S4 Diagnostic help needed
Cars starts and drives fine for a short while then ESP, TPMS, Park Brake, ABS and sometimes engine light all come on together.
Symptoms is that the gearshift pattern becomes erratic. Shifts up to top gear when lifting off throttle no matter what the speed. eg at 30Km/h lift throttle shifts to 7th gear. Sometimes gearbox goes into neutral. The following fault codes were recorded. if there is anyone that has experienced this, or knows what these codes mean it would really help. Chassis Type: 8K-AU48 (8T0) Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 62 6C 72 VIN: WAUZZZ8K0AA060375 Mileage: 133870km-83182miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAKA) Labels:. 06E-907-551-CAK.clb Part No SW: 8K0 907 551 HW: 8K0 907 551 Component: 3.0T SIMOS84 X06 0006 Revision: --X06--- Coding: 0104000C240F0128 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM30TFS8K0907551 A02008 ROD: EV_ECM30TFS0218K0907551C.rod VCID: 6ED8D13AB1DA953A39-803A 3 Faults Found: 6201 - Function Restriction due to Faults in Other Modules U1113 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 5 Mileage: 133819 km Date: 2019.01.07 Time: 11:30:54 Engine speed: 1867.00 /min Normed load value: 58.4 % Vehicle speed: 69 km/h Coolant temperature: 93 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.710 V Unlearning counter according OBD: 40 Engine speed: actual: 1312 /min MAF_ENVD: 424.87058 mg/stroke Coolant temperature (unfiltered): 94.5 °C Engine: operating status: PL Engine load: 55.859375 % Vehicle speed: actual: 65 km/h 6134 - Function Restriction due to Faults in Other Modules U1113 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 6 Mileage: 133819 km Date: 2019.01.07 Time: 11:30:43 Engine speed: 2299.00 /min Normed load value: 12.2 % Vehicle speed: 77 km/h Coolant temperature: 93 °C Intake air temperature: 33 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.913 V Unlearning counter according OBD: 40 Engine speed: actual: 1408 /min MAF_ENVD: 332.27058 mg/stroke Coolant temperature (unfiltered): 93.8 °C Engine: operating status: PL Engine load: 43.359375 % Vehicle speed: actual: 72 km/h 6162 - Internal Control Module P0603 00 [032] - Non-Volatile Memory Error Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 133819 km Date: 2019.01.07 Time: 11:11:56 Engine speed: 2277.00 /min Normed load value: 5.9 % Vehicle speed: 78 km/h Coolant temperature: 93 °C Intake air temperature: 33 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.812 V Unlearning counter according OBD: 40 Engine speed: actual: 1376 /min MAF_ENVD: 103.49411 mg/stroke Coolant temperature (unfiltered): 95.3 °C Engine: operating status: IS Battery voltage: 12.390625 V Vehicle speed: actual: 0 km/h Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb Part No SW: 8K1 927 156 AC HW: 0B5 927 156 E Component: 0B5 30TFSIRdW H04 0004 Revision: --H04--- Serial number: 0000000386 Coding: 000001 Shop #: WSC 32862 000 1048576 ASAM Dataset: EV_TCMDL501 A02051 ROD: EV_TCMDL501.rod VCID: 76E8F95AC98AADFAF1-8022 1 Fault Found: 8448 - Implausible Data Received from Engine Control Module U0401 00 [104] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 63 Reset counter: 40 Mileage: 133819 km Date: 2019.01.07 Time: 11:30:33 Engine speed: 818 /min Transmission input speed: 818 /min Transmission output speed: 0 /min Engine torque: -4 Nm Transmission fluid temperature: 83 °C Accelerator position: 0.0 % Clutch status: Beide Kupplungen offen ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA Component: ESP8 quattro H04 0010 Revision: -------- Serial number: -------------- Coding: 290D08 Shop #: WSC 06325 000 00000 VCID: 7AF0ED6AF592C99A95-802E 2 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 6 Reset counter: 82 Mileage: 133819 km Time Indication: 0 Date: 2019.01.07 Time: 11:30:30 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0022 Hex Value: 0x0026 Hex Value: 0x4692 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 2 Reset counter: 82 Mileage: 133819 km Time Indication: 0 Date: 2019.01.07 Time: 11:30:31 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x2222 Hex Value: 0x0032 Hex Value: 0x0295 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 DT HW: 8K0 907 064 DT Component: BCM2 1.1 H02 0324 Revision: 00002001 Coding: 051100 Shop #: WSC 06325 000 00000 VCID: 050A8E968C6CB662E8-8050 Subsystem 1 - Part No SW: 8T0 959 754 AH HW: 8T0 959 754 AH Component: FBSAUDIB8 IDG H37 0060 Serial number: 0508000066725003 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0209000065333001 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG Component: KLIMA 3 ZONEN H08 0171 Revision: D1000000 Serial number: 01080920090738 Coding: 66146000 Shop #: WSC 06325 000 00000 VCID: 77F6F45EC680D4F2EA-8022 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H25 0380 Revision: 10025001 Serial number: 00000000346256 Coding: 260050914034AF010001000300001D0D0F1D43080001014100 0000 Shop #: WSC 06325 000 00000 VCID: 3C7C2B72BF2637AAC7-8068 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 140909 H05 0070 Serial number: SWF09090140102 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10598781 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000000809091399 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 L HW: 4E0 035 110 A Component: CDC-MP3-Pana H49 0050 Revision: 00000015 VCID: 2142FA0638847A42F4-8074 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840926208200 Coding: 30010D Shop #: WSC 06325 000 00000 VCID: 40845F82D3CE534A9B-8014 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD05RAWX Coding: 30373435363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 41825A86D0C45A4294-8014 Crash sensor for side airbag: driver side: Serial number: 6334MSME4B15176FN Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4B723812C Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME0A3B2C04J Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME073B3B0AN Crash sensor for front airbag: driver side: Serial number: 63732SME003A2B28Z Crash sensor for front airbag: front passenger side: Serial number: 63832SME383839360 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90319IIG000C7 Coding: 000036 Shop #: WSC 06325 000 00000 VCID: 3D7A2676A43C3EA2F0-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 F HW: 8K0 920 930 F Component: KOMBIINSTR. H05 0255 Revision: 00000000 Serial number: CJ0354999 Coding: AF0709000B000008010000 Shop #: WSC 06325 000 00000 VCID: 30640F42636EC3CA6B-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 T HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0105 Revision: EB800053 Serial number: 5300E09902810D Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 52A065CA0DA2D1DA3D-8006 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0170 Serial number: 1908DE07020909 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0074 Revision: AA000000 Serial number: 00001001337559 Coding: 00781B00000000000000 Shop #: WSC 06325 000 00000 VCID: 3B7E286EBA283092CE-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000009308244 Coding: 011C12205E01410001 Shop #: WSC 06325 000 00000 VCID: 458A4E96CCEC7662A8-8010 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 DT HW: 8K0 907 064 DT Component: BCM2 1.1 H02 0324 Revision: 00002001 Serial number: 0121464818 Coding: 011A0E22003904850030010000000000 Shop #: WSC 32862 000 1048576 VCID: 050A8E968C6CB662E8-8050 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS037 H06 0041 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 41 Mileage: 133820 km Time Indication: 0 Date: 2019.01.07 Time: 16:49:03 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 41 Mileage: 133820 km Time Indication: 0 Date: 2019.01.08 Time: 10:41:43 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK Component: DSP Prem H08 0170 Revision: 00008001 Serial number: 34881005411003 VCID: 77F6F45EC680D4F2EA-8022 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000009328063 Coding: 011C12205E01410001 Shop #: WSC 06325 000 00000 VCID: 448C5392C7D64F6ABF-8010 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000453286 Shop #: WSC 00000 000 00000 VCID: 346C03529776FFEA0F-8060 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 66 Reset counter: 82 Mileage: 133819 km Time Indication: 0 Date: 2019.01.07 Time: 11:30:31 Freeze Frame: Voltage: 12.00 V Count: 58 Speed: 0.0 km/h Hex Value: 0x02E3 Hex Value: 0x0001 Hex Value: 0x1010 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8T0-907-357.clb Part No SW: 8H0 907 357 C HW: 8H0 907 357 C Component: AFS 1 H01 0030 Revision: 00000001 Serial number: Coding: 0000019 Shop #: WSC 32864 000 1048576 VCID: 3260054AAD62F1DA1D-8066 Subsystem 1 - Part No: 8K0 941 329 Component: AFS-Modul links H02 S001 Subsystem 2 - Part No: 8K0 941 329 Component: AFS-Modul rechtsH02 S001 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4F0 035 053 B HW: 4F0 035 053 Component: Radio U Basic H45 0020 Revision: AB001007 Serial number: 341I-097637714 Coding: 040003010000000001 Shop #: WSC 06325 000 00000 VCID: 1C3CCBF21FE657AA27-8048 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: None Part No SW: 8T2 035 754 D HW: 8T2 035 754 D Component: H-BN-RW H41 0047 Revision: -------- Serial number: 485I4097502779 Coding: 010A01000206A1EF41000B0E000000030001 Shop #: WSC 06325 000 00000 VCID: 3A702D6AB512099AD5-806E Subsystem 1 - Part No: 8R0 060 884 D Component: ROW 2009/2010 5103 Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604 Component: DU7 High H43 0306 Serial number: 9356I+091067479 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000363155 Subsystem 4 - Part No: 8R0 906 961 A Component: CD-Database 1293 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000101884712 Coding: 010C12204001210001 Shop #: WSC 06325 000 00000 VCID: 4280558ADDC2415A8D-8016 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H03--- Serial number: 525PA8-J9890ZV Coding: 1022006 Shop #: WSC 06325 000 00000 VCID: 387437624B1E1B8A23-806C No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000101884710 Coding: 010C12204001210001 Shop #: WSC 06342 000 00000 VCID: 4280558ADDC2415A8D-8016 No fault code found. |
I've seen in one instance an S4 with air ride installed caused the front passenger tire to rub through the fender liner and into the body harness. The harness ran along the frame rail and to around the where the bumper attached to the fender. Both the top and bumper fender area were heavily damaged. Any time the body flexed all lights came on.
It did not have shifting issues. I have seen bulletins for the valve body's and other issues though but that doesn't look like the problem. However i found this, in Ross Tech Wiki maybe it will help. 16987/P0603/00153916987/P0603/001539 - Internal Control Module: Non-Volatile Memory ErrorPossible Symptoms
Possible Causes
Possible Solutions
Special NoteTCM part number 3B0 927 156 AH will have this fault code when new. Perform soft coding of "0001104" and fault should clear.-Cheers |
Thanks for the input
there were two problems ECU and Wiring the ECU has a faulty internal memory the wiring problem was a corroded can bridge under the dash near the fuse box on the drivers side (RHD) Solution was to replace ECU and clean the can bridge. All good now! |
