need code interpretation help
No CEL, but I pulled codes today (airbag light was on after wife adjusted seat...I can deal with that)
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 35-10 - - - Intermittent 17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-10 - - - Intermittent I cleared codes to see what comes back...I'll run tests on 17536 About 2 months ago, I had a CEL and 17536/P1128 code - replaced MAF, showed normal readings and CEL never came back. Any thoughts on 17748? 17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation Possible Causes Timing Belt/Chain incorrectly installed Timing Chain probably lengthened Camshaft Position Sensor (G40) faulty Engine Speed Sensor (G28) faulty Possible Solutions Check Timing Belt/Chain installation Use Measuring Value Blocks (MVB) to Check Timing Chain Check/Replace Camshaft Position Sensor (G40) Check/Replace Engine Speed Sensor (G28) Timing belt was done @2 years ago...how do I use MVB to check timing belt? |
Now I'm thinking that these may be residual codes
I looked at my last set of codes @3 months ago when I replaced the MAF. I had the same exact 2 codes (but with a CEL).
I don't think I have pulled codes since then. Wonder if these two were just lingering around. |
"Intermittent" in this context means the conditions that set the stored DTCs ...
did not exist at the time the DTC memory was scanned/cleared.
