VAG-COM Discussion
need code interpretation help
Old Sep 24, 2008 | 09:43 AM
Monkeyboy's Avatar
Default need code interpretation help
No CEL, but I pulled codes today (airbag light was on after wife adjusted seat...I can deal with that)
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
I cleared codes to see what comes back...I'll run tests on 17536
About 2 months ago, I had a CEL and 17536/P1128 code - replaced MAF, showed normal readings and CEL never came back.
Any thoughts on 17748?
17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor
Possible Causes
Timing Belt/Chain incorrectly installed
Timing Chain probably lengthened
Camshaft Position Sensor (G40) faulty
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Timing Belt/Chain installation
Use Measuring Value Blocks (MVB) to Check Timing Chain
Check/Replace Camshaft Position Sensor (G40)
Check/Replace Engine Speed Sensor (G28)
Timing belt was done @2 years ago...how do I use MVB to check timing belt?
Old Sep 24, 2008 | 10:27 AM
Monkeyboy's Avatar
Default Now I'm thinking that these may be residual codes
I looked at my last set of codes @3 months ago when I replaced the MAF. I had the same exact 2 codes (but with a CEL).
I don't think I have pulled codes since then.
Wonder if these two were just lingering around.
Old Sep 26, 2008 | 12:26 AM
diagnosticator1's Avatar
Default "Intermittent" in this context means the conditions that set the stored DTCs ...
did not exist at the time the DTC memory was scanned/cleared.
Monkeyboy
Oct 20, 2008 02:39 PM
Monkeyboy
VAG-COM Discussion
Oct 2, 2008 09:07 AM
allroad(s) lead 2Gavin
Audi allroad
9
Dec 2, 2007 11:50 AM
BLK01S4
Jul 30, 2004 07:03 AM
