PDA
View Full Version : Suspension Tuning Discussion
Pages : 1 2 3 [4] 5
  1. Looking at Eibach Pro-System Kit- can anyone find a price quote?
  2. Strut Tower Braces..Opinions? Best ones?
  3. 04' S4 Stock suspension on 98' A4?
  4. suspension
  5. KW Suspensions... the good the ugly? Thoughts needed....
  6. A6 4.2 spring rate.
  7. Stripped Axel Bolt, What do I do?, 14mm Hex, B5 S4
  8. Suspension upgrade on a B6 S4
  9. New Alignment = issues. Front sway bar linkage now rubs on the half shaft. Input needed..
  10. Installed Vogtland COs on the S4 yesterday... some issues
  11. Question for you A4 guys that have done the S4 swap...
  12. Sway Bars
  13. H&R Sport and Bilstein issue A6 C5 Quattro
  14. Eibach Pro Street suspension
  15. WANTED SUSPENSION ---A4 QUATTRO 2002
  16. Have 00 C5 4.2 w/stock springs..how much lower are Audi Sport Springs? I have
  17. suspension clanking
  18. 2001 1.8T sport suspention on 1996 2.8?
  19. A4 Shake, Rattle and Roll
  20. Coilover plastic/nylon washers.
  21. Help: Looking for B7 A4 Coilover install instructions
  22. noob suspension questions
  23. Bilstein PSS9 (B5 S4) dyno results, and suspension ramblings.
  24. Where is the best place to get Ball joints and control arms from
  25. need help identifying a spring
  26. B7 Sway Bars
  27. H&R Race vs H&R Sport springs
  28. mikeKiM@Purem or Tomasz@ StartupRacing, Where I can obtain some coilover spacers
  29. want H&R sport springs, anyone heard of "camber issues" after installing different springs?
  30. How to change suspension on A4 -07?
  31. Front Sway or Rear Sway? Which one would you do first?
  32. adjusting rear H&R coilovers
  33. Looking for sport suspension for my 98 A6
  34. Shock/Strut replacement for 2001 Audi A4 2.8 QMS
  35. Question about lower spring rest on Koni front struts (A4 B6)
  36. Coil overs?
  37. New Audi Parts
  38. Do strut mounting brackets need to be replaced in pairs??
  39. I've changed the shocks it rides a lil better but still rough
  40. Is buying used Sway bars a good idea?
  41. Alignment question
  42. cambre off when doing alignment???
  43. rusted inner/outer tie rods
  44. Neuspeed sport springs w stock (premium pack) shocks on A3....thoughts? TIA.
  45. Question for Mike?
  46. do these springs look progressive
  47. Koni - H-sports...what springs
  48. B5 A4 Suspension Question... Please Help!
  49. anyone play with ride height on a B5? I'm looking to set mine before alignment
  50. Anyone have experience with Shine Racing's B5 coilovers?
  51. Eibach springs
  52. Fraud warning....DO NOT BUY FROM DRIVE WIRE .COM....
  53. Vogtland Coilover CD
  54. H&R Spring install
  55. What spring tool did you use to change B6 A4 Avant rear springs? Nothing I have will fit!
  56. Anyone running Koni FSD and OEM Sport springs A4(B6)?
  57. 97 a6 quattro i add 18 inches wheel and now i have a camber can any one help me
  58. 97 a6 quattro
  59. The boot on the steering rack is torn...what to do.
  60. Front Upper Control Arms...
  61. Adjustable camber plate
  62. Anyone have Koni Sports shocks with Eibach springs on B5s, specifically B5 S4s? TIA
  63. Unusual Sports Suspension Set-Up
  64. coilovers
  65. Noticing some noises with new Bilstein sport shocks
  66. Ok here it goes. Replaced suspension 2K miles ago.
  67. Crazy Marty's question about koni/hr sports
  68. Dropped my B5 A4....
  69. 99 A4 2.8Q Shock Recommendation
  70. '03 A6 4.2 Suspension Advice.
  71. I just bought Bilstein and H+R combo to replace my stock non sport suspension, question ro/
  72. anyone have the Eibach pro street coilovers? opinions would be appreciated
  73. anyone with vogtland spring and koni sport shocks. I have them installed in my B7
  74. Adjusted KW v2 coilovers and portion of adjust plate cracked. Is it still safe to drive until fixed
  75. a4 fwd help
  76. A6-RS6 Suspension
  77. Anyone running Eibach Pro-Street coilovers on their car? Preferbly a TT.
  78. PSK Sway Bar for Avant
  79. 1996 A4 suspension makes noise when I go over small bumbs. Any ideas??
  80. STaSIS Engineering's new website is up and running, take a peek...
  81. Alignment on new suspension
  82. Adjustable suspension and self-leveling xenons.
  83. Suspension noises
  84. Poll...b5_s4..Brand of coilovers?...Likes/Dislikes?...Early Control Arm Failures?
  85. 2001 A4 rear strut upper bolts (are they stretch bolts?)
  86. Anyone else have this problem?
  87. Koni FSD or OEM non-sport shocks for full comfort?
  88. Questions for Eibachs/Konis - Post Installation
  89. Can't find the easy answer, have to ask...The Term "coilovers"...
  90. Replacing 1999.5 a4 control arms...is this a good buy/ or any recomendations?
  91. noob question: pls let me know if the B6 S4 suspension will work on B6 A4's. TIA
  92. Stasis Tracksport Suspension - On Sale B5 A4 / S4 Quattro
  93. rear drivers side riding low
  94. Thank you lord for sway bars ...
  95. B6 suspension advice
  96. Need a little help
  97. QUESTION: H&R vs Koni coilover?
  98. Question: Allroad Pneumatic Suspension
  99. Control arm kits on ebay...
  100. Help - Suspension question ??
  101. Will the ECS coilover kit be OK to use?
  102. '91 CQ: OEM springs/Bilstein HD's or H&R/Boge Turbo combo?
  103. H&R Race & Bilstein Sport... I know
  104. anyone own the VW/Audi 2069 suspension tool
  105. HELP !!!! To all with audi sport suspension
  106. Where to get Tein SS....
  107. Koni/Vogtland or Bilstein/H&R?
  108. Strut Question on 2001.5 A4 avant with stock non-sport suspension
  109. Some question about changing suspension by myself...
  110. Which Coilovers?
  111. Bilstein PSS Suspension or StaSiS StreetSport Suspension ???
  112. loose control arms
  113. Do sway bars really make a difference?
  114. Any recommendation for B7 Avant's suspension?
  115. Will S4 shocks/springs fit A4 as well?
  116. March 19th Jones Beach gathering
  117. any economic way to low down A4 (B7)
  118. 02' A6 4.2 Sport Suspension looking to soften up the ride. Need help!!
  119. Looking for good springs & shocks
  120. Ife expectancy of OEM suspension
  121. impact on camber after coilovers?
  122. Where can I find the best price on H&R coilovers and H- sway bars for an 06 S4?
  123. stock suspension noise?
  124. Who can tell me what would happen if I did this?
  125. will koni coilovers for 2005 S4 fit an 06 S4?
  126. Tech Session by Audi Club NW and Speedware
  127. Is it safe to remove the plastic fender liner in the rear well?
  128. Who's replaced control arms? Which kit is best...Febi or Meyle? With a $150 difference
  129. anybody have neuspeed race springs on a b5?
  130. Suspension advice for B6 A4
  131. what suspension should i buy?
  132. Looking to buy Vogtland Coilovers...
  133. Neuspeed Springs...rear a little low - B7 Avant
  134. Your recommendations: biggest bang for buck in handling
  135. I have the Vogtland Sport Springs installed on an A4 B7, and have a question?
  136. suspension setup for b5 2.8Q
  137. Eibach pro street kit, first impressions
  138. Looking to lower my car, A few questions?
  139. Quattro springs on FWD
  140. How do you like your Abt springs?
  141. Anyone using INTRAX Lowering Springs on A6 2.7t?
  142. I have H&R Race springs w/Bilstein shocks, height is too low, 24.75". looking into ECS c/o kit
  143. Audi Eurosport sport lowering springs
  144. A4 2.8 AWD swap w/ S4 Shock/Strut/Swaybar
  145. Odball coilovers
  146. Question for all you B6 A4/S4 PSS9 owners
  147. aftermarket suspension vs. extended warranties
  148. tool for crimping clamps on cv joint; what's it called, where can I get it? any links?
  149. OEM Sport springs
  150. NEED SUSPENSION HELP
  151. B5 Suspension options
  152. Strut gone bad?
  153. D2 coilovers, are they any good? 36 way adjustable.
  154. PSS9/H&R Coilovers for Audi TT QR
  155. Lots of suspension questions
  156. Hey guys, I just bought some coilovers, anyone in the NYC/Westchester area?
  157. I have 2001 S4 and Stasis SS.. with 25" all around.. anyone has good alignment spec?
  158. 01 A6 2.7t non-sport with shocks that need replacement: What are the options? (criteria is inside)
  159. Planning to adjust my coilovers myself. Is it a good idea...
  160. Lowering 2001 S4 - Nothing crazy 1 to 1.5" drop
  161. H&R Race + Grooved Bilsteins = able to be aligned acceptably? Or not?
  162. Question about replacing springs with ones of different spring rates
  163. I have a 2001 2.7T with the KW Varient 3 coilovers. I have progressive springs
  164. Slight knocking over bumps.
  165. alignment question: my 90 stays straight on flat but is _very_ susceptible by uneven pavement..
  166. look A4 B5 speaker adapter rings for front door
  167. Final Suspesion Question Long (Vogtland/Eibach/H&R)
  168. Trade my suspension for A4 sport
  169. kw suspension for sale for a b6 quattro a4
  170. alignment question: my 90 stays straight on flat but is _very_ susceptible by uneven pavement..
  171. suspension recommendations...98 A4Q
  172. What is the maxiumum negative rear camber with OEM arms?
  173. weird rubbing on passenger side.
  174. Springs for Audi 80 V6 Quattro
  175. Vogtland COs + Sways?
  176. have a used set of Hyperco Linear Rate Springs from Stasis...
  177. anyone ever send shocks to bilstein for custom valving?
  178. Anyone know how to adjust the rear wheel toe in on a b6 a4/s4?
  179. Swaybars for 2001.5 S4 Sedan and 2002 225 hp TT Coupe
  180. Airbags
  181. Body and Frame info *Urgent Help*
  182. what is the effect of my rear springs' lower 4 coils being compressed to the point of contact?
  183. Koni Shocks, Eibach Springs & H-Sport Sways...Question
  184. A4 B5 FWD
  185. Shot/Strut Choices for a 95 90q ?
  186. camber
  187. Anyone with a C5 Sport suspension FS?
  188. H-Sports arrived.
  189. A6 UNEVEN RIDE HEIGHT
  190. First Ride with the AWE Drive Train Stabilizer..
  191. audi sachs suspensions
  192. questions about damper adjustment (S4-b5 X-post)
  193. Stasis Motorsport suspension on sale at Achtuning $3750 shipped*
  194. Springs for B7 Avant? anyone know who's producing them now?
  195. A.W.E. Tuning at H2O International September 25th
  196. 5000 to 4000 switch?
  197. stasis streetsports height adjustment (cross post)
  198. coilovers?....why not?....and what about a camber kit?
  199. A6 front strut support bracket........
  200. OEM S4 Rear Sway Bar
  201. Who's the NA supplier for KW Suspensions
  202. Paging Ryans4 - Suspension Questions
  203. Yum, another one shipped...
  204. Suspension for B4
  205. Service life of oem sport suspension?
  206. H&R SPORT SPRINGS
  207. WHEEL SPACERS
  208. A6 sway bars
  209. 06 A3 Swaybars?
  210. x-post: alignment question....................
  211. front upper strut tower bar
  212. Lowering an A6
  213. OT: But i always Find MikekiM@PureMS here and i have a question for you.
  214. wanted lowering shocks b5
  215. could someone explain sloting strut mount to correct alignment problem...
  216. Tein Coilovers Basic Damper Kit
  217. 2000 A6 2.7 6sp....
  218. For the record, installing coilovers in B6 A4/S4 is way more difficult than B5s
  219. suspensions...what the heck?
  220. Need suspension advice/opinions (xpost from A6 forum)
  221. Is 1.8 A4 sport susp the same as 2.8 A4 sport sus? (B5)
  222. how would the ride be on a 2001 A4 with this setup...
  223. Stasis Tracksport coilovers
  224. Anyone with B5 2.8 sports susp for sale in Nor Cal, I could be interested, TIA
  225. What should be the next platform for our suspensions...
  226. replacing links..
  227. rattle
  228. Where could I get the alignment specs (toe setting) for DIY...
  229. Project B6 A4 Article updated with Suspension modifications - see Audiworld homepage
  230. Anyone know anything about AST Suspension?
  231. Lowering q's..
  232. need rear perches for b6 h&r coilovers. please help
  233. springs? or what?
  234. Installation questions for cup kits
  235. Lots of suspension questions.
  236. Have a question regarding my suspension...
  237. StartupRacing Competition Suspension Released
  238. Looking to upgrade my suspension
  239. Helper Spring Explained
  240. any one here running a koni sport kit?...good bad? 550 doesn't seem too high
  241. Any one know where I can get a set of front swaybar end links....
  242. KONI's!
  243. Bilstein Installation Advice (repost from A6)
  244. Koni coilover height adjustment for 2002 A4??
  245. Stock springs and struts for 96 a4 - 2.8L
  246. Why do my car drives like a boat?
  247. FS: OEM suspension B5 S4
  248. Anyone selling H-Sport Sways for B5?
  249. HELP, Bils or Koni?
  250. x-post: Suspension noise when cornering hard right.
