HID leveling fault on a Skoda Octavia
Hi, hope you can still be of help even though it's an Audi forum. I've been having an issue with my Skoda Octavia 1.9 TDI '09. My headlights will not adjust, and I'm getting AFS error, no bend lighting in the dash. I have replaced the level sensor and it will still not work. They go up and down, but not to the sides.
I have tested the motor and they are working fine. As you can see from the picture, it's not getting any signal, however I just replaced it..? Bad new sensor? Bad AFS Module? Any help would be greatly appreciated! vcds log: Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0136 Revision: 00H04000 Serial number: Coding: 1507354 Shop #: WSC 73430 790 00999 VCID: 347E0C1BCE3B9AA2CB68EA5-8060 Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l S004 Coding: 00000023 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000023 2 Faults Found: 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 117 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 00496 - Sensor for Vehicle Leveling; Front 007 - Short to Ground - MIL ON Freeze Frame: Fault Status: 11100111 Fault Priority: 3 Fault Frequency: 254 Reset counter: 137 Mileage: 179649 km Time Indication: 0 Date: 2011.11.02 Time: 01:08:08 Freeze Frame: Voltage: 11.79 V Speed: 0.0 km/h ABS 1 https://www.briskoda.net/forums/uplo...71287f7386.png |
