My VAG-COM Autoscan Results, should I be worried?
CAR: 2003 Audi 1.8T Quattro with 52K.....tiptronic
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0006
Coding: 0016751
Shop #: WSC 22130
2 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
19534 - Throttle flaps drive unit air throughput i m idling too slightly
P3078 - 002 -
Address 02: Auto Trans
Controller: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
Shop #: WSC 63351
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 003 - Mechanical Failure - Intermittent
Address 03: ABS Brakes
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 01: Engine
Coding: 0016751
Shop #: WSC 22130
2 Faults Found:
P3078 - 002 -
Coding: 0001002
Shop #: WSC 63351
1 Fault Found:
Coding: 04277
Shop #: WSC 06435
1 Fault Found:
Car runs smooth...
Nope, car runs great. No Check engine light or any other christmas lights lighting up my dash... Just wanted to see if there was something in those fault codes that would make you think maybe something immenant was coming up?
absolutcq20v
03-13-2005 06:11 AM
Just got my VAG-COM and pulled the codes, could someone tell me what these mean and what I should do
Biscuit141
VAG-COM Discussion
04-08-2004 05:41 PM
