Loud Noise + Vibration When Turning Left
Hello,
Recently my TT has been making a loud noise and vibration when I turn the wheel any amount to the left. I originally assumed wheel bearing, and when replacing the bearing noticed the CV joint was pretty beat, so now I have a new wheel hub, new wheel bearing, and new axle with new CV joints (all on the drivers side). I'm wondering if anyone has any advice on what to check next besides the tires because they seem fine. Also, I do all my own maintenance and have a VAG COM system although that may not mean anything with this issue. Thanks! |
Forgot to mention, it does get louder/worse with speed and does not go away
Two things. What about the right side bearing and cv? Also could it be esp pulsing the brakes due to an out of calibration acceleration sensor? Mine did that when turning left downhill. Replaced both acceleration sensors and calibrated them. No further issues. Try turning esp off and see if the sound goes away. |
Did you properly torque the axle bolt when you installed the bearing? Did you properly loosen the bolt when you later installed the new CV Joint/axle. That is not allowing any load on the bearing without the bolt loosened? If that was not the case, the new bearing was likely damaged.
