My VAG-COM Autoscan Results, should I be worried?
CAR: 2003 Audi 1.8T Quattro with 52K.....tiptronic
Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 ------------------------------------------------- Address 01: Engine Controller: 8E0 909 518 AK Component: 1.8L R4/5VT G 0006 Coding: 0016751 Shop #: WSC 22130 2 Faults Found: 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent 19534 - Throttle flaps drive unit air throughput i m idling too slightly P3078 - 002 - ------------------------------------------------- Address 02: Auto Trans Controller: 8E0 927 156 P Component: AG5 01V 1.8l5VT USA 0910 Coding: 0001002 Shop #: WSC 63351 1 Fault Found: 17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal P0711 - 003 - Mechanical Failure - Intermittent ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 H Component: ABS/ESP allrad 2328 Coding: 04277 Shop #: WSC 06435 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent |
do you have any drivability issues? check engine light?
Don't really see anything there that would cause me concern
Car runs smooth...
Nope, car runs great. No Check engine light or any other christmas lights lighting up my dash... Just wanted to see if there was something in those fault codes that would make you think maybe something immenant was coming up?
all looks like pretty innocuous stuff. No worries in my mind
schweeet! Thanks...
