PDA
View Full Version : Audi A3 / S3 / RS 3 MKII
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. P0191 Code came back post fuel pressure sensor replacement
  2. UK: I've always wanted an a3 but....
  3. Bought the Orange 2020 Q3
  4. Where is the SAI Relay on 2015 A3 1.8T?
  5. 2016 RS3 : Which brake kit...
  6. A3 Sportback 2017 retrofitting USB ports CarPlay
  7. ARMASPEED Audi A3 8V 1.4TFSI Carbon Fibre Intake
  8. read error when trying to access nav data
  9. UK: Oil filter help
  10. Burning oil
  11. new here
  12. Cool website for build planning (motormia.co)
  13. Carplay 12.3inch screen for Audi A3
  14. Audi A3 Quattro 1/4 tank missing bucking
  15. Looking for a turbo pipe washer/seal
  16. HIGHLY irritating 'squeak' in 2016 RS3
  17. SPEECH DIALOGUE MENU
  18. 2018 A3 replacement Keyfob
  19. Escape from Pothole Money Pit with 225/40R17 vs OEM 225/45R18 ?
  20. Coolant leakage
  21. Firmware Update Virtual Cockpit Audi A3 8V error message
  22. Audi S3 Coolant issues
  23. Weird misfire issue
  24. 2016 a3 DSG Hard shifts/Vibrations
  25. Both USB Ports are dead 17 A3
  26. 2015 Audi A3 rear passenger fender noise
  27. Coolant leaking from front of car
  28. Would 20 inch wheels on 8.5v Audi S3
  29. Anyone here had a white bagged '18 S3 in NJ that was stolen last year?
  30. Screen not working rs3
  31. Replaced mirror with Homelink one?
  32. Used A3 I bought has a steel skid plate. Should I replace with OEM plastic one?
  33. Android Auto without USB
  34. Audi A3 8V MMI Issue Up and Down - Help!
  35. audi a3 8v replace alternator
  36. Stalling
  37. 2015 A3 2.0T burning engine oil...
  38. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  39. UK: Help needed to repair dipped bulb
  40. Audi RS3 Rear wiper starts automatically in heavy rain but is in off position?
  41. Apple car Play
  42. Coolant level
  43. Best CarPlay module for 2015 A3 in 2024? Tons of options.
  44. DIY Virtual Cockpit firmware update
  45. TCL, TPMS and other issues after tire change
  46. coolent issues
  47. DIY Audi MMI (MHI2) firmware update
  48. MMI display
  49. UK: S3 shock absorber?
  50. Rumbling/ Rattling noise
  51. Should (can) I push for a new battery with my new 2019 CPO A3?
  52. 2015 Audi A3 1.8 Premium - won't shift into second upon start
  53. RS steering wheel controls not working
  54. Map Upgrades
  55. Audi RS3 Sunroof Controls Acting Up
  56. tire pressure
  57. A3 E-tron parts cars
  58. 3dr & 5dr front end parts compatibility 2013-2016
  59. pistonsettlement.com may be worth a look for folks here
  60. BATTERY REPLACEMENT
  61. Lifting a3 e-tron with 2018 tiguan springs?
  62. A3 8V Wheel Fitment Advice
  63. UK: A3 Sportsback 2020 2.0 TFSI Quattro Tyre Pressure Help!
  64. 2019 A3 Scraping Sound at Low Speeds
  65. 2015 Audi s3 8V shifting issue
  66. iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
  67. Stumped- P008700 2015 A3 8v
  68. Driver side window won’t roll up
  69. Dizzy from Lease Buyout
  70. Mileage and Issues ?
  71. Audi A3 8V Wheel Fitment
  72. Electrical System Limited Error 2022 A3
  73. 8V S3 Stalling when cornering with wheel slip
  74. Car shimmies under hard acceleration
  75. How to change a rear wheel bearing on an AUDI S3 8V
  76. New transmission recall/TCM update on A3?
  77. 2020 Audi A3 Oil Level system malfunction! Please contact service
  78. Reset Steering Angle Sensor
  79. Front registration plate stuck
  80. 2015 A3 Quattro EPC Misfire 4 mystery...
  81. Broken rear seat release cable A3 Cabriolet
  82. 2015 Audi A3 Quattro 2.0T EPC and Check Engine light on
  83. Connectivity Package
  84. Christmas Holiday Sale
  85. A3 Cab rearview Mirror repair.
  86. Power mirror trouble
  87. Navigation initializing stuck at 11%. Does anyone have an update file?
  88. 2023 Audi RS3 Evap Leak? Is this normal?
  89. Single beep every 30 seconds with the ignition off
  90. Help rs3 possible water flow issuise
  91. Steering and faults 2021 a3
  92. BLACK FRIDAY SALE,, SuperSprint Italy
  93. Free RS3 Dynamic Package front wheel
  94. 2015 Audi A3 stalling
  95. 225/45/18 Will the rub?
  96. 2017 Audi s3 making knocking noise
  97. Missing Option for Tire Pressure Monitoring?
  98. Audi A3 E-Tron to RS3 body kit conversion/facelift
  99. Do 2020 RS3 and S3 Share Same Front Bumper?
  100. Audi RS3 8V (2018) latency at startup
  101. 2013 Audi a3 TDI rear right outer tail light not working
  102. 2016 A3 Rear view mirror bottom flip tab suddenly super stiff/clicking
  103. Weird sound after turn off the engine 2.0 TDI
  104. Will this part fit my A3
  105. 034 Motorsports Tune
  106. EPC and now Check engine
  107. Rebuilding rear differential gen 5
  108. NL: Audi A3 1.6 BSE, rough idle, catalyst error
  109. ARMASPEED Intake for my 2017 Audi A3 1.0 TFSI
  110. Audi A3 8V FL aftermarket stereo, no sound quality.
  111. 2006 A3 8p 2.0 TFSI Trouble Getting Into Gear
  112. HR: Audi S3 8v facelift 2017 LED headlights problem
  113. 1.6 TDI Cold Start Issue
  114. 2017 A3 - Audio System - Dealer or Independent?
  115. Transmission issue
  116. Issues with the Seat Heating in Audi A3 8p Model Year 2008
  117. 2016 vs 2018 RS3 (EU Spec)
  118. New Member – 2018 Audi A3 Seat Belt
  119. 2015 a3 2.0t whirring noise
  120. S3 2017 ERROR CODES
  121. Quiet Intake and Blowoff Valve
  122. Audi S3 Issue - Need Help Troubleshooting
  123. Should i Cash in on the current Value of My S3?
  124. P1443 EGR Fault.
  125. Audi A3 1.4TFSI 2011 Manual Cluster alternatives
  126. Bypass or spare key for a 2006 A3
  127. Cornering/Turn Signal Fog Light
  128. 02 sensor bank 1 Audi A3 8p 2.0tdi
  129. A3 Trunk Latch
  130. Questions about Audi Connect
  131. Camshaft intake timing is wrong need realignment
  132. Mk7 r vs audi s3 FL fixed suspension handling
  133. UK: FRONT END ROTATIONAL KNOCKING SOUND HELP ME!!
  134. Upgraded bushings, now the car doesn't align properly
  135. EPC and Check Engine Light on 2015 Audi A3 1.8T
  136. 2015 S3 Rear Brake Caliper Issues
  137. 2018 a3 mmi swivel wheel
  138. Hight Mileage S3's
  139. Rear Backup Camera Never Appears
  140. A3 suspension
  141. yet another post of troubleshooting ABS sensors/module for false low tire pressure
  142. OBD reader/maintenance reminder resetter advice
  143. 2018 S3 Wheel Specs?
  144. Gearbox Malfunction, no reverse gear
  145. PSA: Check your rear control arms
  146. Temp is high
  147. CZEA engine Still problematic?
  148. NZ: 2018 RS3 chain slip?
  149. Audi s3 cruise control unavailable hill hold assist unavailable and parking brake
  150. Audi MMI Compatability
  151. EPC + Check Engine light on - cylinders misfire
  152. The Audi A3 is better than the S3 (Hear Me Out)
  153. A3 2009 sportback
  154. A3 8V2 USB install - how to connect + and - ?
  155. Power windows not working & safe on cluster [A3 2004]
  156. 2015 s3 misfire after engine swap
  157. Audi RS3 2015 Start/Stop
  158. Have i fried the electronics?
  159. American message board members.....
  160. Emissions issue - O2 sensor values
  161. 2017 battery drain
  162. 2017 A3 Premium DRL question
  163. A3 8V Throttle Issue
  164. Mechatronic Valve Stuck Open
  165. Drivers side brake/tail light/ turn signal out no power
  166. CNTC Engine Replacement
  167. High Milage S3?
  168. Can someone please help me find my EGR valve
  169. Rear window drivers side will not open
  170. Greetings from SuperSprint Italy
  171. Will 2023 RS3 Wheels fit on a 2020 RS3?
  172. Goood Shop Near Danbury, CT?
  173. Activate High beam assist
  174. 2015 A3 Audi Pre Sense: system fault
  175. Audi r8 brakes on a 8v s3
  176. A3 8V Gets stuck in gear and fixes itself when restarting engine.
  177. Break Pad options for RS3
  178. rattling/clattering sound when warmed up
  179. 8V S3 Whistling noise from engine bay under hard acceleration
  180. 2015 A3 1.8L ODB2 errors will not pass inspection
  181. Noises after car is turned off!?
  182. A3 Etron EVAP system leak N80 purge valve location
  183. I think I broke my Haldex testing Launch Control on a stage 1 tune. What code should
  184. Audi A3 Brake System Specs
  185. A3 defrost actuator?
  186. A3 defrost actuator?
  187. Problem with puddle lights
  188. What is the wiring loom for
  189. CSF S3 radiator?
  190. 2015 Audi A3: No sounds from speakers (intermittent)
  191. back window will roll up but then get stuck and go back down
  192. AU: Wheel lock up when I exit a parking bay
  193. Bruised fingers trying to disconnect the door harness connector for speaker wire inst
  194. Will low brake pads through a sensor on the dash?
  195. Front Susp. Way too Harsh?
  196. A3 -15 1.6tdi S Tronic upshift problem
  197. 2017 S3 DRL Issues
  198. Distance Warning Unavailable + Presense Limited warnings [2017 A3 e-tron]
  199. OZ Superturismo Evoluzione 19" fitment?
  200. About that Resonator Sitting in Your Garage...
  201. Help Tranny swap!
  202. Engine swap
  203. Increasing aspect ratio on 19 inch wheels vs downsizing to 18 inch wheels
  204. oil consumption
  205. Transmission Oil Temperatur/Speed Sensor
  206. MX: 1.4t A3 8v; EPC light; no symptoms; car shuts down
  207. Window drops 20mm, but doesn't rise when the door is closed
  208. audi s3 8v knocking noise
  209. Oil leak after service
  210. Leak in front of rear wheel on driver side
  211. 8V - good location for Amplifier Remote-On wire tap in the trunk
  212. A3 2015 - - MMI stuck down. Possible to use app or hardwire?
  213. S3 bent valve.
  214. 2018 A3 E-Tron: Does not charge to Full 100% (stops at 7/8)
  215. Chirping Noise from Engine Bay After Shutoff - 2016 S3
  216. 2015 A3 2.0 Sedan Trunk Trim Removal
  217. UK: 1.6 tdi, rattling noise at idle, Audi a3 2014
  218. Gearbox speed sensor faulty
  219. License plate light issue
  220. Hate to do it but.....tires?
  221. Rear wiper motor failed
  222. Audi 2018 - maps update
  223. 2015 A3 Jerky Transmission
  224. Need electrical assistance 2018 A3
  225. Carbon ceramic discs REFURBISHMENT
  226. Questions about 2017 Audi A3
  227. Codes after Engine swap
  228. Oil specification for audi a3 2018?
  229. Audi A3 e-trons hitting market with buybacks
  230. S3 8v rear diff oil
  231. Boot stuck when changing spark plugs
  232. Audi A3 2020 8Y wireless carplay
  233. A3 40TFSI SLine upgrade
  234. 2019 RS3 Sedan Wheel Dispute with Original Rader
  235. Audi A3 8V - S-tronic problem?
  236. Pfl 8v rs3 PCV replace help
  237. Need advise before going to dealer about EV battery replacement
  238. Cylinder Order S3 8v
  239. Wiring problem S3 8V
  240. Several MMI buttons not working..
  241. S-Tronic DQ-250 (DSG) issue on Audi A3 TDI
  242. Fender Liner Splash Guard A3 2019
  243. Retrofits and CAN bus
  244. Help with Build Sheet A3 Cab
  245. Smog checks and drive cycles?
  246. What fuse is for the OBD port?
  247. A3 runs fine one day, next day will stall out
  248. Boost leak
  249. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  250. Audi s3 08852 fault code
