Just got my OEM sized Power Slot rotors and Hawk HPS Street pads in the mail.
After doing the recommended bedding-in process (below), how long should I use them on the street before subjecting them to a track day? Can I install them within a few days before or should I have used them on the street for a week or two? I'd like to get as much use out of my stock stuff before changing over to the better stuff for the track.
Thanks -------------- Bedding In Procedure from Hawk 1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure. 2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph. 3. DO NOT DRAG BRAKES! 4. Allow 15 minutes for brake system to cool down. 5. After step 4 your new pads are ready for use. -------------- |
Days, if that.
make SURE all lugs are to 90ft/lbs!!! avoid warping on the track!
i'd still do another couple hard stops a day before a track day and again let them sit for a few hours to cool
Thanks! I am also going to be switching to Motul brake fluid.
