Hi, needs help on pairing Telus mobility Motorola V710 to 07 A3.
Hi, I can't seem to get the phone to work with the bluetooth function in my A3.
Here's what I have tried: -Turn on Bluetooth in V710, then select find me (the phone is discoverable for 60sec) -Press mode on steering wheel, the trip computer scrren says "insrt phone" -Few seconds later, the command says "phoe is not ready" Am I doing something wrong here?? My phone is Motorola V710 from Telus Mobility in Vancouver, B.C. Thanks. Jack 2007 3.2Q |
Yup you are doing something wrong.
The key is to use the phone to find the car, not the other way around as you are doing.
There should be a [Look For Devices] option in Handsfree section. That's what you should be using. RTFM for the proper procedure. |
correct, under Settings/Connection/Bluetooth Link.
