Radio Volume
My 2016 A6 with every option but the Bose has a radio volume problem. Approximately 50% of the time when I start the car the radio volume is off and has to be turned up to hearing level. The other 50% of the time the radio volume is the same as when I turned the car off. Very annoying and the Dealer is of no help as the situation is unpredictable. I have tried rebooting the MMI.
Am I the only owner who has this problem? |
Originally Posted by NightBlue4.2
(Post 24728450)
(Post 24728450)
Originally Posted by Sportstick
(Post 24728471)
No, but the dealer has no fix and leaving it long enough to demo an intermittent problem has not been worth the time/trouble. We've rebooted everything that can be done with guidance from the Audi Tech Support line. When it happens, we just turn up the volume. At least, we permanently conquered the Start/Stop so that is one fewer button to push each time, so the radio sometimes takes its place.
NightBlue/Sportstick–Any luck in resolving this issue? Exact same scenario in my '16 A6. And the intermittent nature of it is perplexing and annoying. |
I have the same problem on my 16 A6. Haven't looked into it yet.
Start/stop is another annoying thing. How do I shut that off without driving in S or hitting the button? |
You guys know that you control the start/stop by how heavy you push down on the brake pedal at a stop. I think it's easily controlled, but maybe it's just I never mash the pedal to the floor at a stop. I can easily press it down a little harder at a long light and shut the engine down.
Originally Posted by SpeedKeen
(Post 24775918)
Start/stop is another annoying thing. How do I shut that off without driving in S or hitting the button? Instructions for VCDC coding to disable start/stop efficiency system upon each ignition can be found here: |
Originally Posted by M/M's Dad
(Post 24775908)
Originally Posted by Ricckky
(Post 24775960)
I wonder if it's something that can be changed with VCDS. I have B&O. If I had my volume turned up (to 20 for example) when I shut down, It always turns on at 12 if I was listening to Sirus and 13 if I was listening to Media, consistently. Can't remember but I want to say if it's less than 12/13 when I shut down, it stays at whatever level it was at. I've never had the volume not come on.
(Post 24775960)
(Post 24775908)
