Catalytic converter popped out of turbo...need some advice.
<center><img src="http://pictureposter.audiworld.com/18814/dscn2322.jpg"></center><p>Last night while driving at close to open throttle, the cat dislocated from the turbo. Has this ever happened to anyone else? Should I have it welded or should I replace the cat? If I should replace the cat, should I go aftermarket and what are my options? Should I pop in a newer turbo while I'm down there (car has 90K). And finally, is it safe to drive to the shop?
Thanks, Jon G |
pic from different angle...
<center><img src="http://pictureposter.audiworld.com/18814/dscn2323.jpg"></center><p>
its been known to happen.
i thought someone posted that its illegal to repair a cat. though some places will do it.
also audi's warranty is much higher for the exhaust equipment...hopefully someone can confirm this. |
Common...(edit)
You can have it rewelded. People have stated that the cat to cat flange is simply a press fitting (cheap), so it will come out over time. Welding it should be a permanent fix.
90k miles is out of the emissions warranty. weld it. happened to me @ 50K, but Audi
replaced mine. welding it should be fine.
common problem
Welcome...
...to the club.
<img src="http://images2.fotki.com/v19/photos/4/48510/201967/broken_cata-vi.jpg"> You're fine to drive on it, though you'll run pretty rich. As others have said, have it welded. If you can't find anyone to weld it, you can find a drop-in replacement at ECS Tuning. Good luck Andy |
You should gut the cat and re-weld your old one.
Since you don't have emissions testing.
-jaime |
Re: Catalytic converter popped out of turbo...need some advice.
just replaced both of my cats in my 97 a4 2.8 Man it was a pain in the ass. I got 2 aftermarket ones. The dealer wanted $1000 for each cat and 250 for labor i was like no F**ken way. i went to www.all-catalytic-converters.com and bought my cats for 250 a piece what a deal!!. and when i installed them both and installed new sensors man now it sounds great. these guys do a good job. i suggest calling them they have a friendly associate. i talked to mike well anyways im out.
Wouldnt his post 02 throw codes afterwards?
For cat inefficiency.
