car stumbles
Hi i recently had my ecu chipped in my 01' tt 225 and installed a forge 007p dv and everything was running fine with almost no hesitation until yesterday when I tried to floor it and the car stumbled horribly before pulling hard. The stumble happens about 3100rpm... What could this be? Any help would be greatly appreciated
MAF >
probably not coilpacks.
MAF
Re: MAF >
Do you know where I can get one for cheap?
Here ya go...
$112 bucks is the cheapest I've seen in a while.
PS. I keep a spare MAF in my trunk.<ul><li><a href="http://www.purems.com/products/product.php/II=1747">pure motorsport dot com</a></li></ul> |
could be a MAF - could also be time to do either sparks or coil packs.... or both
I had a similar issue with higher boost and the car would stumble... swapped MAF and had same issue.... how many miles?
Re: could be a MAF - could also be time to do either sparks or coil packs.... or both
car has 68k miles... i also need to change plugs to 0.028" gapped ones
Got my MAF in today and it did absolutely nothing... any other ideas?
new sparks and coil packs
Re: new sparks and coil packs
does oreilly's or autozone sell the the right spark plugs?
