16684/8 - Misfired on cold start. Engine sputtered and smell of sulfur
Leaving work this evening, the check engine light (blink and solid) came on when I started the engine. It then sputtered for about 5 - 10 minutes as I try to drive home. On the way home, I noticed the exhaust smells of sulfur. After driving for another 5 min, the sputter went away - check engine light is still on (solid). Could this be a problem of a bad cat?
Thoughts? Thanks! Address 01: Engine Labels: 058-907-55x-AEBN.lbl Part No: 8D0 907 557 P Component: 1.8L R4/5VT MOTR HS D02 Coding: 06201 Shop #: WSC 06335 4 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16688 - Cylinder 4: Misfire Detected P0304 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16688 - Cylinder 4: Misfire Detected P0304 - 35-00 - - Readiness: 0000 0000 |
Bad misfire on cyl. 4 is all it looks like to me
I know that scary smell of sulfur.
