HID leveling fault on a Skoda Octavia
Hi, hope you can still be of help even though it's an Audi forum. I've been having an issue with my Skoda Octavia 1.9 TDI '09. My headlights will not adjust, and I'm getting AFS error, no bend lighting in the dash. I have replaced the level sensor and it will still not work. They go up and down, but not to the sides.
I have tested the motor and they are working fine.
As you can see from the picture, it's not getting any signal, however I just replaced it..? Bad new sensor? Bad AFS Module?
Any help would be greatly appreciated!
vcds log:
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 1507354
Shop #: WSC 73430 790 00999
VCID: 347E0C1BCE3B9AA2CB68EA5-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
2 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
00496 - Sensor for Vehicle Leveling; Front
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 3
Fault Frequency: 254
Reset counter: 137
Mileage: 179649 km
Time Indication: 0
Date: 2011.11.02
Time: 01:08:08
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 1
vcds log:
Coding: 1507354
Coding: 00000023
Coding: 00000023
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Freeze Frame:
Fault Priority: 3
Reset counter: 137
Mileage: 179649 km
Time Indication: 0
Date: 2011.11.02
Time: 01:08:08
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 1
ToastR
VAG-COM Discussion
10-08-2021 11:36 AM
1 Bad DJ
09-04-2008 12:55 PM
BlackS4tt (Josh)
VAG-COM Discussion
09-01-2005 07:33 PM
