S4 Diagnostic help needed
Cars starts and drives fine for a short while then ESP, TPMS, Park Brake, ABS and sometimes engine light all come on together.
Symptoms is that the gearshift pattern becomes erratic. Shifts up to top gear when lifting off throttle no matter what the speed. eg at 30Km/h lift throttle shifts to 7th gear. Sometimes gearbox goes into neutral.
The following fault codes were recorded.
if there is anyone that has experienced this, or knows what these codes mean it would really help.
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 42 46 47 52 53 55 56
5F 62 6C 72
VIN: WAUZZZ8K0AA060375 Mileage: 133870km-83182miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAKA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 X06 0006
Revision: --X06---
Coding: 0104000C240F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS8K0907551 A02008
ROD: EV_ECM30TFS0218K0907551C.rod
VCID: 6ED8D13AB1DA953A39-803A
3 Faults Found:
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:54
Engine speed: 1867.00 /min
Normed load value: 58.4 %
Vehicle speed: 69 km/h
Coolant temperature: 93 °C
Intake air temperature: 35 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.710 V
Unlearning counter according OBD: 40
Engine speed: actual: 1312 /min
MAF_ENVD: 424.87058 mg/stroke
Coolant temperature (unfiltered): 94.5 °C
Engine: operating status: PL
Engine load: 55.859375 %
Vehicle speed: actual: 65 km/h
6134 - Function Restriction due to Faults in Other Modules
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:43
Engine speed: 2299.00 /min
Normed load value: 12.2 %
Vehicle speed: 77 km/h
Intake air temperature: 33 °C
Voltage terminal 30: 13.913 V
Engine speed: actual: 1408 /min
MAF_ENVD: 332.27058 mg/stroke
Coolant temperature (unfiltered): 93.8 °C
Engine load: 43.359375 %
Vehicle speed: actual: 72 km/h
6162 - Internal Control Module
P0603 00 [032] - Non-Volatile Memory Error
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 133819 km
Date: 2019.01.07
Time: 11:11:56
Engine speed: 2277.00 /min
Normed load value: 5.9 %
Vehicle speed: 78 km/h
Voltage terminal 30: 13.812 V
Engine speed: actual: 1376 /min
MAF_ENVD: 103.49411 mg/stroke
Coolant temperature (unfiltered): 95.3 °C
Engine: operating status: IS
Battery voltage: 12.390625 V
Vehicle speed: actual: 0 km/h
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K1 927 156 AC HW: 0B5 927 156 E
Component: 0B5 30TFSIRdW H04 0004
Revision: --H04--- Serial number: 0000000386
Coding: 000001
Shop #: WSC 32862 000 1048576
ASAM Dataset: EV_TCMDL501 A02051
ROD: EV_TCMDL501.rod
VCID: 76E8F95AC98AADFAF1-8022
1 Fault Found:
8448 - Implausible Data Received from Engine Control Module
U0401 00 [104] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 63
Reset counter: 40
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:33
Engine speed: 818 /min
Transmission input speed: 818 /min
Transmission output speed: 0 /min
Engine torque: -4 Nm
Transmission fluid temperature: 83 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 290D08
VCID: 7AF0ED6AF592C99A95-802E
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 6
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:30
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0022
Hex Value: 0x0026
Hex Value: 0x4692
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:31
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x2222
Hex Value: 0x0032
Hex Value: 0x0295
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DT HW: 8K0 907 064 DT
Component: BCM2 1.1 H02 0324
Revision: 00002001
Coding: 051100
VCID: 050A8E968C6CB662E8-8050
Subsystem 1 - Part No SW: 8T0 959 754 AH HW: 8T0 959 754 AH
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000066725003
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000065333001
No fault code found.
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0171
Revision: D1000000 Serial number: 01080920090738
Coding: 66146000
VCID: 77F6F45EC680D4F2EA-8022
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000346256
Coding: 260050914034AF010001000300001D0D0F1D43080001014100 0000
VCID: 3C7C2B72BF2637AAC7-8068
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140909 H05 0070
Serial number: SWF09090140102
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10598781
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000809091399
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H49 0050
Revision: 00000015
VCID: 2142FA0638847A42F4-8074
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840926208200
Coding: 30010D
VCID: 40845F82D3CE534A9B-8014
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD05RAWX
Coding: 30373435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 41825A86D0C45A4294-8014
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4B15176FN
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4B723812C
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME0A3B2C04J
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME073B3B0AN
Crash sensor for front airbag: driver side:
Serial number: 63732SME003A2B28Z
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME383839360
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IIG000C7
Coding: 000036
VCID: 3D7A2676A43C3EA2F0-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 F HW: 8K0 920 930 F
Component: KOMBIINSTR. H05 0255
Revision: 00000000 Serial number: CJ0354999
Coding: AF0709000B000008010000
VCID: 30640F42636EC3CA6B-8064
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09902810D
Coding: 00C303
VCID: 52A065CA0DA2D1DA3D-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1908DE07020909
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001001337559
Coding: 00781B00000000000000
VCID: 3B7E286EBA283092CE-806E
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009308244
Coding: 011C12205E01410001
VCID: 458A4E96CCEC7662A8-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0121464818
Coding: 011A0E22003904850030010000000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 133820 km
Time Indication: 0
Date: 2019.01.07
Time: 16:49:03
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 133820 km
Time Indication: 0
Date: 2019.01.08
Time: 10:41:43
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34881005411003
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009328063
VCID: 448C5392C7D64F6ABF-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000453286
Shop #: WSC 00000 000 00000
VCID: 346C03529776FFEA0F-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 66
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:31
Freeze Frame:
Voltage: 12.00 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 32864 000 1048576
VCID: 3260054AAD62F1DA1D-8066
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H02 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH02 S001
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341I-097637714
Coding: 040003010000000001
VCID: 1C3CCBF21FE657AA27-8048
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8T2 035 754 D HW: 8T2 035 754 D
Component: H-BN-RW H41 0047
Revision: -------- Serial number: 485I4097502779
Coding: 010A01000206A1EF41000B0E000000030001
VCID: 3A702D6AB512099AD5-806E
Subsystem 1 - Part No: 8R0 060 884 D
Component: ROW 2009/2010 5103
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356I+091067479
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000363155
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101884712
Coding: 010C12204001210001
VCID: 4280558ADDC2415A8D-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9890ZV
Coding: 1022006
VCID: 387437624B1E1B8A23-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101884710
Shop #: WSC 06342 000 00000
5F 62 6C 72
Revision: --X06---
3 Faults Found:
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:54
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 133819 km
Date: 2019.01.07
Time: 11:11:56
Coding: 000001
1 Fault Found:
U0401 00 [104] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 63
Reset counter: 40
Mileage: 133819 km
Date: 2019.01.07
Time: 11:30:33
Coding: 290D08
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:30
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0022
Hex Value: 0x0026
Hex Value: 0x4692
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:31
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x2222
Hex Value: 0x0032
Hex Value: 0x0295
Hex Value: 0x00FF
Revision: 00002001
Coding: 051100
Coding: 66146000
Coding: 00FD11
Coding: 025028
Revision: 00000015
Coding: 30010D
Coding: 000036
Coding: 00C303
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 133820 km
Time Indication: 0
Date: 2019.01.07
Time: 16:49:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 133820 km
Time Indication: 0
Date: 2019.01.08
Time: 10:41:43
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 66
Reset counter: 82
Mileage: 133819 km
Time Indication: 0
Date: 2019.01.07
Time: 11:30:31
Freeze Frame:
Voltage: 12.00 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0000019
Coding: 1022006
I've seen in one instance an S4 with air ride installed caused the front passenger tire to rub through the fender liner and into the body harness. The harness ran along the frame rail and to around the where the bumper attached to the fender. Both the top and bumper fender area were heavily damaged. Any time the body flexed all lights came on.
It did not have shifting issues. I have seen bulletins for the valve body's and other issues though but that doesn't look like the problem.
However i found this, in Ross Tech Wiki maybe it will help.
-Cheers
16987/P0603/001539
16987/P0603/001539 - Internal Control Module: Non-Volatile Memory Error
Possible Symptoms
- Malfunction Indicator Light (MIL) active
Possible Causes
- Control Module faulty
- Soft Coding for Control Module not correct
Possible Solutions
- Replace Control Module
- Code Control Module
Special Note
TCM part number 3B0 927 156 AH will have this fault code when new. Perform soft coding of "0001104" and fault should clear.-Cheers
Thanks for the input
there were two problems
ECU and Wiring
the ECU has a faulty internal memory
the wiring problem was a corroded can bridge under the dash near the fuse box on the drivers side (RHD)
Solution was to replace ECU and clean the can bridge. All good now!
ECU and Wiring
blwestwood
A4 (B8 Platform) Discussion
9
04-27-2021 01:23 PM
Danielfive5
06-12-2019 11:04 AM
packge33
07-15-2012 12:17 PM
