1997 Audi A4 Quattro 2.8 no start
Hi everyone!
I bought a 1997 Audi A4 Quattro with a 2.8 v6. The motor was junk so I replaced it with a used one. I've installed a new starter also. However I'm not getting spark and the full pump is not operating. However if I pull the relay cover off and manually operate the fuel pump goes on. I have a parts car so I've swapped ignition switch, ecm, coil packs, engine harness, relays, ignition module. I'm currently stuck. The car cranks but Doesn't start. Any help?? Thanks everyone!!!! |
VCDS codes?
Just checked and I have no codes
Still got no start. I have no power at the relay. If I supply power to the small stud at the bottom of the relay panel the pump turns on and I have spark but injectors don't fire. I switched the fuel pump relay with a known good one and still nothing. All grounds are good. I however do no have the front end on or. Would this cause a no start or am I possibly looking at a immobilizer issue?
