ride quality w/o losing handling?
- RAD Wheel locks
- Looking to replace tires towards fall
- Does anyone have pics of Axis se7en mods in 18" on an audi?
- P Zero Nero 225/45ZR17 Impressions
- Cupping ?
- Tyre Pressures
- Mille Miglia MM-S Sport
- PZero Nero M&S vs. Potenza RE750?
- Looking for a good medium performace summer tire in 17 or 18"
- Gary, are the OZ Superleggara 19" Gunmetal discontinued??
- Weight of MTM Bimoto 19" ??
- Which tires are a better value for the money - Toyo T1S, Yokohama AVS DB (more)
- Ronal vs BBS, .....
- Will 235/45-17 work on 17x7 wheels?
- Shaved lug bolt.
- Looking for Older Audi rims w/ black audi medallion...
- MAS Wheels? (Xpost from TT forum)
- Will 245 Kumho MXs fit on a 8.5" wheel on the front of a TT?
- Gary..Pirelli P Zero Nero 235/45/17 did fit on my 2000 S4
- x-post from B6 A4 forum...tire question, TIA!
- This is all strange ?
- Stupid question re: rotating tires...
- LAST Days, 17-18" wheel/tire Packages, $998.
- How can I diagnose if it is an alignment prob or radiall pull?
- ******Construction crew cut through a fiber optic line
- Gary, I see PZero Nero on sale for $136 in size 225/40/18...
- Neu Skinz! ;O)
- Gary, fast busy when calling the Tirerack all day :o(
- ok they just told me my tires are down to the steal belts so
- Which setup?
- Gary, can you explain the difference between the Y rated PZero Nero ($115) and the Z rated PZero
- Gary or anyone else: Opinion on the BFGoodrich g-Force T/A KDW 2? - - >
- Pretty cool little "tool" .............
- Gary: Do you know if I can fit 18 X 9's in the rear of a 02 SLK230?
- 19s in the NYC area.. How bad of an idea is this? <insert evil grin>
- Are my 235/45/17 P Zero Neros gonna fit my S4 (oem wheels).
- Where can I get Audi ring stickers for BBS RC center caps?
- Bad Acting Michelins
- Good impressions of the new Pilot Sport 2's!
- Will the Eagle F1 GS-D3 in 225/45/17 fit on 17x7 rims OK?
- HELPPPPP 2002 A6 sport wheels: Cap?
- 9 spoke alloys 17" 7J 225/45r for A3
- What would you choose, BBS CH's in 19's or HRE 446's in 18's
- Which RAD or Mcguard model # for BBS SX?
- Trying to get my rims installed...having problems.
- Gary - I want to get snows on my old stock rims for 93 S4... but they are 8 inches wide.
- Which tires would you get out of these........and why?
- I need a nice affordable 18" setup for B6 A4.....
- 18x8.5
- EDDIE -- 205/55/16 to 225/50/16 on non sport 2.8 A4
- just installed my 17 today on p6000. the tire is too noisy
- need advice on a tire, fitting a rim 18x8.5: looking for good all season tire..
- wtf????...i ordered RE950s from Gary YESTERDAY....and they're at my doorstep today...THANKS!!!
- SPECIAL...$998. 17-18" wheel/tire packages..>>
- Those w/ 225/40-18. What pressure are you running?
- Anti-seize on wheel studs - Gary?
- Does anyone know what shop had ran the AXIS wheels display at waterfest?
- What's the biggest tire I can go?
- opinions on pirelli p7000's?
- Looking for good Alutec dealer.
- Advice Please: Hard to believe, but I actually want to size down my wheels/tires...
- Tire pressure for 1999 A4
- Gary, is there any way to make 18" Breyton Inspirations fit an S4?
- I am going from 225/45/17 to 235/35/19's...but my rim is going from 7.5 to 8.5..
- I am getting Hagens with 235's should I worry about using them in snow?
- where's the cheapest place to get oz sl silvers?
- Your opinions on the following wheels?
- anybody seen the tecnomagnesio detroit silver's?
- Tire Opinions: Hankook Tires orr Yokohama Prada Specs
- 19"OZ Vela's need lip repair.......unless someone wants to buy them?
- Tirerack warranty?
- please help, just talked to gary on the phone.....
- Gary, 20 X 8.5 all around with 235/35 tires on a new cab?
- Will 235/40/18 Kumho 712's on 18x8 OZ Cronos rub on my car?
- Out of the following tires which would you want?
- Will BBS RX(not rx II) 17x8 clear S4 OEM calipers? spacer size needed?
- RONAL 17" & 18" wheel/tire packages, $998.>>
- Tire Size
- Wheels Opinion Please...Slightly Long
- Gary, What tire size should I be running for my 19 x 8.5 Sportec mono 10 to ensure no rubbing?
- BBS LM's 19 inch for S4 anyone use spacers to clear their big brake kits and size of the spacers
- Need new tires on my '02 1.8t 235/45-17"
- Anyone with H&R Coilover Street and 19" on S4?
- Any b6 A4s running 19 x 9.5 in the rear? issues? what tires?
- what aftermarket set of wheel locks r u using? if any? gorilla? mcguard?
- Will P215/50/17 or P225/50/17 fit my A4 1996 non OEM suspension? ..
- Help! No key for wheel locks!
- For those of you with 19x8.5 wheels with 235/35/19 tires, I have a few questions...
- Does any company make 17x9 wheels?
- SSR Rims
- Will 19 X 8.5 rims with a 35 offset fit my '02 A6 2.7? Would spacers help?
- what should I put on my wheel's hub face to prevent corrosion?
- Whose got the best prices on BBS CH 18s with Pilots?
- who sells Oettinger wheels
- Anyone have pictures of an 18" axis supermesh wheel on a car?
- HP Racing wheels - any good?
- Cheapest place to get 5x112 16x7 steelies for the winter? Please. Thank you.
- anyone have oettinger REs for sale?
- Highlinewheels update. invalid email address
- WANT TO BUY TT 5 Spoke 17" Polished Wheels
- H&R Cup Kit Springs for A4 96-99. Part no. 31002-1 will not work on a Avant 1.8tq right?
- Where to get 5x114 to 5x112 adapters? I know, not recommended, but it's so hard to find 17x9 wheels!
- Thanks Gary, got the new Pilot Sport 2s.
- X-Post - Axis Se7ens on a TT - pics? And Gary, probs with 19s?
- Garry, 9 razze, do audi center caps fit on them?
- Who carries FLIK rims besides Edge Racing? I want Abyss 18x8's
- Pirelli PZero Nero's also available in a M+S version??!
- Gary, PZero Nero pricing confusion
- Help Please! Bad idea?......
- cheapest place for 18" superleggeras?
- what's the good size rim+tire in 19" on 2001 S4 w/ H&R Coilover?
- SSR INTEGRAL A2
- Time for some new 225/40/18's... Need a bit of help though TireRack:
- RONAL, 17-18" wheel/tire PACKAGE SALE...ends July 31.
- Anyone tried the new Pilot Sport 2 yet?
- Gary, I notice Kazera has fitments for Ford Foucs in 4 x 108.
- gary: Why does web site show Same tire(?) 4 times
- Anyone running 19"s on S4? are they too aggressive? any problems?TIA
- Im looking to buy some axis wheels but I don't know of a reputable dealer..
- Do we get any discount for buying tires through Tirerack? If so, I want some 19's today.
- Luke @ TireRack rocks!
- Wheel installation questions:
- Someone please explain radial push/pull?
- Can someone explain "radial pull" to me?
- Hankook h405 vs. Nankang ns2 225/40/18 advice
- Is it true that changes have been made to the BFGoodrich KDW2's...
- What would be the drawbacks/issues with running 4 wheels that are identical except for the offset?
- Tire size on 18x8 BBS CH, and rubbing
- just to make sure i've got my calculations right...
- 18 x 8 wheel, how does approx. 17 lbs per wheel compare to others?? Seems light to me!
- Sidewall cut
- 18X8.5 ET35 BBS CH's on my 99.5 A4... Any issues with this setup?
- Tire decision pain...
- Best Wheel Size for '98 A4 Avant Snow & Highway Driving
- Gary; would you agree that BBS is one of the best companys out there, or not
- Enkei CDR9 16" 5x100/5x112 40mm - Can anyone comment on the quality/strength?
- need your advice...look inside
- Wheel abuse & aftermarket suspension question.
- What size tire for 19x9.5? 255/30 or 265/30?
- Just a quicky..does the sport wheels of the new A4 fit the current (00-02) S4?
- Just got oettinger re 18x8 rims any tire ideas?
- 2003 A6 4.2 18's or 19's - Help & Pricing
- Gary, Do you have Michelin Pilot SX in 235/40/18...
- Gary, I'm thinking about putting RS6 replicas on my 2001 S4 Avant. 18 x 8.5 ET 30.
- any one know a good site for 4 lug rims?(more)
- rims and tires
- A4 Brake Job Rip Off?
- Nice deal on Pirelli Nero M+S; Gary got a question for you again
- any companys with good deals on rims, or rim/tire packages out there??
- Gary, I need help finding wheel locks for my new BBS CH's
- Gary@Tirerack.com: looking for new tires. Do I get an Audiworld discount?
- A8 wheels with tires that are too thick. . .HELP!
- Aftermarket Wheels sturdy like OEM?
- What do you guys think of BBS RCs??
- What size 19's can i put on my a4 cab?
- Would a 215/50/17 fit a 95 90 Q with a 40mm offset?
- Paint code for Oettinger REs?
- Think I'm going to get the OZ Superleggera's
- Alignment Question
- Speedline??
- VERY IMPORTANT GARY!!!!!
- Gary, I purchased a set of
- can anyone tell me how good nokian nrw's are?
- Accutire Tire Gauges: Anyone have these?
- What snow tires for stock 15" 2003 Audi A4 wheels?
- Audi Wheels
- Can you run Z-rated tires all year in San Diego?
- Anyone know a salvadge-place/individuals/companies that i can sell my OEM 16" 5 spoke wheel to?
- Does anybody have any feedback on ASA wheels, please?? 17x8...TIA!
- I need help with my tire decision!!!
- Will 15" wheels from 2003 A4 fit my 1998 A4?
- Gary!!! Goodyear GS-D 3 F1 in 235/40/18????
- X-post: Flik TDR's?
- Audi A4/S4/A6 Wheel Bolts: 17 mm or 19 mm?
- Is there any long term effects from having overtorqued bolts?
- Ronal Rims, for AUDI, 16-18" sizes...
- Good place in Northern Virginia to get tires mounted (Reston/Herndon area)
- SSR GT3: Who sells them? Gary: How long would it take to special order them?
- Wheel care and locks- - ->
- acura rims on a4?
- Tire Pressures: Any real performance benefits running a bit higher than manufacturer recommended?
- Gary, need summer tires for my
- wheel spacer/adapter question
- BBS VZ 18x8 w/ Kumho ecsta supra 712 235/40-18
- So what are the real tech negatives for going wider in the back?
- Gary, I need some summer tires for my 01.5 1.8T sport pkg- how can I contact you????
- Sooooo, who has the best deal on Kuhmo 712s now? Tire Rack?
- alternate sizing from stock 215/55-16?
- need help with wheels
- hey guys, need some info about fitting carlsson wheels -
- New wheels , thanks for the help guys
- Highline Wheels 19" RS4 Replicas??
- Would love some input on what some of the goodies on my car are worth...
- Hey Gary, price just went up on Winter Michelin tires. Do you expect it to come down any time soon?
- 225x40x18 Firestone SZ50 EP vs. Falken FK 451 235x40x18 on 18x8.5???
- Do I need longer bolts with just a 5mm spacer? Also can..
- Gary: Does TireRack carry the OZ Opera or Opera II?
- Michelin offering a $50 mail in rebate on any set of four street tires purchased July 1 - 31st
- Need new tire advice/opinions
- about to pull the trigger on some 235/40/18 T1S's does anyone see a problem with this? 25.25'' ride
- 225/45/17 rubber....would this work on a 17x8 or 17x8.5 wheel?
- Thanks to Tirerack for shipping my OZ SL's so fast!
- Gary@TireRack, does BBS make the CH in a 19x9.5 5x112?
- Gary, What are the wheel weights of the OZ classe and the Classe II in 18"
- Pictures of O.Z. Anteras on a B6, preferably in chrome?
- Tire Recomemdation 98 A4 2.8Q
- I plan on purchasing a set of ACH Tunings 18" DTM's for my 01 S4. . . . .
- Recommendations for new tires for used 1998 A4 Q?
- 00 A4 2.8QMS, what's the recommended tire pressure for 225/45R17 Bridgestone S03?
- Nokian WR -- First Impressions
- T or F: In general, running a tire with a stiffer sidewall will allow you to run lower pressures...
- Gary, I just ordered tires from you. I assume that...
- Gary @ Tire Rack, Ace Lola II's?
- I need a set of inexpensive 215/55R16 All season tires...
- Gary@tirerack, question on selecting tires
- 98 2.8Q tire recommendations
- looking for rims
- Do they sell hub rings separately? I just need one for an Oettinger RE 18x8
- Any advice on finding adapters to go from 5x112 to 5x100? TIA
- Anyone with achtuning's rs4 replica 18's dtms? post pics
- Moda R6 curb rash fix.
- rs4/celebration centre cap problem
- Why and How do I prevent a tire from cupping??
- Price on some OZ SL's
- cross post....What are the current opinions of the quality of Oettinger versus Ronal wheels...
- Has anyone tried the Yokohama AVS db S2 tires yet? I'm not real pleased with my.......
- What kind of wheel lock kit would i need for ACE lolas, and where could i find them locally (MD)...
- New tires for 96 A4 2.8q
- Tire brand mix & match on a Quattro - bad idea?
