a/c air conditioner problem.
I made mistake wire the battery switching + and -
for 10 seconds. It blows fuse 16, 42. One blade fuse that located on top of the battery. I checked every fuses and changed if fuses looks bad even little. Now, everything works fine but a/c a/c compressor clutch isn't engaged when I turn on a/c. The fans spins when I turn on a/c. No leak point. I vag-com the car but no codes for a/c. Any place I need to check? |
Any ideas ??? I have the same problem, besides the blowing of the fuses
that's what I ve done so far since last year,
1. I checked both fan motors are working slow or high. 2. I changed coolant temperature sensor. 3. I changed a/c switch located on high port of ac pipe. 4. I changed fan control unit three times. 5. I checked all fuses. 6. I checked voltages that go to fan switch on radiator. both voltage around 11v. 7. I checked temperatures from climate control unit, all temperatures can be read find. 8. No voltage found connector that attached to compressor clutch even I set lowest desired temperature. 9. If I wire compressor clutch with battery directly, cold air blow in to car. I stopped here and build circuit with own switch and fuses, so if I switch on manually inside of car, I can have cold air. To prevent forgetting switching off, I wired a relay with air blow fuse, so I turned off the car, a/c is off even switch is still on position. |
but I will start to find the problem when I have time.
I just don't have any now. |
