Thinking of buying 2014 TTs
Hey guys, Im totally new here.
was hoping for some hospitality and new stuff to learn i guess. Any opinions or common things to look out for problem wise with 2014 model? The car has 55,000kms on it, and with a meh car proof/fax a crack underside on the sheathed body, missing sparetire and jack, shop said misfire code was in it cleared suggest replacing spark plugs ( i think thats the misfire?, idk?) also i was driving and low tire pressure error came on the dealer stated new rear shocks, which they are replacing, but when i took it to a mechanic, they saw nothing with the shocks. im left feeling a little uneasy link is below https://www.autotrader.ca/a/audi/tts..._13_13&sprx=-2 |
bump pls suggestion and opinions?
Read this FAQ https://forums.fourtitude.com/showth...-MK2-TT-a5-FAQ
Pay attention to the mag ride discussion in the FAQ which the TTS has. The Mk 2 did not come with a spare nor jack |
Thank you very much! Im in canada also I forgot to mention
anyone else? any info? the car was sold at an auction, 1 owner, two dealerships with, a total of 3 owners, and currently back at a dealership
What happened with this? Did you get it? My thoughts - 55K service mark is pretty much everything (https://www.audiusa.com/content/dam/...-Year-2014.pdf) so you could be in for a chunk of change right off the bat. Probably the reason for the misfire code is that it needs it's regular maintenance, including spark plugs.
The shock replacement recommendation is questionable...mine didn't need it until 75K miles, but maybe the roads are rougher there? |
