- 2008 A6 S Line aftermarket suspension advice
- recomendations for B5 A4 quattro susp. upgrades??
- What is the best susp. choice for B5 S4 - under $2k?
- noise
- Would installing front and rear sway bars require an alignment afterwards?
- dropping my b5
- Is this where you post when you get suspended?
- Rant: I hate my current suspension
- 2001 S4 Avant Coilover Suggestions
- B8 Suspension Options, Koni, Bilstein, H&R, Eibach
- HELP!!! Hum in suspension, details...
- suspension
- Getting rid of the Cadillac ride, 00 A6 2.7 6sp
- MK4 jetta ('99-'05), are the front struts cartridge replaceable or you replace the whole assemby....
- A4 B8 lowering - options?
- what type/series of koni shock was used on the original Stasis motorsports kit
- how many hours does it take to replace front and rear shocks on a 2000 2.7T
- Anyone ever put an Allroad airbag setup on an A6 ?
- Are these differences enough to warrant a change?
- 2002 A6 OEM sport springs
- Stasis Differentials
- RS4 Euro springs vs. US springs, any differences?
- URGENT Need Help hitting fender on a lowered B5
- audi q7
- Just got new Bilstiens for my 97' A4....Need Help
- Looking for input on suspension for a 2000 A6 4.2 Thinking bilsteins/H&R set-up. Any thoughts???
- How will this effect the handling???
- How much is it usually to install springs?
- For Sale Feeler Post! Stasis Motorsport setup for B7 S4
- Replacing struts... Is it safe to use spring compressors instead of a press?
- WTB: CPP adjustable front control arms for B5/B6 A4/S4
- b6 S4 after STaSIS Ohlins SL install (photos/links)
- looking to lower my 2000 a6 2.8 quattro, anyone selling coilovers, or recomend a brand
- Rear neg. camber help B5S4
- NEED HELP!! Replacing rear wheel bearings on '97 A6 Quattro
- autox'd today, had a slight suspension issue, need suggestions
- Need springs with ~500lbs rate
- On a Budget: suspension/wheel/tire reccomendation over stock?
- Ohlins SL for B7 S4
- Hokay... got my A4 with Vogtland Sports Aligned today... (specs below)
- '01 A6 2.7T w/83k mi, I like the ride except...the shocks are going...
- Koni springs for A3?
- Hub bolt on a4 98
- Thoughts on this suspension
- Calling all H&R coilover owners: underdamped/overly sprung?
- Anyone have comments on V-Maxx coilovers for a 01 A4 b5?
- Koni Coil Overs A4 B5 1.8T
- B5 A4: Differences between Sport and non-Sport suspension
- Group Buy on our GT Suspension Kits
- goin to install koni spring shock kit in my fwd a4 00 1.8t
- n00b help...can someone please explain spring rating?
- Half Baked Half Shaft Question (moved to Coupe GT forum)...
- the low down
- NEW KW V3 Coilovers FOR SALE
- nuespeed springs on '97 A4 2.8.. oem shocks work? will i rub with 17"'s?
- Advice needed on sway bars 2k7 A4 non sport upgrading to sport susp and rs4 rear sway, what size?
- Education...
- My new A6 with Eibachs...
- Group Buy Feeler: Vogtland GTs anyone? (my situation inside)
- Gaps between the body and the metal strut cap...
- B5 a4/s4 Bilstein pss9 Coilovers
- Shock/Strut for 05 A6 with Eibach Springs
- softest coilover if there is such a thing.....
- Question regarding Coilovers
- KMAC camber kit for B5A4
- Paging Tomasz@StartupRacing..... Got a few question about the GT Vogtland Coilover.
- Wear on outside portion of front tire means?
- How hard is it to align a A4 Avant 2004 properly? I have had the alignment done on my
- Anyone looking for a set of Bilstein Sports for their A6 2005+ C6
- How does the Eibach Pro-System on C5's compare to factory S6 / RS6 (ride, height etc.)?
- Stratmosphere Springs
- How do I identify sport vs. non-sport OEM suspension?
- Xpost: What else besides control arms, sway bar links, tie rods should be replaced in the suspension
- Anyone have the same problem with their s-line suspension?
- B7 with s-line - spring recommendations?
- creaking suspension anything to worry about?
- Audi A4 Quattro V6
- working on upper control arms a6..., need help
- Recommendations for springs/shocks
- Running H&R Sport springs with S4 Bilsteins?
- Shock/Strut fitment
- Springs, Shocks/Springs or Coilovers?
- Re: bouncy suspension with Bilstein PSS9's and H+R Sway Bars
- Koni or Bilstein
- Any Forum Vendors have these Konis in stock?
- audi A4 01 1.8T (B5) want to change shocks to S4 ones
- B7 Retrofit suspension into a B6 HELP!!!
- About to pull the trigger on suspension but have a question...
- stock sports suspension sits lower?
- Bilstein PSS9 Perch Mod?
- '01 A6 Avant new Front struts: Bilstein? Koni? Other?
- H&R suspension products are available at A.W.E. Tuning:
- Suspension Mods
- who has the best prices on H&R coilovers?
- Adding positive caster and adjusting servotronic steering force
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- Suspension a-b-c's ..please help
- What's the deal
- So Mike@Purems, you have a coup code for me ;)
- alignment question
- Ran over major debris!!!
- B6 Suspension Mod Suggestions
- Selling Complete 02 Allroad Air Suspension!!! $1,800. Complete
- X-Post from b5 forum... nobody seems to know or want the answer the question...
- FK Konigsport Coilovers B5 S4 Quattro - $1100
- New setup recommendations needed
- Coilover question for manufacturers/suppliers/anyone who knows the answer
- I wanted to stiffen up the suspension and lower my ride. Can I shave an inch or two from current
- Rear Bilstein upgrade on 98 A6 Wagon (C4 chassis)
- looking for replacement shocks & springs for A6 2.8
- I've already searched archives, but can't find any concrete answers - 2.8 sport springs on 1.8T?
- Stripped bolt hole, subframe mount, opinions..
- what makes coilovers that much better?
- shopping for coilovers for the A3 2.0T...
- Best place to buy H&R springs, shocks and H-sport sway bars for 4.2???
- Axle shaft contacts spring perch on new suspension setup
- New control arm kit...harder to steer???
- xpost from b5 s4 forum re: camber settings:
- Verification: B6 A4 1.8t quattro susp (spring+shock) will work on B7 2.0t quattro right? TIA
- 2008 TT sway bars
- 1999 A4 Avant Quattro- Rear springs rubbing on struts
- so what's the difference between increasing compression vs. increasing spring rate
- Where to get coilovers for my C5 A6 3.0?
- Any way to add ride height and/or dampening controls to coilovers?
- steering problem on 2000 a6 2.7t
- Two questions for suspension experts - self-proclaimed OK too:
- need help with issue installing H&R Sports on '00 A6- clunking issue
- Stock Suspension for B6 S4!?!
- H&R Sport Cup Kit for a B5 A4
- Suspension recommendations for A3
- Squeaking is driving me insane! C4 A6
- Coilover suspension for a A4 B5 QT
- PAGING!! gonutz for Avant coil over kit
- Audie TT 2.0 T 2007 Damper rates
- Suspension Set Up
- Squeaking Noise
- xpost: Will the Eibach Pro Kit for 2000 A6 2.7T (Q)Sedan fit 1999 2.8 A6 Avant? Answers welcome...
- Had coilovers put on the car ~ 2 months ago. I was adjusting ride height last night... TIA.
- Question about Alignment
- New suspension up front...
- Spring Rates on Bilstein PSS9 S4 kit (B6 - S4 kit)
- Corner balancing and suspension question
- how do you know when to replace shocks
- Spring lifespan?
- Have to say I am very happy with susp. - Questions inside for Stasis cent. rear diff owners
- H&R Sport Springs ... remove all wheel gap?
- H&R coilovers vs H&R springs and Bilshten shocks.
- anyone interested in adjustable a4 upper control arms
- What is the best coilover system for an 01 A4 2.8 quattro? Thank You
- Already STFA but found nothing...
- differences in struts for A6 2.7T ('98-00 & '00-04)
- I'm currently running Eibach springs with stock shocks :) questions inside...
- Koni Coilover problem (broken spring)
- Rear springs sagging
- Car sits higher with new shocks
- 2001 A4 FWD: Question regarding suspension alternatives
- Bilstein Sport Shocks + OEM Sport Springs (should I use H&R Sport Springs Instead?)
- lowering a b5 a4
- B6 A4 V6 FWD Sport Springs Blowout. Save $60.00 at AWE Tuning
- Speed sensitive steering?
- Strut replace on 2001 A6
- Considering new suspension for my B5 S4, I need some experts to chime in:
- B5S4 setup question
- Any input on this??
- '00 B5 S4 T-Rod End and Lwr Rear Cntl Arm Failed Bushing Appearance??
- Bypassing the stubborn pinch bolt...lots of pics
- quatro gear box leaks
- Coilover/Camber help
- Question for the experts
- Not sure how busy this forum is, this is my first post here...
- B5 S4 Suspension options/alternatives
- Suspension Poll- my suspension is getting a bit "spongy" and I'm thinking of replacements..
- Where can I get goo service
- camber kit needed really BAD
- Will they Fit?
- bump stop question
- control arms or shocks and struts?????
- Unknown rear OEM sport springs.
- Multiple Flat Tires Problem (Phx people help too)
- Hey, I am looking for a used coilover kit or springs and shocks for my 1999 audi a4 1.8t quattro
- Corner Balancing / Alignment
- Clearing the air on our Gran Turismo Kits
- Will 2002 A6 2.7t sports suspension work on 2002 3.0 Avant?
- Q: In theory at least, when one changes from one set of wheels to another set of wheels with ...
- raising the rear bilstein c/o's-the entire assembly is rotating!
- What would you do with this setup 2005 B6 S4 w/Bilstein PSS9's and 19x8.5 rims?
- 2000 A4 Avant Suspension Change- Allroad Suspension
- Need Help Picking the right sway bar! B6 S4
- Looking into these suspension set ups on FWD A4T tip
- I want my H Sport swaybars......Ordered 1-30.....Still waiting :^(
- trying to change srut inserts on '94 100cs q
- Can a 00 2.7 S4's Springs (h&r) and shocks (bliestien) fit on a 1999 1.8T a4 earlier body style?
- Figuring out non sport suspension from Sport Suspension
- Is this any good ...K&W Coilover Suspension... there used
- Bleistein & H&R vs Koni & Vogtland need help asap
- Can I run H&R sport springs (1.75 drop) with 19's????? Please help!!!!
- Hi, need help on Stasis Koni Street Sport coilover install on 04 B6 A4!
- what's the B5 S4 sedan stock ride hight? 27f/26r??? already stfa.
- Magnetic Ride & Lowering Springs
- What would you recommend???
- Bilstein B16 PSS9 on A6 s-line 2005
- B7 2.0T FWD suspension
- Lowering Springs Installaiton Guide...
- I've got ~ 110K + miles on my H&R coilovers...
- need help changing lower control arms only can anyone help.......
- After Market Sport Springs?
- Still a little confused about which control arm bushings to torque at ride-height.
- Suspension????
- Kw Variant 1 on a 96 Audi S6?
- Racing suspension setup...
- Koni Coilover Kit - Rear Spring Sag?
- Suspension Alignments - Audi Dealership vs Private Wheel & Tire Shop
- Need to go back toward OEM for my 98 B5 A4 - do I need to change both coils and shocks?
- Upgraded suspension for my '95 S6 Quattro
- Weird handling after control arm replacement
- Advise on replacement struts and shocks for 95.5 S6
- Autocross Set-up
- Wheel Spacers
- On an A4 (B7) model with coilovers with dampening adjustment. What is the ideal settings?
- S4 shocks only in stock 1.8t
- ????? does anyone know how to install spring
- Need coilover help!
- How low can you go on a B5 S4.....
- X post. Any suggestions?
- Looking for Two New Front Axels, need help
- Help with suspension issue. Bottoming on the drivers side rear.
- B5 S4 Sedan versus Avant suspension
- how does ride height effect cornering for vogtland co's?...
- suspension advice for a FWD 1.8T 2000 A4
- tire wear diagnosis
- HPS Airsuspension
- anyone go from stock sport package to Bilstein HD or Sport shocks?...
- Progressive spring installation, does orientation matter? TIA.
- Koni vs. H&R --> Calling Mike@PureMS
- A6 2.7 suspension
- coilover ?
- Upgrading Stock Suspension on B6 A4 TQ...
- shock suggestions for a B5 A4 1.8T quattro...
- One of my Friend has S6 with PSS9
- need some help with choosing between coilovers and sport springs?
- Freaking out.....
- Strut Cartridge Installation?
- Audi TT suspension
- Can anyone compare and contrast the differences b/w the KW v3's and the PSS9's
- Suspension recommendations?
- Camber kit for '00 TTC w/ H&R coilovers
- anyone installed koni 82-2488 on 2000 4.2A6Q?
- I'm a suspension freak and I got news for you, A4 B7 with plain old H&R Springs works well....
- B6/B7 Vogtland Coilover Kit Impressions
- Anyone try Koni FSD?
