- 2009 2.0t with P0776, Transmission Solenoid B
- 2009 ABS pump compatibility
- A new member with few questions.
- Milltek Catback and ARM DP, will they fit each other?
- 2 Piece BC forged wheels with PS4s
- DS1 flex fuel works!
- S3 headlight switch wiring diagram
- Audi A3 8p 2010 center console trim
- 2003 1.9 pd130 cam & crank sensor cable problem.
- Audi A3 Front Grill
- Pedal Commander on an A3 2.0 TFSI?
- Locking chirp.
- Pair key to driver mode
- Rear wheel hard to turn
- New Forged Carbon Paddle Extensions
- Strange music....All speakers except 1 are silent
- A3 Cab Suspension Vibration
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- EPC Issue 2016 A3 2.0 Quattro - HELP!!
- Seeking indepedent shop for my RS3
- I need some feedback from the 2015-2020 Audi a3 2.0t Quattro owners
- Evap Hose and Filter Repair
- IL: I dont have Car Modes on my A3 Sedan
- Genuine "Quattro" Puddle Lights Are On Sale!
- Struts, Springs, and Spacers - Oh my!
- Fender
- CarPlay not working wirelessly
- Front end clunk after new sway bar end links
- Replacing fuel line connecting HPFP to the Fuel Rail
- A3 e-tron. What is EV battery replacement threshold?
- High Mileage Issues ? Warranty expires in 2 weeks. Should i Extend?
- looking to update mmi system
- ZA: Audi A3 1.8L 8V turbo goes stututu after tuning it?
- 2022 S3
- High pitch noise when steering left
- Audi A3 8V springs
- Rare Porsche Green 2018 Audi S3 on CarsandBids.com
- A3 vs S3
- Rear view camera stopped working
- PL: RS DNWA choke and hesitation
- UK: Please help me, A3 diesel
- MY17 Failed Front Passanger Strut
- Audi A3 S-Line questions
- Audi A3/S3/RS3 8Y Lane Departure Warning
- Your Winter Setup
- PL: Audi a3 2.0 tfsi 2016, 43.000 miles Quattro weird engine sound
- Squeel/Buzzing WHen Shifting to D/S
- Swap Proposal: Black Trim Pieces for Chrome Trim Pieces (8Y)
- Felt battery cover torn up after dealer visit
- Issue Pumping Gas
- Possible Haldex issue.
- 2015 Audi S3 Part Out
- CY: Dehybernate after long time storage?
- UK: Advice needed for the prospective purchase of an OBD scanner for my A3
- Horn hard to press
- UK: lost communication to tcm and other error codes
- 2021: cannot delete key user
- 2018 S3 purchase
- 2016 A3 2.0T Quattro (8V) Seat belt question
- The 034Motorsport SummerFest Dynamic+ Tuning Sale Is Here At PartsByTopher!
- RS/Honeycomb grill for S3
- S3 Coding
- Audi A3 8P1 door compatibility.
- Help; MMI works but sound disabled
- DE: OEM tyres?
- 2023 S3 Order Guide Pages
- Ambient Air Sensor
- Audi A3 1.6td ultra high miles
- 2015 Audi A3 4 Cylinder - Would Love Help How To Resolve 3 Error Codes - FUE CAT 025
- drls completly turned off when headlights on
- AUDI A3 2014 MMI Flickering
- Audi s3 2.0T with 292 bhp?
- OBDEleven reports fault code P164E00
- RS sport exhaust for 2022 RS3
- 2015 A3 code: P256300
- MMI Navigation or after-market Android Auto?
- Mods - Have you considered making MKIII forum
- 2015 A3 Trunk Trim Removal
- DRL headlights half-off on both sides
- Camera problem
- '19 S3 vs '22 S3
- Can E-85 Ethynol Blend gas be used in A3 E Tron?
- MMI with no navigation
- Virtual Cockpit Overheat Shutdown
- Question for original long term RS3 owners
- 2022 RS3 Turning Circle/Parking
- Steering wheel w/o Virtual Cockpit retrofit
- 2022 RS3 Service manual for purchase?
- UK: Driving the 2022 Audi RS3 OVER 100MPH!
- 2016?
- Lowering Springs
- Need help I’m out of ideas
- Top View Camera in new A3?
- Audi S3 8Y Winter Wheels/Tires
- 2018 TTRS error code P2015
- 2019 A3 Passenger Side Buzzing/Vibrating Sound
- Audi A3 1.8 tfsi 2014 won’t start
- 2018 audi A3 quattro 1/4mile
- Oil Sensor message
- 2017 S3 Misfire
- A3 e-tron sportback 2016 overnight battery drainage
- getAudiparts.com | NEW Genuine Audi Dynamic Center Caps Sets!!
- Squealing sound while coasting
- Navigation Map update
- UK: ABS CODING?
- Should I consider a car that was side swiped?
- Cracked my oil pan I think
- 2018 s3 cold start idle problem
- 2016 Audi S3 Front Brake Pads Wear?
- 2017 A3 Brake and Rotor Replacement
- Buzzing noise coming from engine area?
- 2014 S3 8V knock/click sound when releasing brake pedal
- door handle rattle 2018 RS3
- Bike rack - Seasucker?
- Keyless entry/exit installed but (sort of) not functioning
- S-Line steering wheel emblem
- Need some advice.
- PODS and PCV recall with Uni Tune
- Whining sound only in 4th gear.
- Fuse F22- No power supply
- New Models - A3, S3, RS3 8Y Parts Section is Open...
- Audi S3 Magnetic Ride Replacement
- Best tune for 2018 A3?
- Active Lane Assist
- Audi A3 8V ECM fault
- TTS Supersports I’m S3
- RS3 Drive System Malfunction
- How is the chrome trim removed / refitted?
- How many radiators??
- Misfire? 2017 A3 Quatro 2.0T
- 2017 S3, 48k miles, $33.5k. Buy or no?
- Idle Rpm in sport mode
- New wheels, what et?
- Audi A3 8Y-8Y rubber mats. Original
- Jerk/lunge at very low speed.
- 2022 Audi S3 cloth Matt’s.
- S3 vent rings
- E-tron battery life
- Sound coming from steering.
- Considering IE Stage 2 8V A3
- Duplicate MP3 On 2021 A3 MMI
- is there caps built into the front tweeters & 3inch mids to keep the proper hz?
- 2022 S3 Order with allocation
- Fuel guage reads 2-2.5 gallons low?
- HELP : Turbo + oil pressure problems Audi A3 8V
- Audi A3 8v coolant?
- 2015 A3 Coolant Temp Sensor location
- Ideas for diagnosing creaking and thunking noises?
- Finally--Amber rear turn signals
- Loss of coolant issue.
- Audi A3/S3/RS3 8V Power Folding Mirror Retrofit - Full Tutorial
- Lost my diffuser looking for part number
- S3 Wheel Help!
- UK: Cam belt?
- STronic not working well - A3 2.0 TDI 2019
- AU: Engine data display and upshift flashing Module
- Steering Wheel Torque Spec
- Adding drive select
- FYI 2015 S3 rear rotors replacement
- Question on Audi Care and extended warranty
- UK: Limp mode!
- Fuel Tank Size?
- What scan tool do you use for your A3, and do you wish you had something better?
- Picture log of my new to me 2017 A3 Quattro
- Cabriolet hot air through vents with top down
- Virtual Cockpit
- RPO code confusion
- [S3 8V] Full Led Headlamp problems
- SE: New wheels question : RS3 `19 Sedan
- Audi A3 8Y (2022) Adaptive Cruise Control
- Need more horsepower!!!!!
- Paddle shifters
- UK: Wheel centre star caps
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Black Friday / Cyber Monday SALE ON NOW – Best prices of the year!
- Inflation Relief - Black Friday thru the end of November Sale...
- UK: 2017 front rattle noise over bumps
- Electrical problems
- S sport package worth it 2022?
- A3 Sportback Etron charging time registry
- Heated side mirrors malfunction
- Location and Replacement of heater control valve
- S3 Stage 3 reliability with 50k+ miles ?
- A3 November allocations
- Audi A3 8v heater blowing cooler on passanger side
- HR: Audi a3 sedan 2016 turn signals
- particul filter Pressure sensor is right place? HELP
- DS1 vs Unitronic?
- Rough idle in A3 2.0TFSI after cruising on highway for 20+ miles.
- Weird squeaks from the car
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- Looking to purchase 2018 A3 Cab (Prestige)...
- CA: RS3 Recall Preventing Purchase at End of Lease
- remote CP removal help if possible for VC retrofit
- No regen charging in S mode during long trip
- 8V S3 MMI Bugs
- Front grill license plate delete
- TR: A3 1.6 TDİ 2014 YEAR, I NEED HELP, P2456 FAULT
- Rs3 2018 help
- halfway done with retrofitting power folding mirrors and side assist
- High Mileage
- Mmi screen wont auto down with ignition off, weird message
- S3 For Daily?
- UK: The right splash guards / dust shields for S3 sportback?
- UK: A3 halogen lights
- VCDS Instruments
- Hood Release Keeps Failing
- Keyless Entry
- AN: Car keeps braking by itself
- 2018 A3 e-tron 16" Wheel Offset - Winter
- A3-E-Tron-3 yr/36,000 miles - $3400?
- Disabling Rear Cross-Traffic Assist?
- Heater Motor Resistor
- UK: Slow WiFi speeds in car
- A few problems that may be connected (key, key fob,stereo 12v lighter)
- retrofitting side assist (blind spot warning)
- Buzzing Noise - Adaptive Lighting?
- Horn noise on take off
- Interesting Changes in Wed Site
- Driveline Vibration
- UK: Help, A3, clutch
- Help!!! MY18 A3 LED headlight DRL coding.
- MORE OUT OF MY TURBO ? HELP!!!
- Audi A3 8V 2.0T Engine Start System Malfunction
- 2022 A3?
- AU: 2015 S3 WING (fender) MIRROR REPLACEMENT TROUBLES
- New 8Y RS3
- Which A3 should I go for?
- 2015 Audi s3
- A3 Cabriolet: A/C automatically turns on when top put up
- Audi S3 8V 2018 Misfire when warm Fuel quality inadequate
- Problems with the launch control - Audi s3 8v 2016
- 8v A3 2015 Headlight Flicker
- 2022 S3
- 2018 S3 -- Total Loss?
- 2015 A3 reliability
- A3 Quattro rough shift - TPI code 2053306/4
- Carly AC Coding Help!
- CEL - coolant bypass valve stuck
- Part Identification - 625 0260 00
- ANCEL VD700 Scanner makes my A3 drunk
- Audi A3 screen mirroring
- A3 8v Android Auto
- Small PA Speaker Location? Under the hood?
- Audi Debuts RS Torque Splitter on 2022 RS 3 & Interview with Audi Test Driver
- Do repairs at Audi dealers get put on vehicle record?
- DIESEL TDI -- whos got one?
- Need new Diff?
- Brake pedal jiggle on start up?
- 2022 A3/S3
