- Gary: What is the current Back Order Status on ContiExtremeContacts in 225/45-17's??
- xpost: trial and tribulation of getting 1 19x8.5 sportec anthracite wheel
- Anyone ever talk tires with non-tire people...
- Tire size substitution question: 205/55-16 and 215/55-17
- Falken Azenis ST115 vs Avon Tech M500. Which one do I want?
- Looking for STOCK front springs for '96 A4
- n00b question about handling...(kinda long)
- Can a place like Sears Auto Center or a Jiffy lube type store
- Xpost: If I'm going to run 235/40/18 tires, should I worry about rubbing inside or outside.
- most affordable set of 19" RS4 oem? with or without tires. Also,
- does anyone have pictures of an a4(blue in preference) with hp evo wheels to see if it matches
- Rotating Tires on 2000 S4
- Opinions. please
- How much can I get for these rims?
- cheapest place to purchase Falken AZENIS ST115
- Gary: 255/35-18 Summer tires
- Anyone know of Volk LE37 knock-off that'll fit an S4? Or some cheap, used LE37s
- Took my tires to get flipped today and tire shop found mulitple bubbles on 3 of 4 tires.
- where can i get 1 19x8.5 sportec anthracite?
- Need (4 ) 235/45R17 summer tires. Anybody in N.E. looking to upgrade their tires?
- 99 1.8T FWD / HR Sport / Grooved Bilsteins / 18x8.5 Moven SP-10, ET35/ What tire size should I run?
- XPOST: S6 Wheel/Tire Combo
- do 225/40-18 fit 18x8.0 wheels OK?
- Looking for place that sells BBS RC "BBS" center caps...
- Michelin 205/55/16 fit my audi A4 1997?
- what's a good size tire for 18x8 wheel?
- Alignment for 99'Quattro???
- Need help with wheel fitting- Rial Daytona Race
- hi will these fit on a '98 cabrio?
- 17x9 Wheel options
- Paging: Gary @ Ronal
- Now that SSR is going away it seems, good 18 x 8.5 options for B5 S4?
- Will these wheels fit my 04 Allroad?
- will 17" 02 / 03 A4 sport wheels (et 43) fit on '00 S4 (stock brakes)?
- Got Pirelli??
- Tire comparo: B'stone G-009, Conti Extreme; Michi Pilots A/S -- discuss
- Need some direction on an alignment issue
- Gary@Tirerack out of the office till Friday.
- BBS CH 8.5x19in ET30 for TT... how will this offset look/work? getting used TT, doing research.
- hi ,all i'm thinkin about to get A8 replicas 18" and i have question : .......
- rs4 replica wheels?
- axis seven mod or enkei rpm2?
- Anyone know a paint to match Ace Lolas? Spray preferably
- Anyone have BFG Comp T/A ZRs? Is the sidewall flexy?
- What pressure to run in 225/45/17s?
- Bought a set of kumho Ecsta MXs...care and feeding advice?
- Anyone here track both SO3's and PS2's?
- Enkei Wheels
- Just ONE tire wearing and Cupping??
- Just want to say I'm quite impressed with the Falken GRB FK-451
- Attention Gary, need hubcentric ring info
- I returned the sucky, suck-suck Falkens and got Potenza G-009s. Thank F-ing God!
- Anybody have a drift or pull problem with Goodyear F1 GSD3?
- Attn Gary at Tirerack, how wide can you go on Stock 18" Avus?
- Trade BBS LM's for your BBS RGR or RS GT?
- when will tirerack get the new bbs ck wheels?
- 02 S6 18" options
- so its alright to claybar wheels then wax them right?
- Anyone know where to get Moven SP10 wheels online? Thanks.
- 225/40-18s i'm getting freaked out driving around town; this is my first set of 18s
- NE1 have 2 235-35-19 Goodyear F1s i can buy? new or with some miles on them. TIA
- Do I need to replace ALL 4 tires???
- Vibration between 55 and 80 on certain surfaces only?
- Will 245/40/17's fit on a B5 S4 Avant?
- Bridgestone G009 or Dunlop SP A2 Plus?
- Gary@Tire Rack I need 4 of these tires when you get them in stock let me know
- 235/45/17 ContiSport Contact 2???
- wheel sizing for audi a4
- What am I going to need to make these wheels fit?
- Wheels and tires
- Besides Tirerack anyone know who else carries ASA wheels ?
- need BBS RE cheapest pricing.....anyone?
- What's the best route for . . .
- Need some "tuner" lugs, 14x1.5mm...
- Minimum tread depth: does it vary by tire size?
- OZ
- how much of a difference in performance is 225/40/18 and 235/40/18?
- Need 1 used 235/40/18 for my spare, toasted the stock one--anyone out there have one?
- Motegi or Rota Wheels / Good or Bad - Weak. Opinions needed. Thanks.
- x-post. Curious about wheel balancing......
- wheelmax.com website
- Ronal USA offers 20% off..wheels..
- any articles explaining tires/wheel sizing?
- Gary @Tire rack
- 18x8.5 options for a B5 S4?
- What you guys think of HP DESIGN EVO?
- P Zero M&S mounted. I'm thinking bad tires(anyone else?), or tire tech didn't want to rotate.
- BBS CH's...do they use stock lugs (99.5 A4)?
- Anyone with SSR GT7s?? pics? TIA!
- Any one get NOISE from their P Zero Neros??
- Gary..........will SSR GT1's fit my B6 S4, and if so, how much?
- Other than obvious tread depth, do winter tires lose effectiveness after a few seasons?
- Gary@Tirerack.....
- got a flat...anyone have ONE bridgestone potenza RE040 225/45/18?
- Tirerack sponsor: Can you recommend a 225x45x17 tire that will
- running out of ideas ...
- Will it fit?
- Getting my Pzero Nero M+S's on Tuesday from Tirerack
- Cheapest place to buy Enkei Rpm2?
- I thinking of getting some 19" Flik Justice rims, but I want to put a OEM center cap on it.
- Pneumant PN 950 Tritec
- Tire storage
- Attn Gary at Tirerack, which tires with these?
- does Sears match prices on other online stores for tires??
- Few questions....how much could a 225/45/17 tire weight?
- I had a nail in my rear tire and took the car to a local
- Wheel polishing/cleaning in Westchester/CT
- Could I mess up an HRE getting them refinished? having them taken apart...
- Do you guys think I should mount this tire I've just bought?
- Help!!!
- Track Guys: "RoadForce" Balance on the Hunter GSP9700 machine. Yay or Nay?
- Anyone have Bridgestone Potenza G009's?
- Does AW think Sumitomos are quieter than Kumhos?
- Help? Should/can I run on a set of tires where front's are new rubber and rears are slightly used?
- To buy new rims, or not to buy new rims that is the question....
- B6 S4, will 18 x9 et38 fit front and rear?
- Ronal USA, offers 20% discount on wheels
- Thanks to Edge Racing....
- just got 19x8.5 sportecs w/ goodyr F1s for my B5 S4- what psi is appropriate? (more)
- Need some help from the wheel experts. TIA
- time to get new tires!
- Need some tire conversions. (x-post from AWOT)
- Gary@Tirerack....
- x-post. is this even possible?
- Gary any better prices then what is Listed on tirerack for us audi guys?
- anyone ever experience polished lips peeling?
- Luke I always want to say, *Gary* I need Oscar to get me a quote ASAP on 1966 912 tires . . .
- gary, came across your m3 on bimmerfest how you like that bavarian motor works?
- Gary at Tire Rack, can you help me with this??
- BFGoodrich g-Force T/A KDW 2 vs Sumitomo HTR Z II options
- Dunlop SP9000: where are they??
- Goodyear F1 GS-D3 vs. Toyo T1-S - looking for comments
- expected mileage yokohama avs 235/35/19 ?
- What 17" wheels do u offer for about 200$ per wheel?
- Tire rotation Mythbuster? (swapping side-to-side)
- Question for you tire experts :-) Will i notice a difference between Pzero Nero's and the Nero M+S..
- Any rubbing issues on these sizes: 18" x 9" and 245/45-18 tires
- Gary@Tirerack: SSR competition
- mixed tire size on quattro.. Gary or anyone?
- Correct aftermarket wheel offset for 225/50R16... ?
- Nokian RSIs are phenomenal snow tires. That is all.
- hey , do you guys know if the enkei rpm2 will clear s4 brakes?
- rims and tires for my a4
- 235/45/17 on 99 Avant question for Gary
- school me on wheels in general
- Looking for a "track Tire" that I am going to put on my extra set of rims
- Looking to upgrade using plus zero...
- I hate my Kumhos (sorta long).
- slight vibrating at 75 plus....
- Help with tire sizing
- Tire wear related to differntial wear
- need some advice...
- Is a 235/40/17 on a 17x7.5 rim OK?
- 255/45-18 on 18x8 rim OK?
- Hartmann M1 Sale!
- looking for 2001 A6 5 spoke oem rim
- Anyone ever get a four wheel alignment at Town Fair Tire?
- Please post pics of S4/A4 with 19inch A8 rims
- Need Help
- Why is Edge Racing's web page still down? Anyone?
- Someone Sell Me 19or20" Tires+Wheels for 2001 A8L
- looking for a new/used 235/40/18 Conti2 Sport Contact - just 1, just post or email please [nm]
- REALLY liking my 205/60-16s on my B5 Avant non-sport. Cheap too, ($53). Mmm...cushy.
- Are my Nitto 555's considered heavy tires?
- new P-Zeros... 2 have rim protection ribs, 2 don't
- will these 32mm offset wheels cause rubbing w/ 1 finger gap & no rolling on B5 S4?
- what is the recommended tire size on an 18x9 wheel?
- gary@tirerack: any news on advan neova ad07 supply?
- Gary@Tirerack....Availability on P Zero Nero M+S
- quick qustion valve stem hole size, Gary? or someone?
- Quick tire question...
- abs
- will 18x9 with 45 et fit on a b5?
- Pirelli PZero Neros vs. Dedicated Snows
- wheel adapter for jetta 5x100 to 5x112
- B5 A4 X-post...tire size questions
- Goodyear GSD3?
- Do BBS RX wheels have a conical seat or ball seat for the lugs?
- Ur S6 16x7.5? Tire sizes???
- Looking for a 17" BBS RK
- Specs on BBS wheels im selling
- ran over a huge pothole bent my rims, air leaked out of it, anyway to sue the city? (more)...
- Dunlop SP Super Sports - do they need to be heat cycled
- ADR Version II (saw on ebay) would they fit?? 18X9...
- WHEELS? NEED A LITTLE HELP, PLEASE......
- Has anybody in here driven the Falken GRB FK-451?
- A6 rims fit 2001 A4?
- looking for RS4-based rims (17 or 18") that knowingly clear Porsche / Brembo / StopTech BBK
- Continental Extreme Sport Tires, where to find???
- Ok..need a nice 18x8.5 wheel for a Project Car for an Audiworld article...
- can anyone put a name to these rims?
- Gary, confused with pricing on the V710's....(and couple questions)...
- wheel parts question - any help would be much appreciated
- Great new topic - Do you use air in your tires? Seriously!
- Less than 200 miles OEM B6 S4 Rims - Perfect condition.
- vredestein wind trek extreme or blizzak ws-50
- SSR Wheels Bankrupt?
- Gary@Tirerack will be out of the office Until Monday, Feb 7th
- Hi Gary @ tirerack....quick ?
- Anyone here heard of FLIK's painted rims have the paint come or chip off?
- New to AudiWorld, don't know much about wheels/tires, help
- Husky Jack, Stand, impact wrench package at Home Depot
- Have you seen Yokohama's new rubbers?
- Edgeracing's website is down? Anyone else have a problem accessing?
- What would you guys reccomend for 19 inch wheels with polished lips and dark centers?
- What is the largest size of wheels I can put on a 02 B6 A4 sport
- ICE racing tires: please post your opinions -
- 18 X 9 wheel....and 45offset....Would I rub using this wheel on my B5 A4 ??
- Hey Gary! Can you tell us when the conti extreme 225/45/17 will be in stock?
- Anyone try the Dunlop Direzza? Opinions? Gary?
- i Gave some advice to a friend and said that the Toyo RA1s were not for daily driving
- Is this do-able? Take a 5x112 rim and have them re-drilled to 5x108?
- what's the latest tire comparable to SO-3 that aint so damn heavy?
- Wondering about wheels for my '05 S4 Cab
- Does anyone know where I can get touch up paint for my BBS CH?
- After the weekend at Steamboat Audi Ice School - One can see how All Season suck!!!!!!!!!!
- BBS RK 17 X 8....Anything for sale out there?
- Need advice on "cheap" track wheels and tires.
- What's a good inexpensive summer tire? Fuzion zri?
- looking to upgrade to 18s, tire question
- Might be selling my new 18inch rims/tires, wanna get diffrent ones, need ideas!
- Toyo Proxes 4 VS. BFG g-force KDW (new flame pattern ones)...
- Gary@tirerack need hub center rings...>
- Gary@Tirerack - Question about tires for my '01 A4
- Any good site to find *tire* weights? Looking for 225/45R17 Falken Azenis Sport Rs and Kumho MX
- can stock lug nuts be used safely w/ the addition of a 5mm spacer?
- Is Gary@Tirerack in today?
- So I have two extra sets of wheels that I can set up as snows for s4 15 or 17 ?
- Tire handling debate: V-rated vs. H-rated -- Please advise
- Anyone know what wheels these are? or who's car this is?
- Need input regarding wheel and tire sizing for TT 225 QC...
- Tire size vs ride?
- Tire Dilema for A4 Sport
- Gary@Tirerack will be out the rest of the day today.
- I would like to get bigger tires from Tirerack, but I woud like to
- Oettinger wheels and spacers (long, read if you have t heir wheels)
- paging Gary@tirerack >>
- Hey TireRack, when will the Kumho V710 be available?
- Anyone have a pic or able to photo shop a 17" Avus S4 wheel on a D2 A8 (old body style)?
- anyone have personal experience with the Potenza G009?
- XPost: Looking for single 17x7.5" Mille Miglia Spider wheel 5x112
- Hey Gary or the TireRack team, 19" tire diameter questions...
- gary and others... need help picking a set of all season 18" tires..
- Is there a 17" wheel that will fit over Stoptech 355's?
- does anyone know how to get another center? its the replica rim so its label is just a sticker.
- Any opinions on ATS Lite wheels? for possible AutoX use, check this one out
- If I need an ET48, will an ET35 work with a spacer? (18")
- Falken, Dunlop SP2, Bridgestone P009
- Eddie/et. all sizing question 18 x 8.5 et 32
